Primare SP32HD met HD audio board
Started by Johnny_Bravo, November 15, 2020, 12:02:54
Johnny_Bravo
In nieuwstaat verkerende Primare SP32HD.
Inclusief de SP33 HD audio Update, waarbij het videoboard vervangen is voor 5xHDMI in en 2x HDMI out.
Tevens is hiermee ook het nieuwe OSD geïmplanteerd.
Door de upgrade dus identiek aan de SP33
Upgrade alleen was al € 1.250,-
Wordt geleverd inclusief luxe afstandsbediening.
Features
- HD Video pass through (3D)
- Upscaling to 1080p
- 5 HDMI in
- 2 HDMI out
- New onscreen menu in conjunction with new C24 remote
- Individual offset per input
- Individual video settings per HDMI output
Balanced analogue outputs:Front (left and right)
Center, Sub, Surr (left and right)
Surr back (left and right)
Unbalanced analogue outputs:Front (left and right)
Center, Sub
Analogue record output:1 RCA (left and right)Zone2 output:1 RCA (left and right)
Digital outputs:1 RCA
1 TOS-LinkVideo outputs:
2 HDMIAnalogue
inputs:2 balanced
8 RCA
incl. 7.1 inputsDigital inputs:1 balanced
3 RCA
3 TOS-Link.Video Inputs:
5 HDMI
Digital Frequency response:20Hz-20kHz ±0.2dBTHD and noise:0.005% @1kHz (AES17 filter)THD:<0.005%, 20Hz-20kHzSignal to noise ratio:-110dB
Analogue Frequency response:10Hz-100kHz, 1dBInput impedance:47kΩ unbalanced
3kΩ balancedOutput impedance:47Ω unbalanced
47Ω balanced
Processing Upscaling:1080p/24Video:HDMI with HDvideo pass-tru with 3Dpass and
HDMI OSDModes:Stereo, Bypass, Party,
Dolby Prologic IIx Music,
Dolby Prologic IIx Movie,
DTS NEO:6 MUSIC
DTS NEO:6 CINEMADecoding formats:Dolby Digital
Dolby Digital EX
Dolby Prologic II
Dolby Prologic IIx
Dolby EX
Dolby Plus
Dolby TrueHD
DTS
DTS ES
DTS Neo:6
DTS 96/24
DTS HDMaster Audio
DTS HD High Res audio
MULTI/2 CH PCM/LPCMSampling rates:32KHz,44.1KHz,48KHz,
88.2KHz,96KHz,192KHzControl:1 IR Input
3 12V outputs (triggers),
1 RS232RS232:
The RS232 connector allows your dealer to
upgrade the firmware on your SP33, or control
the SP33 as part of a multi-room system.
Power consumption:Operating: <60W.
Fully stabilized SMPS Color:black or titanium
Weight:12 kg
Width:430mm
Depth:385mm
Height:180mm
Johnny_Bravo
Nu vaste forumprijs...
Te beluisteren in de buurt van Nijmegen, zolang hij nog aangesloten staat.
Beluisteren op eigen eindversterker uiteraard ook mogelijk.
Johnny_Bravo
Ik ken de tijden hier op het forum dat een Primare binnen 1 dag weg was.....
