REL Acoustics Q50 , met replacement woofer
Started by Ralf67, September 4, 2020, 13:16:19
Ralf67
Rel Q50 subwoofer met  replacement woofer.
Deze woofer vervangt de bestaande woofer waarvan de foamrand vergaan is.
Mag weg voor €80
Compleet met spikes en 220V kabel.
You are looking at a 12" speaker that has been especially selected by the designer of the Q50 / Q100 as a suitable replacement drive unit. This speaker boasts a large magnet, vented pole piece, rubber surround and a polypropylene cone, which results in tight and controlled bass.
Ralf67
Prijs voor de Rel Q50 naar €75
