Monitor Audio MR2
Started by Ralf67, August 29, 2020, 14:47:09
Ralf67
Monitor Audio MR2
Zeer fraaie boekenplank luidsprekers.
Mogen weg wegens overcompleet.
Met frontjes, waarvan 1 met klein gaatje.
2 gaatjes in achterkant van ophangbeugels.
Verpakking aanwezig.
Mogen weg voor €129
https://www.monitoraudio.com/en/support/past-products/monitor-reference/mr2/
Frequency Response
42 Hz — 30 kHz
Sensitivity (1W@1M)
90 dB
Nominal Impedance
6 ohms
Power Handling (RMS)
100 W
Recommended Amplifier Requirements
30 — 100W
Bass Alignment
Bass reflex - Front ported
Drive Unit Complement
1 x 6.5" MMP II bass/mid-range
1 x 1" C-CAM Gold Dome tweeter
External Dimensions (Including Plinth (H x W x D))
350 x 185 x 250 mm (133/4 x 75/16 x 913/16")
Weight (each)
5.6 kg (12.3 lbs)
Ralf67
Ralf67
Ralf67
Ralf67
