JVC laser projectoren plus NP5
Started by vik, August 7, 2020, 07:18:22
home@the movies
Quote from: papaleo on January  9, 2022, 19:20:32
Maar daar word de nz7 e-shift toch beoordeeld dit is nog de 'oude' e-shift en niet de e-shiftX.
De NZ7 is de nieuwe projector Leo, de oude is de N7 ;-)
papaleo
Dat weet ik maar de nz7 heeft niet de e-shiftX zoals de z8 en de z9 maar heeft de e-shift die de nx9 heeft dus de 'oude' e-shift techniek.
home@the movies
Quote from: papaleo on January  9, 2022, 20:44:03
Daar heb je een punt  :thumbs-up:
vik
Met betrekking op het geluid van de E-shift en ook de laser modes hier twee quotes van Kris Deering:
QuoteeShiftX noise should not be apparent at all unless you have NO other sound in the room and you are listening RIGHT at the unit and specifically for a change (shifting from off to on). I've done this test with several units now and can barely make out any change in sound at all. I run my 4100 in mid laser and from less than 3 ft from the front of the projector I can barely tell it is on with no other noise in the room (soft whir at best).
QuoteHigh laser is interesting with these projectors. It is DRAMATICALLY quieter than the RS4500. It is also about the same or slightly lower than the NX series in high lamp. The problem is that the low/mid laser modes are so quiet that when you go from them to high or vice versa, it seems a lot louder because of all the air rush noise. If you just start with the projector in high laser and never go to the lower modes, it actually sounds quite good (every time I do this in my room I'm amazed how quiet it is in high). But as soon as I go to mid/low and it gets REALLY quiet, going back to high sounds a lot louder all of a sudden.
The eShiftX noise on my unit nearly requires you to put your ear on the projector or right next to it and then toggle it on/off and you can still only barely make it out. My first review unit had ZERO difference with eShift even with my ear ON the unit. So there has been some variability with this. I can't imagine eShiftX noise being an issue for ANYONE even in the quietest movie.
m mulder
#1079
Zou het misschien mogelijk kunnen zijn dat er toch een verschil tussen de chassis van nz8 en nz9 zit.
Het blijft vreemd dat Theo wel iets hoort, maar Martin helemaal niets, terwijl de techniek hetzelfde zou moeten zijn
vik
Klopt Leo. De E-shift in de NZ7 werkt op 120hz (120 cycles per seconde) en de NZ8/NZ9 op 240hz (240 cycles per seconde)
Teejoo
Quote from: vik on January 10, 2022, 09:36:51
Ja, maar het geluid van zijn unit is dus duidelijk stiller dan die van mij. Want deze is ook op afstand goed hoorbaar. En die van Martin dus niet zelfs op 10 cm afstand.
home@the movies
Vandaag de bevestiging gekregen over de prijs van de Nieuwe NP5, prijs is zoals verwacht aan de wat hoge kant;
6999 Euro.
Wat zijn de verschillen tussen de JVC DLA-NP5 en de JVC DLA-NX5?
+100 lumen lichtopbrengst (nu 1900)
2x 48Gbps HDMI 2.1 versus 18Gbps op de NX5
Lage latentie modus
HDR10+
"Sneller verwerking voor superieure beeldweergave met hoge resolutie."
JVC NP5 Functies en specificaties
4K60p-ingang
0,69-inch 4K D-ILA
65 mm hoge resolutie volledig glazen lens
1.900 lumen lichtopbrengst
40.000:1 eigen contrast / 400.000:1 dynamisch contrast
HDR (Frame Adapt HDR/HLG)
ISF ccc-certificering
vik
Zowel ik als mijn collega CineMike hebben de NZ9 nog niet gezien dus kan daar niets over zeggen op dit moment. De vorige NX9 was geheel identiek aan de N7 behalve de lens en ik verwacht dat het met de NZ9 niet anders zal zijn.
Naar mijn mening is er niets geks te horen bij de NZ8 bij Teejoo en zodra je het volume aanzet van een film hoor je helemaal niets meer van dit geluid. En als je wat meer posts volgt van Kris Deering dan geeft hij ook aan dat het varieert en verschilt per unit. Dat zijn ook mijn persoonlijke ervaringen met de 1080P JVC Dila projectoren die zijn voorzien van een E-shift techniek.
Het blijft uiteindelijk een mechanische shutter die heel snel op en neer gaat en daar heb je onderlinge verschillen in dat heb ik altijd zo ervaren. Ook de akoestische omstandigheden spelen een rol.  In een vrij harde ruimte zul je de ene projector meer horen als in een andere omgeving en mijn oude ruimte was daar een perfect voorbeeld van.  In mijn plafond zat flink wat absorberend materiaal verwerkt en de projector hing daar strak tegen aan en je hoorde amper iets van projector.
Aan Teejoo zijn ervaring of de manier hoe hij iets als storend ervaart daar kan ik geen uitspraken over doen dat is zoals het is.
Quote from: m mulder on January 10, 2022, 09:37:52
#1084
Martin speelt doorgaans op redelijke 'oorlogssterkte' (misschien wel 110db). Misschien is zijn stoordrempel wat hoger?😉
m mulder
#1085
Toch blijf ik het vreemd vinden. Het chassis van de nz9 is immers langer, dan het chassis van de nz8. Dus zou er binnen in ook eea anders  kunnen zijn toch.
buckler
Quote from: MichelDW on January 10, 2022, 12:23:28
Haha , schuldig  :popcorn:
Nee serieus, zoals ik zei heb ik nu al meerdere malen geluisterd met mijn audio geluid uit en met mijn oor bij de projector en je hoort de 8k X e-shift simpelweg niet, niet bij on'off schakelen en niet bij het lopen tijdens een film scene.
Nu kan ik wat gehoorschade hebben opgelopen in de loop der jaren maar geloof me een ander hoort hem ook niet hoor. Hij is gewoon stil.
Ik kan van de week eens luisteren met de laser op low maar ik vreet mijn schoen op als ik hem dan wel hoor. Stil is stil.
Teejoo
#1087
Quote from: vik on January 10, 2022, 11:45:51
Waar het hier om gaat of het 'iets geks is' omdat sommige units dus wel stil zijn en anderen niet. Dat is bepalend, niet of het je stoort of je oordeel baseert op de vorige generatie e-shift.
En als klant die zich wel aan elk onnodig geluid stoort verwacht ik van JVC dat ik dan ook gewoon een stil exemplaar krijg voor zo'n bedrag omdat het dus blijkbaar wel kan. Daarom is het interessant om uit te zoeken hoe het nu in het veld zit. En dan bedoel ik idd gewoon in een stille kamer voor een zuiver vergelijk en om welk model.
Quote from: Teejoo on January 10, 2022, 16:50:53
Staat er niets in de specs van wat voor geluid de unit mag maken? Al zal denk ik e-shift niet als specifieke spec zijn ogenomen  :sleepy:
papaleo
#1089
Ik lees zojuist op avs dat er met de NZ/laser modellen nog iets mis is wanneer je e-shift gebruik...of dit structureel met alle units is of dat dit per unit kan verschillen is mij daar niet duidelijk geworden...maar er blijkt een groene kleur/gloed in de NF test patroon te zien zijn...of dit te wijten is aan dit testpatroon zou ook nog kunnen natuurlijk.
Het lijkt veel op color-moiré
In het filmpje is het zichtbaar/duidelijk gemaakt..
https://youtu.be/v-vskCmQH-Q
Zijn er hier NZ gebruikers die dit ook hebben waargenomen?
home@the movies
Ok, even een update want eerlijk is eerlijk.
Tot vandaag had ik enkel de NZ9 's gehoord, ik heb hier drie NZ7, een NZ8 en nog een NZ9 klaar staan om uit te pakken en te kalibreren voor klanten, maar aangezien ik op vakantie was moest dit even wachten.
Vandaag heb ik de eerste NZ8 gekalibreerd (onze eigen demo unit trouwens) en hoe graag ik ook zou zeggen dat ik niets hoorde bij het inschakelen van de 8K E-Shift, moet ik toegeven dat het wel degelijk zeer duidelijk hoorbaar is bij deze unit.
Zoals ik al zij, eerlijk, is eerlijk en datgene wat ik niet hoorde bij de NZ9 is wel degelijk aanwezig bij de NZ8, of dit ook op de NZ7 het geval is ga ik pas eind deze week al dan niet kunnen bevestigen, eerder heb ik geen tijd om ze te kalibreren.
Bennie
Quote from: papaleo on January 10, 2022, 18:45:49
Schijnt veelal in de "chain" te zitten. Dus bijvoorbeeld de blu-ray speler die qua processing een ongunstig effect heeft op dergelijke testpatronen. Dus zou dat niet te groot maken. Het probleem met het geluid vind ik wel een spannende. Ben benieuwd hoe dat zich gaat ontwikkelen..
JVC NZ8 - Projecta HD progressive 2.80m 2.40:1 - Panasonic 9004 - Jungson AV 1000D - Doumois reference 1 - Svs SB4000
home@the movies
#1092
Dit is een "normaal" fenomeen als je convergentie, E-Shift en/of andere processing gaat gebruiken  bij de Sony's reality creation bvb)
Dit test patroon is een torture test voor zeer hoge beeldfrequenties, en laat ook duidelijk zien waneer er geen één op één pixel mapping meer is, dat laatste geeft dit fenomeen en is zeker niet eigen aan JVC.
papaleo
#1093
Het is inderdaad alleen waarneembaar wanneer je e-shift aan hebt staan maar ook wanneer je in de instellingen de panelen op 'zoom' ipv 'native' heb staan en als je bron die het patroon weergeeft ook nog eens bv een enhancer aan heb staan kan dit ook nog eens worden geaccentueerd... 'Dit geeft maar weer eens aan dat je beter alle digitale snufjes/enhancers uit kan laten...' en het is inderdaad niet gerelateerd aan JVC het blijkt dat Sonyen zeker Epson op dit gebied nog 'slechter' presteert  ::)
Teejoo
#1094
Quote from: home@the movies on January 10, 2022, 18:54:54
Ik heb op AVS inmiddels ook het idee dat het niet hoorbaar is bij de NZ9. Maar fijn dat je hiermee ook bevestigd dat ik niet helemaal gek ben  ;)
Teejoo
#1095
Quote from: home@the movies on January 10, 2022, 19:04:18
Idd, en dat is in real life dus echt geen issue met filmmateriaal. Overigens is het ook geen issue als je het QBF patroon gebruikt. Dat wordt zelfs scherper. Het gaat echt om die moirè (?) patronen die raar gaan doen.
Ik weet zeker dat je het cool gaat vinden Leo! Let vooral op dat contrast en 'scherpere' heldere elementen in een donker frame door het verbeterde lichtpad. En ook zonder e-shift is het uiteraard al top.
home@the movies
QuoteMaar fijn dat je hiermee ook bevestigd dat ik niet helemaal gek ben  ;)
Niet helemaal neen  ;D ;D ;D ;D ;D ;D
papaleo
Quote from: Teejoo on January 10, 2022, 20:04:50
Hoe ervaar jij nu het laser-dimmen tov het iris dimmen...
En als het contrast/zwartwaardes zou toenemen hierdoor blijven de highlights in het beeld dan ook 'fel' overeind...,ik bedoel dimmen dan highlights ook niet mee?
home@the movies
Quote from: papaleo on January 10, 2022, 21:31:07
Of het nu laser dimming is of een iris, er gaat steeds een gamma correctie gebeuren om het "verlies" in de highlights te compenseren, je kan niet het ene hebben zonder dat het een invloed heeft op het andere.
Het verschil zit hem in de manier waarop het "dimmen" gebeurd, mechanisch door een iris zal meer kans hebben op ongewenste neveneffecten dan het dimmen van de laser.
Teejoo
Ik ervaar het zeker als een verbetering omdat het nog onopvallender gaat. Ik merk het soms alleen als er opeens ondertiteling in een donker beeld komt. Dan geeft hij opeens weer wat meer licht. Dan realiseer je je ook dat hij ook de highlights wat dimt, wat uiteraard ook niet anders kan. Maar in een sterrenveld of zo valt dat niet op omdat je enige referentie dan de sterren zijn, of het ruimteschip etc. Ze zouden het bereik idd nog iets kunnen verminderen om het perfect te krijgen.
