Stroomvoorziening
Started by paulkokkie, March 2, 2020, 19:34:47
holco
PascalP
Quote from: holco on March  6, 2020, 11:01:57
Voor wat het waard is wat klanten reviews.
https://ac-regenerator.com/what-they-say/
Potverdorie wat een godsgruwelijke achtergrond, bijna niet te lezen :P
Heb de tekst maar ff gekopieerd naar een Word filetje
Cyreg
en.... dat wordfile-tje kan je wel even posten?
setup:    Michell TecnoDec/RB250/TecnoW > MP110 > GramAmp2C/PSU1; Cyrus CD8SE; Cyrus FM7 >> DNM V3 Interlinks >>
             Exposure 3510 INT >> Exposure DMF-two LSkabel >> Harbeth C7ES-3 '35th Anniversary' op Ikea Oddvar stool
netspul: huiswcd > M-WaY 2DW+ Gold  > Furutech e-TP60E > AH! KB10 (3510), AH! KB10 (PSU1), AH! KB10 (8SE), AH! KB10 (FM7)
vanzomereng
Kingpin
€1850,- voor een paar parallelfilters ...  :-X
holco
kopiëren plakken kan ik wel  ;D
Customer Reviews
Set up my new toy Thursday and immediately discovered new levels of fine detail in recordings that I have known for decades along with a clearer definition of recorded space, depth and positioning of voices and instruments. Absolutely brilliant! These observations are based on 20 years of experimentation with power conditioners.
LeeMedia, Denmark
Does exactly what it says on the tin. i.e. put out a pretty constant 230v. Fan noise is zero (now that I've turned down the speed a bit). My incoming mains is showing on the high side (average around 250v so far). So the unit is working its magic and putting out 230v to my system (all the time).
My amp's trannies have suffered from hum/buzz since Ive owned it. Now almost silent being fed by the regen unit. I had previously tried a number of mains filters (which include DC blockers) but never silenced the amp until now. So from the readings showing thus far my guess that it was high mains voltage causing the trannies to sing away sometimes. Highly recommended!
If I was put on the spot right now and asked what was the best hifi bargain EVER in my own system..................I would probably pick this regen unit.
..... results are positive. Inky black and smooth are 2 words that spring to mind. Can watch fluctuations on computer too!
How does it sound? It's stunning...opened up the sound stage and a more 3d sound.
.... the most notable improvements are the extra seperation between instruments, added depth and width, and treble sparkle (not bright) particularly with percussive sounds. .... an excellent product thoroughly recommended.
Got my AG1500 today. Tried it first just on the power amp. Not a big difference. Then plugged the rest of the system in. WOW. Big upgrade. Tighter and more focused sound with a larger scale. Money well spent ....
I have a rather nice, stupid money, system. My AG1500 has just arrived and been plugged in. I swear that I can hear a difference; better highs, more separation, more air. I unplugged it and listened again then replugged it I am confident that that the music has improved. This is a complete no brainer.
The sound is amazingly clean and open now and the picture on the plasma is deeper, sharper and natural. I think the biggest thing for me tho is the input has never dropped below 240v and has risen to 249 and the output is always 230 so for that alone and the clean power this is a god send.
One thing that could be advertised better is the USB connection and the logging. Very useful.
This is one thing I will never be without in my system as it protects and cleans the power and has replaced a whole raft of Isotek products. Sold those and that more than covered the cost of the AC regenerator
I am genuinely hearing deeper, better defined bass along with a more tonally accurate mid-range and a soundstage that appears to have expanded in all directions. I don't know what the difference is compared to the 3KV UPS other than having half the rated output plus no batteries but I do know it's probably the most cost effective upgrade that I have made.
I maintain that having a stable and correct mains supply is essential to get the best out of any system and for the longevity of all electronics. So my advice to anyone would be to start with a regenerator in your system and any piece of kit that you add will always work at its best, that's my take on it anyhoo.
It might not work to the same extent for everyone, possibly dependent on your mains supply but I know I now couldn't listen without one. A true bargain in my estimation.
Brilliant product. I replaced a £1000 Nordost mains cable connecting the mains to a Nordost Thor mains conditioner with the AG500 powering the Thor via a bit of normal mains cable.In my system sounds it sounds very significantly better.And now I have a spare Nordost mains cable to connect between Thor and DAC.What's not to like? A serious Hifi bargain. Highly recommended.
R Thorogood
I'm using the two units in two separate setups:
Combined with the ATC SCM 50ASL Finest Fidelity, McIntosh D100 and a Auralic Aries it's an clearly significant improvement. The room opens wide, instruments are fixed at it's location and the bass get's more accuracy and definition. It's a serious improvement!
The second setup is a combination which shows every change of the equipment absolute dramatic: An Auralic Aries, a McIntosh D100 and a MalValve Headamp three plus Stax SR-007MKII (the 2.5er). It's with the AG500 like moving in a different world. It's no longer listening to recordings – it's so close to the perfect illusion. And it's with the AG500 indeed a huge and significant step forward.
I would say: Highly recommended.
My problem was: I had days when everything sounds wonderful. And the next hour, the next day it has been gone. With this experience it's clear to me: It depends on the quality of the power grid and that's absolute unpredictable. With the Power Inspired AG1500 and AG500 PWM it stay's constantly on the top level.
B Bohne
Adding the AG500 to the circuit brings cleaner, clearer, livelier sound. It doesn't colour the sound and it's perfectly transparent. Adding an audiophile power lead between the mains socket and the AG500 makes no difference, as expected. Overall I am very very pleased with it and would not consider going back to life without it. At £200 (with summer discounts) or even the retail price it is a true no brainer and could be a giant killer indeed. I have ordered silver plated DIY IEC male connectors from MCRU and will re-terminate a couple of my audiophile main cables to transform them into extension leads to add them between the AG500 and the Taboo MK3. I will report if this makes any difference.  This is as I found the impact of the AG500 is even more noticeable with the Taboo than with the Burson, but certainly there with both. I suspect this is because the Taboo is both more detailed and more transparent.
Negura
PROS:
good build quality
batteries in case of power downs
better dynamics
better imaging and positioning with better instrument separation
larger soundstage
improved details and micro-details
deeper, more controlled and punchier bass
not expensive at all
good support
I really cannot find any cons for this product.
The AG500 earns my full hearted recommendation.
Dan Gheorhie
Mr Me (John) HiFo WigWam
What I have noticed, is that since fitting the AG 1500 into my system the bias voltage has been ROCK Steady and I mean rock steady never varies.
Sound Quality – not easy to comment however – I am sure the sound stage is not only wider but more forward in presentation! Previously the sound stage was between and behind the speakers...
My room is not ideal and my speakers Reference 3A are good with lots of detail and clean bass for a stand mount albeit not to deep...
So a result! It would have been really helpful to have a dedicated owner handbook the one supplied references a UPS unit and more information about the technology within the AG1500 would be of interest.
S Shaw
The AG1500 I purchased from yourselves has transformed the sound of my system and I was using good quality mains filtering previously.  A great product at a very reasonable price. Almost inaudible in my listening room with the fan adjusted-the fridge in the adjoining kitchen is louder! It has completely eradicated the problems I had with a poor to ordinary domestic mains supply.
Dave I
#31
Supra stekkerblok met NIF filter is mooi en kost niet de wereld. Nieuwe met de Silver Lorad intern bekabeld kost €299 voor 6 stekkerposities.
(uiteraard is een ledenprijsje mogelijk)
Ik heb al jaren een degelijk blok van Hifituning, of en welke een effect deze heeft, ik weet het niet meer. Destijds was ik er na aanschaf iig direct content mee. Onderwijl heb ik er een Kemp sns plug ingeprikt, of en welke effect deze heeft, dat heb ik ook niet helder 🤓
Slechter werd het er niet op en ik heb hem daarom maar laten zitten.
TS komt met een doorsnee set en vraagt gepast advies.
Nu worden hier adviezen gegeven over filters die meer kosten dan de gehele set en een kwaliteitsbijdrage van 0,1% leveren.
Waar zijn jullie nou mee bezig  :nowink:
paulkokkie
Quote from: Kjelt on March  6, 2020, 17:44:01
Daarom begon ik ook met ' Ik durf het bijna niet te vragen'
Maar het zijn allemaal goed bedoelde adviezen, af en toe denk ik wel dat er een aantal mensen volledig doorschieten.
Van mij mag er een slotje op.
NAD C399+MDC module + Kef R3
(Denon AVR 4520 B&W DM640 B&WHTM61 S2)
HJ
Quote from: paulkokkie on March  6, 2020, 18:44:12
Ik laat mijn stekkers altijd op maat maken door een hobbyist op MP(mss wel iemand van dit forum?).
Dan geef ik de lengtes, stekkers en hoeveel aansluitingen etc op en maakt die persoon ze op maat. Gewoon degelijk en goed spul en voor normale bedragen ;-)
Mrgab
Quote from: MichelDW on March  6, 2020, 16:52:28
Ik ben ook in de markt voor een nieuw stekkerblok, zie de naam supra idd regelmatig voorbij komen. Weet je zo of deze er ook met 8 stekkerposities is?
PascalP
#38
Quote from: Mrgab on March  9, 2020, 13:24:57
2/4/5/6/7/8/10 is beschikbaar, ook configureerbaar hoe je wilt, dus met/zonder filter, met/zonder schakelaar etc.
heb zelf die met 10 sockets waarvan 2 ongefilterd en 8 gefilterd, geen schakelaar.
let wel, deze blokken komen zonder netsnoer, dit moet je er nog los bijkopen. T/m de 6 socket is het een standaard 10A IEC stekker (C13), vanaf 7 sockets is het een 16A IEC stekker (C19)
#39
Ze zijn er zelfs met 15 posities. :D
Snowmaster
Jij bent snel tevreden 😉. In dat geval zeg ik : koop voor weinig geld iets solides.
Als ik Kjelt zijn eerste reactie lees dan is een duur audiofiel blok niet zinvol bij jouw set.
Mwaaaah....discutabel. Wel is het jammer van je geld
Wat is dan wel zinvol?  Helaas is die vraag moeilijk te beantwoorden.
Allereerst kan de stroomaanvoer op jouw 4520 de klankkleur en kwaliteit wel degelijk beïnvloeden. Kan dat hoorbaar worden ? Ja !  Maar als je geen hobby hebt aan de zoektocht naar de beste combi voor jouw set en jouw huis begin er dan niet aan.
Sommige HTers draaien als meer dan 10 jaar stekkertjes en kabels .
@Kjelt : heb ik jou niet 10 jaar geleden een meterkast aanvoerkabel geleverd? Heb je die ooit gebruikt?
Quote from: Snowmaster on March  9, 2020, 15:37:48
Nee, moet iemand anders zijn geweest.
paulkokkie
#42
Nou, ik ben niet snel tevreden, maar heb zeer bepekte mogelijkheden qua banksaldo.
En als ik dan lees dat er een stekkerblokje te koop is die €800 kost dan vraag ik me af waar we mee bezig zijn. Nou met de hobby, en een hobby mag geld kosten, maar dan moet je het wel hebben.
Ik heb mijn ooj laten vallen op deze: https://www.jouwhifi.com/a-21249458/stekkerblokken/zeer-fraaie-kwaliteit-audio-video-stekkerdoos/
Vind ik voorlopig wel even genoeg.
B-art
Zou ook de supra nemen, goede prijs kwaliteitsverhouding. Alternatief de essential audio tools mains block, wel wat duurder maar ook mooi.
Rowdy
Zijn er ook stekkerblokken waar je 2 of meer adapters kunt aansluiten, zonder dat je een WCD moet overslaan? Stel ik wil 2 adapters en 1 stekker aansluiten heb ik een stekkerblok met minimaal 5 WCD's nodig. Fijn zou het zijn als het ook op een 3-voudige stekkerblok kan.
Je bedoelt van die stekkervoedingen? Dan voldoet een simpel gewoon stekkerblok, soms kun je ze omgedraaid wel naast elkaar steken, zeg maar met de body om en om aan de andere kant van het stekkerblok.
Rowdy
Bedoel meer trafo's in de vorm van een adapter. De trafo's van mijn platenspeler en Fono MC zijn in de vorm van een adapter.
JunkO
Kijk ook 's naar het volgende stekkerblok:
https://www.amazon.de/dp/B007VB3MVK/ref=sr_1_fkmr0_1?__mk_nl_NL=%C3%85M%C3%85%C5%BD%C3%95%C3%91&keywords=Music+Line+Mainsblock&qid=1584004220&sr=8-1-fkmr0
Deze is van goede kwaliteit, degelijk en zonder poespas en zeker niet te duur. Ik heb 'm zelf nu een aantal maanden en ben er erg content mee, zorgde bij mij (en een medeforummer) voor meer rust in het geluid.
Primare A30.1 MKII | ELAC 512 JET | Marantz HD-DAC1 | BeyerDynamic DT880 Edition 600 Ohm |  Yamaha WXAD-10 streamer + iFi Audio iPower | Van Damme Hifi Series | Ghentaudio + Tara Labs interlinks
Snowmaster
@paulkokkie : jij gaat van twee stekkerblokken naar één degelijker versie. In de basis is dat prima.
Maar....alle componenten in een set beïnvloeden elkaar. Ook al ze niet ingeschakeld zijn. Dit betekent dat als je alles samen in 1 blok stopt het resultaat ook slechter kan worden.
Doorgaans werkt het beste om een bronapparaat vooraan in te pluggen en een sub meer naar achteren. Ditzelfde geldt voor een tv. TV's kunnen flinke vervuilers zijn in een blok.
Advies : als alles een flinke tijd gedraaid heeft, probeer dan eens je tv of iets anders op een tweede blok uit. Ook volgorde van de stekkers kan geluid- en beeldverschil geven.
Wel alles (ook decoder) goed in fase zetten !
Laat tzt maar wat van je horen of het nieuwe blok bevalt. Is Altijd leuk
paulkokkie
Quote from: Snowmaster on March 15, 2020, 21:09:46
Bedankt voor je aanvulling. Maar het is de bedoeling om 2 stekkerblokken te gaan kopen.Dit mede door de opstelling hier en doordat elke fabrikant zijn eigen stekkers gebruikt en dus niet uniform is. Soms stekkers met een blokje er op, soms gewoon recht toe recht aan, soms met een hoek, en ik moet de stroom ook verdelen. Niet alle apparaten op een groep.
