Yippie
Author Topic: draaitafel project op basis van een L76  (Read 19378 times)
Offline simsatit
  • HT forum legend group
  • Trade Count: (+11)
  • Total likes: 116
  • Gender: Male
  • simon says: are you at it? as he is..
Re: draaitafel project op basis van een L76
« Reply #100 on: September 10, 2020, 16:35:39 »
Hi,
Dank mannen,
Niets meer gepost want dit project lag even helemaal stil, ga er weer mee verder dus foto's en verder verslag volgt.
>>>see you space cowboy<<<
daihatsu cuore 0.9, bic pen (navulbaar), gemÍleerd servies: klinkt allemaal erg goed!
Offline jrjhoe
« Reply #101 on: September 10, 2020, 19:16:28 »
Leuk!
Stereo: TAD CE-1 | REL B1 | Mark Levinson No. 332 | Krell KRC-HR | Luxman EQ-500 | Pyon Sound Ultima/Iris 12Ē | Michell Gyro SE Black/SME 309/DIY PSU | Mytek Manhattan II met Roon Ready kaart
Offline simsatit
  • Total likes: 116
  • Gender: Male
« Reply #102 on: September 20, 2020, 13:54:23 »
Klein stukje verder
Offline simsatit
  • Total likes: 116
  • Gender: Male
« Reply #103 on: September 20, 2020, 13:58:32 »
 8)
Offline jrjhoe
« Reply #104 on: September 20, 2020, 14:06:09 »
Gaaf, bring it on!  :headbanging:
Offline dre73
« Reply #105 on: September 20, 2020, 17:15:23 »
Vakwerk! 8)
Classe cp-45,Perreaux 3400,Acoustic Signature Challenger,Bluenote b5 titanium,Benz Ace-s,Pass labs Pearl 2 phono,Auralic Altair G1,zelfbouw luidsprekers .
Offline simsatit
  • Total likes: 116
  • Gender: Male
« Reply #106 on: September 22, 2020, 16:24:54 »
dank!
Offline simsatit
  • Total likes: 116
  • Gender: Male
« Reply #107 on: September 22, 2020, 16:27:33 »
en wat verder:
Offline minplus
  • senior member
  • Trade Count: (0)
  • Total likes: 545
  • Gender: Male
  • Don't worry, be happy
« Reply #108 on: September 22, 2020, 17:10:42 »
Fraai! 8)
If nothing's left, go right
Offline m9
« Reply #109 on: September 22, 2020, 22:42:09 »
12 inch arm zo te zien en welk element?
Offline simsatit
  • Total likes: 116
  • Gender: Male
« Reply #110 on: September 22, 2020, 22:56:28 »
Klopt, 12í
element is een Dynavector.
Offline simsatit
  • Total likes: 116
  • Gender: Male
« Reply #111 on: September 29, 2020, 12:49:42 »
Klein beetje verder..
Offline jrjhoe
« Reply #112 on: September 29, 2020, 17:32:28 »
Mooi!  :clapping:
Ben erg benieuwd naar het eindresultaat.
Offline simsatit
  • Total likes: 116
  • Gender: Male
« Reply #113 on: September 29, 2020, 20:14:03 »
Mooi!  :clapping:
dank je, anders ik wel 😁
Offline simsatit
  • Total likes: 116
  • Gender: Male
« Reply #114 on: September 29, 2020, 20:16:44 »
Het is trouwens een wat ouder element die een retip heeft gehad, hopelijk is het een mooie match met de arm.
Mocht deze niet voldoen dan komt er wel weer wat anders, maar eerst maar eens proberen.
Features and Improvements DV-20X has a solid aluminium alloy body similar to the XX-2. The cantilever is a 6mm length of hard aluminium pipe with a Micro-Ridge stylus. The magnetic flux damping and softened magnetism along with powerful neodymium magnets gives the 20XH a healthy 2.8 mV output - suitable for most MM inputs. The 20XL has an output of 0.3 mV ideal for most MC phono stages. Both high and low versions of their 20X are available ensure for the optimum end result.
The high output model is most suited to valve preamplifiers or electronics that only offer MM inputs whilst the low output version offers superb performance when combined with dedicated moving coil inputs.
SPECIFICTIONS
Type High/Low output moving coil cartridge with flux damper and softened magnetism
Output Voltage 2.8mV / 0.3mV (at 1KHz, 5cm/sec.)
Channel Separation 25 dB (at 1KHz)
Channel balance 1.0 dB (at 1KHz)
Frequency response 20 - 20,000Hz (Ī 2dB)
Compliance 12 x 10-6 cm/dyn
Tracking force 1.8 - 2.2grams
DC resistance 150 ohms / 5 ohms
Recommended load resistance > 1Kohms / > 30 ohms
Cantilever 6mm length, hard aluminium pipe
Stylus Micro-Ridge
Weight 8.6 grams
Offline simsatit
  • Total likes: 116
  • Gender: Male
« Reply #115 on: October 5, 2020, 14:24:18 »
korrel 800, op naar K2000
Offline simsatit
  • Total likes: 116
  • Gender: Male
« Reply #116 on: October 9, 2020, 13:52:19 »
Schuren en puimen is klaar, nu op naar het politoeren :headbanging:
« Last Edit: October 9, 2020, 13:57:19 by simsatit »
Offline simsatit
  • Total likes: 116
  • Gender: Male
« Reply #117 on: October 19, 2020, 13:54:48 »
politoeren klaar, redelijk gelukt, ben wel tevreden.
Offline Bart_M
« Reply #118 on: October 19, 2020, 15:48:28 »
Mooi werk!
Offline simsatit
  • Total likes: 116
  • Gender: Male
« Reply #119 on: October 19, 2020, 19:17:01 »
thanks!
fitting...
Offline simsatit
  • Total likes: 116
  • Gender: Male
« Reply #120 on: October 19, 2020, 19:19:07 »
Offline minplus
  • senior member
  • Trade Count: (0)
  • Total likes: 545
  • Gender: Male
« Reply #121 on: October 19, 2020, 20:37:23 »
Ruilen tegen m'n Zoonie? ::)
Offline jrjhoe
« Reply #122 on: October 20, 2020, 10:22:42 »
Heel gaaf!  :headbanging:
Offline simsatit
  • Total likes: 116
  • Gender: Male
« Reply #123 on: October 20, 2020, 11:57:47 »
je zoonie?
is het een puber? en is hij zo erg dat je hem wilt ruilen met mijn dt? 😂
Maar serieus, wat is een Zoonie?
Offline simsatit
  • Total likes: 116
  • Gender: Male
« Reply #124 on: October 20, 2020, 11:58:13 »
