Zidoo Z1000 Nieuwe Firmware release
Started by papaleo, January 10, 2020, 21:02:24
papaleo
Voor de belangstellenden is er nieuwe firmware release v2.3.10 voor de Z1000  :clapping:
Nu ook NL subs van Opensubtitels beschikbaar  :pompom:
En een tal van verbeteringen welke in de changelog zijn opgenomen.
http://forum.zidoo.tv/index.php?threads/new-firmware-v2-3-10-version-for-zidoo-z1000-release.66278/
System
1. Optimize the problem of the USB 3.0 port even if the device is lost
2. Fix the problem that DTS track music cannot be played
3. Fixed the issue that HIFI music will not play automatically next time
4. Optimize online playback
5. "Information" key, display the current HDMI output information
6. Optimized the problem of abnormal sound after DTS music playback is paused
7. Fix the problem of abnormal sound of Bluetooth device when HDMI output is set to source code output
8. Fixed the issue that Dolby Atmos audio freezes in some individual film sources
9. Optimize DLNA projection function
File manager
1. Fix the problem that the same share name is displayed in NFS (for Usbshare multiple external hard disk cabinets, only one can be found)
2. Cancel the top navigation category and add the list rotation function
3. Added CD disc insertion tips
4. Optimize sorting function (save separately by path)
5. Added the function of pressing "Popup" to return to the top of the list
6. Fixed the problem that the played video does not prompt the watched icon
7. Modify the problem that the volume label does not display more than 20 characters
Poster wall
1. Optimize the display of the details interface and the movie video
2. Optimize segmented video scanning
3. Optimize scanning to solve the problem that stopping scanning during scanning may cause unmatched videos to not match properly when continuing scanning
4. Solve the problem that the child lock set is not displayed synchronously after the movie rating is initially set
5. Increase the HDR corner mark (scanned videos will not be displayed)
6. Optimize file name recognition
7. Optimize application stability
8. Optimize bracket processing for title recognition
9. Added trailer filter filtering, the word 'trailer' in the file name will no longer be scanned
10. Optimize the NFS mount method
11. Fix the problem that the background service causes the setup wizard language to be incorrect
12. Fixed the problem of disordered video in the folder video list interface
13. Fixed the problem that poster information cannot be obtained based on the file path
14. Fixed the problem that the total number of videos on the device does not change after moving the video out of the poster wall
15. Clear device and delete device will remove related video information from database
16. Fixed the issue that the poster does not refresh after modifying the rating of the child lock
17. Child lock setting interface adds function description and child lock reset function
18. Optimize the collection function
19. Fixed the issue that playback records cannot be saved when playing NFS source
20. NFO added sorttitle field support, only use this field for sorting in movie collection interface
Music player
1. Optimize folder browsing function
2. Add CD playback function (requires external optical drive)
3. Optimize the sorting function
4. Optimize the calculation method of scanning progress
5. Optimize track identification for SACD and CUE albums
6. Improved the interface of obtaining track list, and solved the problem that the mobile phone cannot control the CUE / DSF track list of the temporary list
7. Modify the time display format of CUE to keep the same with SACD
8. Optimize focus control logic to solve the problem of focus flicker
9. Modify the recording method of the playlist to solve the problem that the last song in the random play mode will be rerandom.
10. Added screen saver function in play details interface
11. Fixed an issue where the list interface displayed an error after the grid layout removed the list
12. Fixed the problem of getting albums when playing music from file manager
13. Fixed the problem that the lyrics could not be closed without playing the details interface
14. Fixed the problem that sometimes the detailed interface picture cannot be obtained
15. Added automatic full-screen playback switch
16. Added music file information display to the list
17. Solve the problem that search interface focus may be lost
18. Fix the problem that the song is cut abnormally in the playback interface
19. Modify singer details interface
-Add album sub-categories, you can directly enter album details from the list
-Add picture subclasses, you can set the default, delete and add operations for pictures
-Add details sub-category, you can browse all the information of the singer
20. Add "View Artist" and "View Album" functions
21. Add song names that do not match the file name "track + number"
22. Fixed the problem of flashing back when pressing the "Home" key in the folder song interface
23. Fix the problem that Bluetooth remote control connection stops playing
24. Add multi-folder scanning. The abnormality will be displayed after the scanning is completed, and the normal display will be restored after all scanning
25. Fix the problem that the time of the song displayed on the front panel is incorrect
26. Fix the problem that the sample rate of the playback details interface is incorrect.
27. Fix the problem that some DTS-CDs cannot be played
Local player
1. The problem that the optimized bit rate is displayed incorrectly
2. Fix the problem that the movie name is displayed incorrectly
3. Add ZOOM function
4. Increase the video ratio
5. Fixed the issue that Polish subtitles are displayed in Portuguese
6. Optimized subtitle download function
7. Optimize the front panel USB icon display
8. Optimize the problem that DVD cannot select chapters
9. Optimize ASS subtitle display
10. Fixed the problem that the srt subtitle space is not displayed completely
11. Fixed the problem that the file name of the DVD folder was displayed abnormally during playback
12. Optimize the setting of video scale interface display
13. Add sequence play function
Blu-ray navigation
1. Added the function of subtitle track list displayed by shortcut keys
2. Optimize subtitle download function
3. Fixed the problem of incomplete display of srt subtitle space
Quick settings
1. Add ignore EDID function
2. Add video sequence playback function
Scheduled shutdown
1. Modify the problem that the traditional display is abnormal
Picture manager
1. When optimizing the slideshow, the picture is blurred
Weather
1. Optimize the problem that the weather is not available in some cities
Mobile APP (need to update mobile app v.1.5.5)
1. Add audio offset setting in the setting interface
2. Folder browsing function has been added to the music device interface
3. Application interface adds sorting function
4. Fixed the problem that the same device is repeatedly added to the music device interface
5. Fixed the issue that the CUE / DSF track list cannot be obtained from the temporary list songs
6. Optimize the problem that the application interface icon is not displayed
7. Optimize poster wall interface display
8. Solve the problem that the file management is affected by the search bar, and it will return to the upper directory when rescanning SMB or NFS
9. File manager adds list refresh function
10. File Manager adds CD-ROM drive list
keeskloon
Vraagje
Speelt deze Zidoo 1000 ook Dolby Vision af,want dan is deze speler interresant naast mijn Nvidia shield 2017 ivm iso afspelen met compleet menu.
Woonkamer:Marantz SR7015/Marantz NA7004/Fronts Dali Zensor7/Rear Dali Zensor5/Dali Zensor Vocal/Dolby Atmos Dali Alteco C1 4X/5.2.4/Sub SVS SB-3000 & SVS SB1000/Oppo UDP 203/Nvidia Shield Pro 2019/Zidoo 1000 Pro/LG Oled 65 G1 RLA /Ziggo Next mediabox/Synology 1019+/Synology 1517+
svmnb
Bedankt, Leo. ;)
@keeskloon: helaas, geen DV en zal er ook niet komen, vermoedelijk vanwege hoge licentiekosten.
svmnb
Zojuist geïnstalleerd en schermmelding "android wordt opnieuw gestart" ging niet weg.
Na een uur even de Zidoo app gestart en ik kon alles benaderen. Ook WRT was actief op mijn PC, dus het risico maar genomen op geforceerd afsluiten.
Firmware is verder keurig vernieuwd, dus niks aan de hand.
Even snel de subtitle functie getest, maar bij geen enkel bestand tot nu toe een Nederlandse ondertitel kunnen vinden.
papaleo
#4
Quote from: svmnb on January 11, 2020, 09:36:20
Ja dit had ik ook...,ook ik kon niet blijven wachten en had de Zidoo opnieuw opgestart.
Bij werkt de subtitel scraper wel goed...
Heb je in het menu 'Nederlands' aangevinkt?
Onder: Default Language>>Default download>>Nederlands + Nederlands(Belgie) aanvinken
keeskloon
Wil een 2e mediaspeler kopen naast mijn Nvidia shield  dus zat aan de zidoo 1000 te denken .
Kun je deze vergelijken met de shield of is er een betere.
Marco66
Zelfde issue id met blijven hangen na update, ff uit en aan en werkt weer.
Wel nog vraagje wat betreft de subtitle dowload, moet je hier nog ergens iets instellen?
Geeft nu download faillure aan. Ik weet dat je bijv in kodi toen je gebruikersnaam en wachtwoord moest invullen die je bij opensubtitles.org had gebruikt als aanmelding.
papaleo
Quote from: Marco66 on January 11, 2020, 12:18:04
Nee,heb ik niet hoeven doen...,na de update kreeg ik automatisch de NL subs te zien (wel eerst in het menu aanvinken,zie mijn vorige post)
papaleo
Quote from: keeskloon on January 11, 2020, 12:17:48
Ik heb mijn Shield Pro er voor opgeruimd...
Marco66
Quote from: papaleo on January 11, 2020, 12:29:09
Ok, ga ik wel naar kijken.
svmnb
Quote from: papaleo on January 11, 2020, 10:49:30
Hmm, ga ik alsnog doen :blush:
keeskloon
Ik heb de gok gewaagd heb een Zidoo z1000 besteld.
papaleo
keeskloon
Quote from: papaleo on January 14, 2020, 20:28:40
Nee geen gok grapje heb ik hem besteld na de vele positieve reacties van de mediaspeler de zidoo 1000.
keeskloon
Hij is binnen gekomen de Zidoo Z1000 werkt perfect maar 1 vraagje het krijg ik dit scherm erop zie foto.
Marco66
Quote from: keeskloon on January 16, 2020, 05:44:43
Lijkt de oude firmware, heb je niet de Zidoo Z10 besteld haha.
papaleo
#17
Inderdaad...zoals Marco al aangaf.
Dit is niet Zidoo's Z1000 eigen ontwerp launcher/Gui want deze ziet er heel fancy/chique uit.
Zie foto...
Volgens mij wil hij juist het voorbeeldvan zijn plaatje hebben en niet het nieuwe (fancy) GUI.
keeskloon
Quote from: papaleo on January 16, 2020, 16:17:23
Zie foto...
Opgelost dacht dat dat het homescreen was maar het was de andere sorry.
tdbakker
#20
Verstuurd vanaf mijn CMR-W09 met Tapatalk
Stereo:Xanadu HRS22YH//Cambridge Audio Edge NQ en W//Roon.
HT:Anthem MRX520//Rythmik E15//Xanadu Center HRC1 en Xanadu Rears//Sony KD-65AF8//Zidoo Z1000
usered
Een beginners vraag: sinds een paar weken een tevreden bebruiker van z1000 aangesloten via het netwek op een NAS en mijn TV.
Nu heeft mijn android pagina geen PLAYSTIRE, her en der lees ik dat deze te downloaden is. Waar zet ik dat bestand neer, en hoe handel ik dan.
Bij voorbaat vrindelijk dank voor de info
Ed..
