Arendal 2 white gloss 1700 nieuw 3 jaar oud
Started by chansig, October 4, 2019, 20:24:22
Bijna 3 jaar oud (december 2016). Nieuwprijs 1700 euro. Iets meer dan 40 kilo dus alleen ophalen (tussen Driebergen en Veenendaal naast de A12). Optisch en technisch 100%. Geen doos. Incl netsnoer.
Vraagprijs 999,-- euro
The Subwoofer 2 is the pinnacle of bass accuracy. Using two of our proprietary 13.8" driver driven by our 1000W RMS Avalanche DSP amp, the cabinet volume has been sized to produce an optimally damped system, producing low distortion, naturally deep bass, that drops and drops. A further performance edge is provided by our dual opposed, force cancelling driver topology to deliver clean deep hits, without cabinet movement subtracting anything from the driver output. To be safe, we've over engineered the cabinet with inch thick walls and two inch thick baffles, so you won't feel a thing even when crashing out the most bombastic soundtracks.
The brain of Arendal Sound subwoofers, the 1000W RMS Avalanche 1000DSP, are built around a Texas Instrument's 48-bit data path (with 28-bit filter coefficients) DSP engine, allowing virtually unlimited design flexibility with the assurance of no signal degradation along the way. Each amplifier's transfer function, power output limiting and thermal protection are monitored to the millisecond and are customized for each individual drive unit and cabinet combination. The high efficiency Class D amplifier modules are based on a proven topology that has been continuously refined over the past 4 years. Excelling in transient response, high current output and very low distortion, they deliver the necessities for highly accurate, deep bass with output capabilities that drives and controls each 13.8" woofer to its fullest potential.
https://www.arendalsound.eu/collections/subwoofers/products/1723-subwoofer-2
twani
Ben wel eens benieuwd, waarom verkoop je zoiets Hans?
Jij bent toch hét mannetje van de SUBerlatieven?
Gezien de opstelling wil ik vanuit esthetisch oogpunt 2 dezelfde subs hebben. En dan is 1700 euro te veel geld.
twani
Quote from: chansig on October  4, 2019, 20:36:56
Ahzo..... ;)
Voor de kick zou het wel magistraal zijn om 2 van deze subs naast mijn oren te hebben. :D
Vraagprijs is een vraagprijs. Wil je weten wat ik er voor wil hebben ? Vraag de prijs aan me.
Ralf67
Carloz
Leeuwarden
clicquot
die woofer zit op de "zijkant" - maakt dat eigenlijk uit hoe je die plaatste tov luisterplek (woofer naar voor gericht of zijkant) ??
dank voor info
In theorie zou het, volgens mij, niet uit mogen maken.
