BK XXLS 400 FF wit 425 euro
Started by chansig, April 17, 2019, 07:41:44
Specifications
System Type: Active System with Variable Freq bass filter and 50 Litre Sealed Enclosure
Frequency Response at -3dB:
In your front room -3dB lower than 20Hz !!!
Amplifier Input / Output Impedance: High Level 100K - Low Level 10K
Gain Control Range: 60dB
Drive Unit Impedance: 4 Ohm
Mains Input: 230V / 50Hz
Dimensions: 400D x 460H x 400W
Weight: 27.7kg
Automatisch aan/uit
Nagekeken door Jossie. En de versterker is helemaal oke.
425 ex verzenden en wordt ook niet verzonden.
Ralf67
