Author Topic: Optoma UHD40 4k home cinema projector reviews  (Read 24525 times)
Offline bartvv
  • eigenaar van KlankBart
  • HT forum donateur
  • full member
  • Trade Count: (0)
  • Total likes: 3
  • Gender: Male
  • Doe alles wat je doet met hart en ziel
    • KlankBart, distributeur van Thuisbioscoop apparatuur
« on: March 21, 2018, 22:00:52 »
De UHD40 is pas heel kort leverbaar, Projectorcentral heeft als eerste een mooie review online staan.
In de US heet deze HD50, en in Europa de UHD40.
"Among the new 4K UHD projectors using the 0.47" DLP chipset the Optoma UHD50 is uniquely impressive for several reasons. It has lens shift which the others do not, it has a noticeably deeper black level, and it has the lowest fan noise in the group.
In addition, there are no obvious flaws -- the picture is sharply focused from side to side and top to bottom, there are no hot spots or fading on the edges, and color balance is reasonably well-tuned right out of the box so you can fire it up and get into an enjoyable big screen experience without worrying about calibration if you don't want to.
Conclusion:
The Optoma UHD50 is unique among the new crop of inexpensive 4K UHD projectors featuring the 0.47" DKP chip as the one with the deepest black levels and lowest fan noise. A lot of folks will buy it simply for those two advantages alone. But beyond that its 1.3x zoom and modest lens shift will make it easier to install. It also has a shorter throw ratio than the competition--while the others require a 13' throw distance to hit a 120" diagonal screen, the UHD50 only needs 10.5'. So it may fit better into smaller rooms where space is a premium.
The shorter throw distance also makes placement on a low shelf between the seats a viable option that saves the cost and hassle of a ceiling mount. Beyond that, the Cinema color calibration right out of the box is reasonably well-balanced, enjoyable and easy to watch, so you can set it up and immerse yourself in your favorite movies with little muss or fuss. This combination of features makes it an excellent value for $1499.
This is not to say that the UHD50 is "best in class" in every aspect. The Viewsonic PX727-4K tends to have higher contrast and three-dimensionality within a given frame, and color saturation is deeper. It also appears incrementally sharper when they are placed side by side, although you need to see them side by side to tell the difference. The PX727-4K has a clarity, smoothness, and stability that the UHD50 cannot quite match. So the PX727-4K will appeal to the serious videophile despite the UHD50's advantages in black level, fan noise, and installation flexibility.
On the other hand, the Optoma UHD50 beats the PX727-4K on a number of parameters that many buyers consider constitutional. For many, getting the deepest black possible in images with a lot of black is paramount, and the UHD50 edges the PX727-4K on this count. Many are extremely sensitive to fan noise, and the UHD50 is the quieter of the two. Some say lack of lens shift is a deal-breaker, and the UHD50 has it while competing units do not. Clearly the shorter throw ratio of the UHD50 will be a decisive factor for some buyers.
On top of these obvious advantages, when you fire up the UHD50 it looks perfectly sharp with sufficient color saturation and contrast. Your reaction, if it is like mine when I first turned it on, will be "Wow, that's a great picture." So the Optoma UHD50 holds its own as a highly competitive offering in the low priced 4K projector horserace. If you pick one up, we are certain you'll feel your $1499 was money well spent. "
Lees de hele review hier: http://www.projectorcentral.com/Optoma-UHD50-review.htm?em
Distributeur van: Adeo projectieschermen, Barco residentieel, B&K, DVDO, Fortress bioscoopstoelen, Gefen, KanexPro, Optoma projectoren en schermen, OS Screen, Screen Excellence met geluiddoorlatend doek.
Offline reza
  • Jezus loves you!
  • Trade Count: (+4)
  • Total likes: 1060
  • Gender: Male
  • First i was blind, but now i see
Re: Optoma UHD40 4k home cinema projector reviews
« Reply #1 on: March 21, 2018, 22:07:40 »
Nerderlandse prijs?
Offline bartvv
  • HT forum donateur
  • full member
  • Trade Count: (0)
  • Total likes: 3
  • Gender: Male
« Reply #2 on: March 21, 2018, 22:23:20 »
De advies verkoopprijs van de UHD40 is 1499,- inclusief BTW.
En ik heb ze in voorraad.
Offline Zymotic
  • Administrator
  • Trade Count: (+14)
  • Total likes: 437
  • Gender: Male
« Reply #3 on: March 22, 2018, 08:21:28 »
Quote
CONCLUSIE
We hebben ervoor gekozen om niet langer stil te staan ​​bij deze Optoma UHD40 omdat we geloven dat het niet de commercialisatie waard is. We begrijpen niet wat logica fabrikanten ertoe aanzet apparaten van consumenten met dergelijke gebreken aan te bieden. Niet alleen gaf de nieuwe Optoma UHD40 ons de heldere halo van de nieuwe chip van Texas Instrument, maar het voegt een al even ondraaglijke geluidssizzle toe, irritante HDMI-synchronisatie-traagheid en laten we de vloeiendheid en contrast.
Tot slot en na onze tests zijn onze aanbevelingen eenvoudig en radicaal: houd uw geld en vermijd huidige of toekomstige declinatie van de nieuwe Texas Instruments 4-K-chip zolang het lichthalo-probleem niet is opgelost. We geven deze Optoma UHD40 een rode kaart PJHC.FR.
Wat een groot verschil in reviews. Of zit er ook veel verschil tussen de units?
Offline bartvv
  • HT forum donateur
  • full member
  • Trade Count: (0)
  • Total likes: 3
  • Gender: Male
« Reply #4 on: April 16, 2018, 22:27:45 »
Op Projectorcentral is een vergelijking beschreven tussen de UHD40 (die in de USA UHD50 heet) en de UHD60 projectoren.
"Is there is any visible difference in image sharpness? The answer is clearly no -- in practical terms you see exactly the same amount of image detail on both models. The fact that one projector's chip has a mirror matrix of 2716 x 1528 and the other a matrix of 1920 x 1080 (half the number of mirrors) has absolutely zero impact on the sharpness and detail in the image.
This does not mean the pictures look identical. There are other contributing factors on a projector that affect what you perceive as image sharpness. In this case digital noise is a factor - the lower the noise the cleaner and sharper the picture looks. And in this regard the UHD50 tends to edge the UHD60 with an overall lower noise factor.
In addition, one of the biggest factors influencing what you see as image detail and sharpess is contrast. In this case the UHD60 is higher in contrast than the UHD50, and in many scenes this contributes to the perception of it being the sharper of the two projectors. But at the end of the day, both the level of digital noise and the projector's contrast have more impact on one's perception of the sharpness and the ability to resolve detail on these two projectors than does the physical resolution of their chips, which is a non-issue."
http://www.projectorcentral.com/4k-projectors-defined.htm?page=Optoma-UHD60-vs-UHD50
Offline reza
  • Jezus loves you!
  • Trade Count: (+4)
  • Total likes: 1060
  • Gender: Male
« Reply #5 on: April 19, 2018, 18:59:15 »
Ik las ergens dat de UHD 51 en UHD 50 gelijk zijn, behalve dat de 51 Alexa aan boord heeft, maar dat klopt volgens mij niet?
De UHD 51 schijnt een enorm goede projector te zijn, een Epson 9300 killer!!
Ik zou deze wel heel graag ergens willen bekijken, waar kan ik dat op mijn gemakje doen?
Offline donaldk
  • Beyond The Elite Upper Class
  • Trade Count: (+2)
  • Total likes: 79
  • I love the HTforum
« Reply #6 on: April 21, 2018, 18:12:49 »
De Europese versie van de 51 heeft geen Alexa wel 3D, volgens Optoma.
Offline reza
  • Jezus loves you!
  • Trade Count: (+4)
  • Total likes: 1060
  • Gender: Male
« Reply #7 on: April 29, 2018, 11:48:09 »
Weet iemand waar ik de Uhd 51 kan zien spelen?
Al meerdere vragen gesteld via pm. Maar niemand reageerd?
Ik was serieus geīnteresseerd in deze projector maar dat is helaas alweer een stuk minder geworden..
« Last Edit: April 29, 2018, 21:30:04 by reza »
Offline angelo41
« Reply #8 on: April 29, 2018, 14:28:05 »
ook wel benieuwd om deze in aktie te zien. bij coolblue is ie nog niet leverbaar,staat op binnenkort.
Verstuurd vanaf mijn ONEPLUS A5010 met Tapatalk
Offline reza
  • Jezus loves you!
  • Trade Count: (+4)
  • Total likes: 1060
  • Gender: Male
« Reply #9 on: April 29, 2018, 21:30:50 »
Bij bol. Kan die besteld worden.
Offline angelo41
« Reply #10 on: April 29, 2018, 23:01:39 »
heb er dan overgekeken daar
Offline angelo41
« Reply #11 on: April 29, 2018, 23:03:24 »
de uhd60, maar niet de uhd51?
Offline reza
  • Jezus loves you!
  • Trade Count: (+4)
  • Total likes: 1060
  • Gender: Male
« Reply #12 on: April 30, 2018, 08:57:58 »
Volgens de site wel.
Offline angelo41
« Reply #13 on: April 30, 2018, 09:35:52 »
link?
Offline pillie123
« Reply #14 on: April 30, 2018, 11:20:13 »
Link naar niet forum sponsor verwijderd  LDFR
Mooie prijs voor een 4K en short throw beamer.
« Last Edit: April 30, 2018, 14:21:48 by Kjelt »
Samsung EU75NU8000, Arcam AVR390, Kef R3 , SVS SB3000 ,  HTPC  Streacom F12, VU+ 4K Zero,, Pioneer LX5090.
Offline angelo41
« Reply #15 on: April 30, 2018, 11:34:40 »
niet leverbaar.
Offline pillie123
« Reply #16 on: April 30, 2018, 12:52:52 »
Links naar niet forum sponsor verwijderd  LDFR
« Last Edit: April 30, 2018, 14:22:28 by Kjelt »
Offline Kjelt
  • HT forum donateur
  • Forever Addicted
  • Trade Count: (+12)
  • Total likes: 2662
  • I also love the HTforum
« Reply #17 on: April 30, 2018, 14:24:33 »
topic opgeschoond.
LEES DE FORUM REGELS
directe links naar niet sponsoren zijn niet toegestaan
Offline darkrunner
« Reply #18 on: April 30, 2018, 20:27:52 »
In hoeverre zijn die goedkope 4k dlp projectors nog interessant qua prijs nu de Epson 7300 onder de €1700 duikt?
Gemotoriseerde Horz/Vert lens shift en lens memory van de 7300 zijn toch onklopbaar onder de 2k lijkt me.
« Last Edit: April 30, 2018, 21:18:56 by darkrunner »
Offline angelo41
« Reply #19 on: May 20, 2018, 18:44:51 »
deleted.
« Last Edit: May 20, 2018, 18:53:26 by angelo41 »
Offline donaldk
  • Trade Count: (+2)
  • Total likes: 79
« Reply #20 on: May 20, 2018, 22:53:18 »
Almere, Zoeterwoude?
Offline reza
  • Jezus loves you!
  • Trade Count: (+4)
  • Total likes: 1060
  • Gender: Male
« Reply #21 on: May 20, 2018, 23:18:19 »
Waar?
Offline donaldk
  • Trade Count: (+2)
  • Total likes: 79
« Reply #22 on: May 21, 2018, 15:51:56 »
Īk neem aan dat je bij de Topic Starter terecht kunt, anders Jan-Willem Kantelberg en de zijne proberen bij Optoma Benelux.
Ik dacht altijd dat je meer naar het Oosten zat, maar lees net dat je hier in het Westen zit, anders forum sponsor Grobi.TV. Volgens Youtube video heeft die hem staan in donkere kamer.
« Last Edit: May 21, 2018, 15:56:19 by donaldk »
Offline angelo41
« Reply #23 on: May 21, 2018, 17:16:01 »
welk een zou aan te raden zijn? uhd51 of uhd550.
« Last Edit: May 21, 2018, 17:16:26 by angelo41 »
Offline darkrunner
« Reply #24 on: May 21, 2018, 18:13:43 »
Geen van beide...
