Simpleaudio Roomplayer Plus (nieuw) LMS/MPD/ROON/Airplay (3 stuks beschikbaar)
Started by pacific, November 29, 2017, 12:44:01
pacific
Beschrijving
Ik heb er 4 nieuw in doos beschikbaar. Zijn per stuk voor €299,00 inclusief de genoemde reloaded software. Nu mag deze weg voor €175,00 per stuk of €500,00 voor 3 stuks zonder software. Link geef ik je waar je deze kan bestellen.
For sale a brand new Roomplayer + with amplifier from Simpleaudio. Warranty is 3 months.
This is including Reloaded Software (€79,00) can also be sold without this software then reduce price with €79,00!
Simpleaudio is not developing they're software anymore. So to better use this very good product i included the Reloaded software. This software is developed in the Netherlands and fully supported. This software can also be sold separately for €79,00.
What is reloaded sofware
Why upgrade my Simple Audio device?
The original software of Simple Audio is basically rendere useless. Since the manufacturer has abandoned the product, apps can not anymore be downloaded, not for iOS, not for desktop. Especially for iOS this is a problem since it can't be installed anymore on new devices. On top of that, cover art is gone too.
What does Simple Audio Reloaded do?
Simple Audio Reloaded adds a series of functions and applications on top of the original Simple Audio software. This includes but is not limited to Squeezebox (including server), Airplay, DLNA and Roon. In addition, it adds a configuration interface to set it all up to your liking.
Where can Simple Audio Reloaded play music from?
Simple Audio Reloaded can play music stored from your network but also files stored on a USB drive attached to the player. Music services are supported via Squeezebox. At the moment that includes among others Spotify, Deezer and Tidal
Does Simple Audio Reloaded erase the old software?
Simple Audio Reloaded does not erase your software. It simply adds functionality. You could install the package and decide to keep running the original software
What does the Reloaded software support?
- Airplay
- Logitech Media Server
- MPD
- Squeezebox
- Syncrhonator
- Roonplayer
- Roomplayer original software
Simpleaudio Roomplayer + with amplifier
Never Multiroom Audio was simple: Transfer your digital music collection in every room
the house without loss of quality and extensive cabling to the multiroom system of Simple Audio.
- 24-bit High Definition Audio system signal transmission via circuit
- System features integrated Powerline adapter - low electromagnetic emission
- Control via computer or via iPhone® / iPod®
- Available with or without high-precision digital stereo power amplifier
- Peak Output Power: 50W / channel into 4 ohms
- RCA Line Input / -Output
- Additional line input on the front panel 3,5 mm jack)
- USB port for external storage media
- Headphone output
- Subwoofer Output
- Ethernet 10BaseT / 100 BaseT (RJ45 connector)
- Supports MP3, AIFF, FLAC, WAV, AAC (MPEG 4), Apple Lossless, 24 bit audio files up to 96 kHz
- Integrated Internet Radio (powered by TuneIn
- Supports music service WE7
- Dimensions: 50 (H) x 200 (W) x 200 (L) mm
- WEIGHT: 1,6 KG
- Material: Noble real glass surface on top quality anodized aluminum frame
High quality music.
Simple Audio offers the comfort of a multiroom music system, the distributed without complex installation digital music in excellent sound quality throughout the house. Everyone knows products that promise playback of digital music in CD quality. But the fact is that they reflect only low-resolution music files in MP3 quality. Simple Audio has the ability in your home music in studio quality 24-bit High Definition Sound play.
Multiroom
In the living room playing the most recent album of digital music library, while the playlist of an online music portal is streamed in the study of the favorite Internet radio stations and in the kitchen - the connection of a showroom player in each room makes it possible.
The network
Simple Audio products exclusively use the network that owns every home already: The main power grid. Per Powerline technology transform the showroom Player music in high-frequency digital signals and distribute them across the circuit. Thus provides each player Room Music from the socket. This makes the system completely dispensed with HDCP, SSID or IP addresses and to a wiring of the whole house.
The Powerline technology is evolving rapidly, as is due to the growing number of wireless network signals the need for an alternative solution in order to keep the amount of electromagnetic emissions low.
Easy access to digital music
You know the drill: Every computer in the house has its own music library with your own labeling, order and sorting. A merging of these collections would only cause confusion. Therefore, the Simple Audio System allows you to create as many individual music
pacific
Nog foto van de bovenkant  ;D
Rudi64
Nice..hier gaan heel wat mensen  blij mee zijn.
Heb een tijd terug de mijne verkocht omwille van dat deze niet meer ondersteund word.
Fijn spelertje met heel wat kwaliteiten!
Linn MDSM/2 ◼ Linn Majik Exaktbox I Katalyst.◼ Linn M109 speakers-◼ Linn K400 speakerkabels ◼BlueJeans 6a ethernet cables/ Iso Acoustics mini pucks.
pacific
Ja klopt heb er zelf 2 in gebruik bevalt goed bij mij als mpdclient.
Sent from my LG-H990 using Tapatalk
pacific
Deze zijn dus multifunctioneel inzetbaar en de software zit erbij en die kost al €79,00.
pacific
pacific
Moondance
Kun je het apparaat ook demonsteren? En ik neem aan dat het Roon-ready is, niet dat die software erbij zit.
HT: Denon AVR 4520 receiver, Samsung BDH 6500 BluRay, Apple TV 4K, Optoma 3D DLP projector, Projecta scherm 2.30 m. Front & rear speakers: Synthese Floating 2. Center: B&W HTM7. Rear center: B&W CDM CSE. Sub: Yamaha DXS12.
Stereo: Sphinx PJ10 amp, Cocktail Audio X40 streamer,
Pro-ject 2Xperience acryl TT, Denon DL110 element, Project Speed Box 2, Musical Fidelity M1Vinl phono pre-amp, Synthese Floating 1 speakers
Monster HTS 2600 netfilter (2 x) Buttkicker Concert LFE, Buttkicker
pacific
Quote from: Moondance on December 19, 2017, 22:21:44
Ja geen probleem hij kan getest worden. Ik gebruik hem zelf ook. Klopt Roon ready.
Moondance
En als de software apart wordt verkocht, hoe gaat dat updaten in z'n werk? Doe je dat zelf of kan de koper dat makkelijk zelf doen?
pacific
Quote from: Moondance on December 19, 2017, 22:58:31
Software kun je loskopen en kun je zelf installeren. Deze is zeer duidelijk beschreven.
pacific
pacific
pacific
pacific
pacific
Nu €199,00 zonder software en €269,00 met software.
Sent from my COL-L29 using Tapatalk
pacific
Actie prijs tot en met 10 augustus. €175,00 per stuk zonder software of alle drie samen voor €500,00
Dit is dus een goedkopen mogelijkheid om een Roonplayer te bezitten inclusief DAC en versterker.
Draai hier zelf ook mee op mijn slaapkamer met mooie monitor speakers en klinkt echt goed.
Gebruik dit zelf samen met Linn Kazoo app voor de aansturing en dat gaat zeer soepel.
pacific
pacific
pacific
3 stuks samen voor €450,00 dit is ook ideal als Roon endpoint. Let wel software moet nog loss gekocht worden. Per stuk €165,00
pacific
Niemand interesse in deze mooie all in one spelers?
pacific
Deze zijn nu €149,00 per stuk zonder de software welke je online kan bestellen of ik stuur de contactgegevens naar je door.
Bij afname alle 2 dan €425,00
