Sony VPL-VW760ES laser projector
Started by wrcveen, September 1, 2017, 11:40:07
wrcveen
Gisteren aangekondigd op de IFA Berlijn 2017, de Sony VPL-VW760ES laser projector.
Technical Specifications
Please be aware that the features/specifications can differ from country to country
Display System
Display System   4K SXRD panel, projection system
Display device
Size of effective display area   0.74" x 3
Number of pixels   26,542,080 (4096 x 2160 x 3) pixels
Projection lens
Focus   Powered
Zoom   Powered (Approx. x2.06)
Lens shift   Powered
Vertical: +85% -80% Horizontal: +/-31%
Light source
Light source   Laser diode
Screen size
Screen size   60" to 300" (1,524 mm to 7,620 mm)
Light output
Light output   2,000 lm
Colour light output
Colour light output   2,000 lm
Dynamic contrast
Dynamic contrast   ∞:1
Displayable scanning frequency
Horizontal   19 kHz to 72 kHz
Vertical   48 Hz to 92 Hz
Display resolution*1
Computer signal input   Maximum display resolution: 1920 x 1080 dots (HDMI Input only)
Video signal input   480/60p, 576/50p, 720/60p, 720/50p, 1080/60i, 1080/50i, 1080/60p, 1080/50p, 1080/24p, 3840 x 2160/24p, 3840 x 2160/25p, 3840 x 2160/30p, 3840 x 2160/50p, 3840 x 2160/60p, 4096 x 2160/24p, 4096 x 2160/25p, 4096 x 2160/30p, 4096 x 2160/50p, 4096 x 2160/60p
OSD language
OSD language   18-languages (English, Dutch, French, Italian, German, Spanish, Portuguese, Turkish, Polish, Russian, Swedish, Norwegian, Japanese, Simplified Chinese, Traditional Chinese, Korean, Thai, Arabic)
INPUT OUTPUT (Computer / Video / Control)
HDMI1 / HDMI2*2   Digital (RGB/Y Pb/Cb Pr/Cr)
Trigger   Minijack, DC 12 V Max. 100 mA
Remote   RS-232C, D-sub 9-pin (male)
LAN   RJ45, 10Base-T/100BASE-TX
IR IN   Mini Jack
USB   DC 5 V, Max. 500 mA
Acoustic noise
Acoustic noise   24 dB*3
Operating temperature / Operating humidity
Operating temperature / Operating humidity   5°C to 35°C (41°F to 95°F) / 35% to 85% (no condensation)
Storage temperature / Storage humidity
Storage temperature / Storage humidity   -20°C to +60°C (-4°F to +140°F) / 10% to 90% (no condensation)
Power requirements
Power requirements   AC 100 V to 240 V, 4.3 A to 1.8 A, 50/60Hz
Power consumption
Power consumption   430 W
Standby   0.4 W (when "Remote Start" is set to "Off")
Networked Standby   1.0W (LAN) (when "Remote Start" is set to "On")
When a LAN terminal is not connected, it becomes a low power consumption mode (0.5 W).
Standby Mode / Networked Standby Mode Activated
Standby Mode / Networked Standby Mode Activated   After about 10 Minutes
Dimensions (W x H x D) (without protrusions)
Dimensions (W x H x D) (without protrusions)   560 x 223 x 496 mm
22 1/16 x 8 25/32 x 19 17/32 inches
Mass
Mass   Approx. 20 kg / 44 lb
Supplied accessories
Supplied accessories   RM-PJ24 Remote Commander (1)
Size AA (R6) Manganese Batteries (2)
Lens Cap (1)
AC Power Cord (1)
Operating Instructions (CD-ROM) (1)
Quick Reference Manual (1)
Safety Regulations (1)
Notes
*1   Displayed image may be converted for some input signals.
*2   Both HDMI inputs are compatible with HDCP 2.2.
*3   This value is approximate. Depends on the projector setting condition and usage environment.
| Sony VW 760 | Cinemascope 380 cm | Apple TV 4K | Sony Playstation 5 | Anthem MRX 1120 7.2.4 | Revel W990 | Revel W893 | 2x JBL Synthesis S1S-EX |
wrcveen
Wat mij niet duidelijk is, kan deze 100% van alle kleuren in rec.2020 weergeven?
home@the movies
er is al een heel topic aan de gang hierover, maak het niet te ingewikkeld door er nog één extra te openen over dezelfde zaken.
Er is geen volledige weergave van P3 color space, maar wel een veel groter bereik dan REC709.
Sony heeft ervoor gekozen om geen P3 filter te gebruiken om geen lichtverlies te creëren in HDR.
wrcveen
Bedankt voor je reply.  Andere topic is juist te algemeen over verschillende projectors van Sony vind ik.
home@the movies
Quote from: wrcveen on September  1, 2017, 12:08:05
Daar heb je ook een punt ;-)
wrcveen
#5
Ik zie deze projector wel als upgrade van mijn JVC RS400 / X500.
De JVC geeft 1700 lumen en is gecalibreerd met het HDR REC.2020 profiel. Van calibreren heb ik totaal geen verstand maar las dat als deze Sony laser gecalibreerd wordt er maar 1600 lumen van de 2000 overblijven? Geeft mijn JVC ook minder lumen, is de Sony wel een upgrade?
raindog
Natuurlijk is deze Sony een upgrade tov. de X500 als het gaat om de nieuwste technieken: 4k, HDR, laserlamp etc.  Maar hij speelt ook in een hele andere prijsklasse en je hoeft volgens mij niet zo ver te kijken om een significante upgrade te kunnen maken. Misschien helpt het om jezelf af te vragen waarom je zou willen upgraden. Wat mis je nu aan de X500 of zou je verbeterd willen zien?
Wil je meer licht output?
Wil je een hoger (native) contrast?
Wil je een dieper zwartniveau?
Wil je meer scherpte?
Wil je een mooiere motion?
Wil je native 4K?
Wil je per sé een laserlamp?
Ik ben zelf wel erg benieuwd naar het plaatje wat deze 760 neer zet, met name in vergelijking met de 360.
home@the movies
Quote from: wrcveen on September  5, 2017, 09:24:49
Nog niemand heeft de Sony effectief kunnen meten en Calibreren dus hoeveel licht er al dan niet overblijft is nog een open vraag.
De JVC heeft 1700 lumen de Sony 2000, ook je JVC moet een stuk licht inboeten na calibratie, zeker in de HDR 2020 stand.
Sony gebruikt geen filter om hun grotere color space te maken (wel niet zo groot als die van de JVC).
Geef ons nog twee weken en dan hebben we het toestel bij ons (wel nog een pre productiemodel) pas dan kunnen we al iets meer vertellen over de juiste prestaties na calibratie enz.
Gr
Werner
wrcveen
Quote from: raindog on September  5, 2017, 10:27:04
Wil je native 4K?
Meer licht, projecteer op een 3,80 meter breed CinemaScope scherm. Maar wat mij het meest irriteert aan de JVC is de 20 seconden HDMI handshake. Voor de rest tevreden. Laserlamp niet per se nodig. Maar absoluut geen DLP techniek zoals de niet Sony's en JVC's.
wrcveen
Quote from: home@the movies on September  5, 2017, 11:56:34
Gr
Werner
Ik ben erg benieuwd [emoji2]
raindog
Quote from: wrcveen on September  5, 2017, 12:32:09
Aha, ja op 3.80 breed kan ik me voorstellen dat je meer licht wil...  :blush: Damn, dat is een flinke breedte.
Robbo
Gr
Werner
Kun je uitleggen waarom er in HDR minder licht overblijft ?
home@the movies
Er zijn eigenlijk meerdere zaken maar dit zijn de belangrijke;
Enerzijds het feit dat de HDR/UHD films op een heel andere helderheid op disc zijn gezet dan HD waardoor de projector veel meer licht nodig heeft om dit te kunnen weergeven.
Anderzijds ook afhankelijk van op welke manier er een grotere color space wordt gebruikt. Vaak is dit door gebruik van een filter waardoor er makkelijk 20 to zelfs 30% lichtverlies kan optreden tov een standaard HD color space of eentje die niet met en filter gemaakt wordt maar dan niet zo groot is.
HDR gebruikt ook een totaal andere gamma curve waarbij de lagere partijen veel langer in het zwart blijven om daar meer definitie in te kunnen brengen.
Robbo
OK dank je.  Ik kom het de 20e wel eens bekijken  :)
home@the movies
Quote from: Robbo on September  5, 2017, 15:58:50
Dat zegt 1000 keer meer dan woorden  ;D ;D
N1v3K
home@the movies
#16
Maandag verwachten we de eerste levering van 6 toestellen, er gaan een paar klanten zeer gelukkig zijn tijdens de komende feestdagen  ;D ;D ;D ;D.
Noteer het weekend van 16 en 17 December in jullie agenda want dan organiseren we alweer een demo sessie(shoot out) met deze fantastische projector, samen met de JVC en de andere sony's.
eddy135
Quote from: home@the movies on December  1, 2017, 18:59:26
Noteer het weekend van 15 en 16 November in jullie agenda want dan organiseren we alweer een demo sessie(shoot out) met deze fantastische projector, samen met de JVC en de andere sony's.
Daar ben je wel heeel vroeg mee: 15 en 16 november vallen pas in 2025 weer in een weekend... :clapping:
HALF WERK IS EEN GOED BEGIN
Zelfde hier, maandag komen ze binnen :D
Review later op maandag of dinsdag.
home@the movies
Quote from: eddy135 on December  1, 2017, 19:04:09
Aangepast, 16 en 17 dus, dank voor het opmerken  ;)
Quote from: home@the movies on December  1, 2017, 19:50:19
;D Werner kijk er nog eens goed naar, november is pas volgend jaar weer  ;)
eddy135
En dat dan in december natuurlijk.. :)
home@the movies
#22
Quote from: Kjelt on December  1, 2017, 20:06:22
Ohh man man, ik ben echt een compleet warhoofd, ik leef duidelijk in een andere tijdzone, back to the future 4 of zo  ;D ;D
broodro0ster
Super! Wanneer kunnen we inschrijven :D
HT: Dolby Atmos 7.2.2 | NAD T758 V3 (Full Dirac), KEF R700, KEF R600c, 4x KEF R300, BA A25 atmos, 2x SVS PB-2000
Sony HW55es isf, Kingpin VFS-240, Shield TV
Living: LG 77G2, Boston Acoustics A25, Denon X-2000, Shield TV
home@the movies
Quote from: broodro0ster on December  4, 2017, 08:58:40
We hebben de datum geprikt op Zondag, voor de geïnteresseerden gaan we ook een audio demo doen met de Arcam en Dirac live software.
Juiste uur, meer info en inschrijvingen komen er vandaag of morgen aan, ik zet het wel op de event pagina.
Gr
Werner
