Zidoo X9S Review
Started by skank1, October 2, 2016, 20:01:23
skank1
Ik heb ze beide ja, de zidoo wint voor mij!
Waarom omdat de himedia een microstutter heeft met 3d iso (niet iedereen heeft er veel last van , maar ik zie ze, het is er) , plus de migratie van de externe speler is beter bij zidoo...
Dus. Absoluut zidoo kiezen!
renzo4000
Oké, thanks... Heb de x9s besteld, hopelijk morgen in huis. Ik ben benieuwd ;)
skank1
Version 1.2.7 of Zidoo X9S
Updatelist:
System:
1,A download tool aria2 added in OpenWrt system.
2,The brightness of VFD can be adjusted now in the setting of system.VFD stands for vacuum fluorescent display which is in the front panel.
3,3D library of skia been improved,subsequently scores of Antutu exceed 40000.
4,Green screen appears occasionally when play 3D movie, this issue has been fixed.
5,RAW out of sync when play some TrueHD and DTSHD HRA movies, this issue has been fixed.
6,After HDR playback exit,HDR status don't back to normal status, this issue has been fixed.
7,The setting of Force downmix audio can't be saved after restart the box,this issue has been fixed.
8,Optimized audio option.If the settings is RAW and playing AAC audio,The audio output will be temporarily auto changed to PCM
9,Enable the statusbar
Launcher:
1,More tips added in the desktop interface.
2,The mouse cursor style changed into a better one.
Player:
1,The offset of subtitle will only valid for once.
2,AutoFrameswitch added 30fps and 60fps.
3,If the movie is paused,press the menu key will not resume the playback.
4,When searching the subtitles,the system will make it a priority to search the subtitles in default subtitle language setted in system advanced settings.The lower priority is system language.The lowest is English.
5,Removed Force SD audio setting.
6,Removed the auto-identify of MKV's MVC.(We now rewriting this part)
7,Bookmarking function is open as default.
8,Press OK to play from the beginning when resuming playback from bookmark.
9,3D playback tips added.
Filemanager:
1,Immediately sync after copy or delete.
2,A button to return to top added.
3,A wrong error report when add&remove the directory in Russian language fixed.
Full_OTA_Package:
Mediafire mirror
Amazon mirror
MD5:92e75f35a30dac901cdb41058a4dddf6
How to upgrade
This version will be test in forum for a week,then push it for OTA upgrade via online.
About ZIDOO X8,will release new version tomorrow
Enjoy!
skank1
Quote from: renzo4000 on November 23, 2016, 13:52:40
Top! Ga je geen spijt v hebben!
Paul-Karacsony
Gelukkig heb ik nu wel 5.1 geluid via mijn versterker. Helaas niet overal. Zelfs de IPTV werk goed. Ben er dus tevreden over. Vraagje. Hoe kan ik you-tube installeren?
tdbakker
Via de playstore.
Heb ik ook gedaan maar hij speelt geen filmpjes af,en dat heb ik met een andere app net zo.
De filmpjes blijven laden???
Stereo:Xanadu HRS22YH//Cambridge Audio Edge NQ en W//Roon.
HT:Anthem MRX520//Rythmik E15//Xanadu Center HRC1 en Xanadu Rears//Sony KD-65AF8//Zidoo Z1000
Paul-Karacsony
Dat is wel heel jammer. Want het zou graag ook filmpjes willen kijken op you-tube. Dan zal fb ook wel niet lukken en skype
tdbakker
Ik denk dat er iets verkeerd staat er bij mij ?moet ik nog even uitzoeken.
Misschien doet hij het bij jou wel goed?
Zal je even moeten proberen.
skank1
renzo4000
Inmiddels mijn x9s binnen en wat testjes gedaan en lijkt tot op heden prima te functioneren. Echter heb ik wel een nieuw "probleem" ... mijn onkyo 616 doet geen 4k passthrough :( ... ik dacht van wel maar hij kan alleen maar upscalen naar 4k. Maximale bron input is echter 1080p  :(. Direct aansluiten op de tv lost dat op, maar dan ben ik alle hoge HD audio streams weer kwijt. Misschien toch maar de receiver upgraden dan maar  :P
Paul-Karacsony
Ik ben benieuwd of je nu ook films kan kijken met seroen 5.1 geluid
renzo4000
Seroen weet ik niet, maar surround gaat wel lukken hoor ;)
Paul-Karacsony
ha ha Dat was een typefout  ;D Ik heb helaas maar 1 X met mijn ITPV suround ontvangen. Maar met het kijken van films nog niet. Ik zou mijn god niet weten hoe ik dat moet instellen. Ik weet niet waar je woont. Anders zou ik dolgraag een keer willen komen voor uitleg. En dat jullie kunnen kijken of de instelling wel goed zijn. Ik woon zelf in Eindhoven
renzo4000
http://forum.kodi.tv/showthread.php?tid=291943
In de eerste post staan screenshots, ook met de instellingen.
Paul-Karacsony
Heel erg bedankt. Ik zal het snel een keer gaan doorlopen. Maar kijk jij via movies de films? Of via andere mogelijkheden
gsuk
Even een leek vraag
Waarom zou ik deze nemen inplaats van een Nvidia shield?
Eigelijk wil ik gewoon plug & play
Geen ervaring met  kodi!!
Kijk op een pioneer kuro full HD 10i0p 60 inch
En Anthem receiver 5.1
Dus geen 3d of 4k
Gewoon oldskool dus
En een Hdi dune base en externe server op windows (ict streaming server)
Apple TV voor netflix
En Chromecast voor moto GP via mijn Android smartphone
Alvast bedankt
Verstuurd vanaf mijn SM-G935F met Tapatalk
Woonkamer: | pioneer 608xd plasma | panasonic DMP BD30 blu-ray | Onkyo TX-NR905 avreceiver | B&W DM602 s3 front | B&W DM303 rear | B&W LCR600s3 center |                                                               | Velodyne CHT-12R subwoofer | sony X55ES  cd | HDI Dune Base 3.0 media player | humax IHDR-5200C hd decoder | sonos 120 | logitech harmony one |
Slaapkamer: | pioneer 428xd plasma | HDI Dune Smart b1 media player | HUMAX IRHD-5100C hd decoder |
kantoor:       | Audio Engine
renzo4000
Op basis van je eisen hoeven beiden niet eens, maar kijk eens hier: http://forum.kodi.tv/showthread.php?tid=252916
gsuk
#42
Quote from: gsuk on November 30, 2016, 08:58:49
Even een leek vraag
Dus geen 3d of 4k
Gewoon oldskool dus
Alvast bedankt
gsuk
#43
Daar zie ik door de bomen het bos niet meer!!
Het wordt een toevoeging niet een vervanging
Alle bekende geluid sporen ondersteunen
Van dolby - dolby hd
Van dts - dts master audio
En bijvoorbeeld een mkv maar  ook een blu-ray afspelen
Ik gebruik een harmony 950 ab
En heb een harmony van ziggo
En het moet ook redelijk makkelijk te bedienen zijn voor mijn vriendin en ook een beetje voor mijn zelf
renzo4000
Beide apparaten zullen voldoen, maar neem even tijd om dat topic te lezen en dan je keus te maken. Mijn ervaring is met de x9s erg goed en zal meer dan aan je verwachtingen voldoen.
skank1
Even een leek vraag
Dus geen 3d of 4k
Gewoon oldskool dus
Alvast bedankt
Een shield en je apple tv wegdoen, kan je met shield ook
Mogelijks je chromecast ook weg
le mans
Mooi revue :clapping:
is de firmware ook via de kabel te updaten en is er enige feedback? Forum?
En is er een interne scraper, die mn nieuwe content via Pc automatisch voorziet van info, trailers hoesjes enz?
twijfel nu helemaal tussen deze en Himedia
gsuk
Quote from: skank1 on December  2, 2016, 16:32:17
Ik heb inmiddels een ziddoo
Weg doen van de Apple tv en Chromecast  kan altijd nog.
skank1
Quote from: le mans on December  2, 2016, 16:53:10
is de firmware ook via de kabel te updaten en is er enige feedback? Forum? Ja en ja
Ja geen pc nodig
road rebel
#49
Goede vraag, ik kan geen reden bedenken.  :D
Quote
Plug and Play en Kodi in een zin kan niet. Maar moeilijk is het niet; er zijn honderden tutorials en fora die je kunnen helpen.
Quote
Dus geen 3d of 4k
Gewoon oldskool dus
maakt niet uit
Quote
Met een Shield TV (=Android TV) heb je op 1 toetsel een DLNA ontvanger (indien je liever jouw windows server blijft gebruiken), een 4K HDR netflix client en een chromecast ontvanger. Maar je kan ook MotoGP rechtstreeks op de Shield kijken zonder jouw smartphone te moeten starten (Shield is nl. ook Android).
