Het Pass Labs topic
Started by YamahaRXV, October 20, 2014, 00:01:43
YamahaRXV
Een topic gewijd aan Pass Labs door liefhebbers en voor liefhebbers die hier hun ervaringen, wetenswaardigheden, en interesse betreffende dit mooie karakteristieke door Nelson Pass opgerichte merk kunnen plaatsen.
Ondanks de niet in grote getale aanwezige Pass Labs eigenaren hier op het ht forum hoop ik toch dat hier de nodige Pass Labs gerelateerde posts geplaatst gaan worden want dat verdient dit merk toch zeker wel.
Een topic is geen topic zonder de nodige (basis)informatie en foto,s , dus daarom als aanvang van dit topic alvast wat leesvoer over Nelson Pass en zijn creaties.
About Pass
Pass Laboratories, Inc. was founded in 1991 by Nelson Pass.  Operating out of his shop at home, Pass developed prototypes of a single-ended Class A amplifier design.  At the same time, he and Mike Burley were constructing an in-house machine shop with three home-built CNC milling machines with which to produce the amplifiers when the design was finished.
The first product, the Aleph 0, shipped in 1992.  It was a mono-block design rated at 70 watts into 8 ohms, and was unique in using three gain stages of power Mosfets including a push-pull output stage biased by a big constant current source.  The amplifier operated as single-ended Class A up to its 70 watt rating and in push pull Class A at higher wattage.
The amplifier was highly acclaimed, and was called the "Amplifier of the Decade" in Sterephile magazine.
At this time, Nelson hired his next-door neighbor, Elena Tong, to help with producing the amplifiers, and she manages much of the company to this day.
A stereo version called the Aleph 0s followed after, along with a preamp called the Aleph P.  A larger version of the Aleph 0 called the Aleph 1 shipped the following year, and was a mono-block rated at 150 watts.
In 1994 Pass Labs released a newer Aleph design which simplified the circuit from three gain stages down to only two stages and used a newly patented power current source to bias the single-ended output stage.  The new circuitry was incorporated into a revision of the Aleph 1, the 200 watt Aleph 1.2, and smaller models, the 100 watt Aleph 2.
In 1994 Nelson was joined by Wayne Colburn, who began working on improved version of the preamp and on a new phono stage.  The company received two patents this year, one of them the design that became the SuperSymmetric circuit in use today.
In 1995, the 30 watt Aleph 3 and Aleph L preamp were released.  Also in 1995 the Joseph Sammut left his position at Krell and became operations chief at Pass labs.  The following year he was followed by designer Desmond Harrington.
In 1997 Wayne Colburn's efforts bore fruit in the revised Aleph P, the Aleph Ono phono stage, and the D1 digital to analog converter.
By 1995 the company had outgrown Nelson's buildings, and building was begun in a new location.  In 1997 Pass Labs moved out of Nelson's shop space and into a new facility in Foresthill.  By then, even more space was needed, and was leased for storage elsewhere.  Nelson's original shop continues to house research.
In 1998 the company released the X1000, the first amplifier using the patented SuperSymmetric topology.  The X1000 achieved 1000 watts with high performance, local feedback and only two gain stages:  a cascoded differential pair of transistors and a large bank of complementary output followers.  This ground breaking design has formed the amplifier products from Pass Labs to the present day.
The X1000 also introduced Desmond Harrington's signature mechanical design work.  The X1000 was followed by the mono-block X600, the stereo X350, and the stereo X250 and X150 models.
In 1998 and 1999, Wayne's preamplifiers X0, X1, and Xono were released, and Joe Sammut became the President of Pass Labs, freeing Nelson to devote all his time to product.
In 2001 Pass Labs shipped the XVR1 active crossover and X2.5 preamplifier.
In 2002 the first XA amplifiers were released, combining the X and Aleph topologies into balanced single-ended Class A amplifiers with many of the characteristics of both the X and Aleph series.  The XA200 was rated at 200 watts mono, the XA160 was 160 watts.
In 2003 the company produced the X150.5, the first major improvement of the X150 amplifier, and followed it with ".5" revisions to the other X amplifiers through 2003 and 2005.
In 2007 Pass Labs is applying the ".5" advances to the XA series of amplifiers, with the XA100.5, XA60.6, and XA30.5 shipping as of this writing.  These revisions dramatically lower distortion and noise and also dramatically improved the performance of the amplifiers into low impedance loads.
Also in 2007, Desmond Harrington assumed responsibility as President of the company.  Nelson and Wayne continue development work, Joe manages sales and marketing, and Elena and Kent English manage the rest of the company.  All these people still like each other, and sit in the same office everyday.  This way they can all can hear everything that's going on, laughing about most of it.
Bron: Pass Labs
Pass Labs versterkers kenmerken zich door de interne minimalistische opbouw van componenten, een behuizing voorzien van een schitterende gefreesde dikke aluminium frontplaat (niet alleen voor het optische aspect, maar ook voor het functionele) en gebouwd als een tank.
Klankmatig gezien enorm stabiel, krachtig met veel autoriteit en controle, en een heerlijke organische en ietwat buizenachtige sound met veel glans en hoorbare nadruk op weergave van instrumenten en melodielijnen.
Wat plaatjes van o.a. de eerste Pass versterkers waar het Pass avontuur mee begon (Aleph en de First Watt) en de meer recente en m.i. prachtige juweeltjes  :inlove:
Deleted Member 2
Dan ook maar gelijk de top van de door Pass Labs leverbare phono versterkers, de XP25:
€ 11.500
YamahaRXV
Quote from: Onder013 on October 20, 2014, 00:22:42
Kijk, zo gaan we goed van start  :clapping:
Prachtige phono versterker Henk  :inlove:
Deleted Member 2
Er zijn zelfs luidsprekers van Pass Labs:
Wist ik niet eerder
YamahaRXV
Quote from: Onder013 on October 20, 2014, 00:36:36
Wist ik niet eerder
Klopt ja, maar heb ik (bewust niet) vermeld omdat Pass Labs met name bekend staat om zijn versterkers  ;)
Bijzonder.
Zo prachtig als ik de versterkers van PL vind qua uiterlijk. Zo verschrikkelijk als ik de speakers vind :P
Een merk waar ik inhoudelijk niets van kan zeggen. Maar qua looks helemaal mijn ding :inlove:
Zouden er mensen zijn die hier een 7.1 setje van hebben staan?
twani
Een mooie verzorgde "intro-post" Jan, prima👍
twani
Iedere keer als ik een foto zie van Nelson moet ik altijd steevast aan deze man denken.....
David Crosby.......   Zelfde kapper ook :colgate:
gerzom
Helemaal leuk hier !!
Trouwens, vanaf deze maand is ook de Xs Pre-amp leverbaar ($38.0000  :crazy: ) past wel goed bij een set Xs-300's en ze werken aan een Xs phono.
Valkyrie
Ik vind het echt juweeltjes om te zien!! :wub:
sultankat
Ik moet niet teveel in dit topic kijken. Merk nu al spntaan kriebels met de vraag hoe dat zou klinken op mijn SF's...............Prachtig die merken met een historie en baanbrekende techniek in audioland.
Quad Artera Play Plus + Quad Elite QMP mono's | NAD PP2e Phono preamp | Thorens TD147 + Ortofon OMB 20 | Audizio tuner | Innuos ZEN mini MK3 streamer +  Innuos voeding | Meze Audio 99 Classics | Tannoy D700 speakers | Wireworld Mini Eclipse 8 speakerkabels |  | Van den Hul Digicoupler | Ansuz digital cables | Shunyata power cables | Vibex powerblock
twani
Quote from: sultankat on October 20, 2014, 09:22:13
Je weet toch dat je zélf een Accuphase E460 in je "sig" hebt staan hé? :tounge2:
Lijkt me niet heel veel beter te kunnen. Anders misschien wel, maar beter?
WickedGame
Erg gaaf topic! Heb een keer een set B&W 800D's op een Pass Labs X350.5 gehoord en dat klonk echt waanzinnig! Als ik ooit Classé wil gaan inruilen op iets anders is Pass wel een kanshebber. Enige puntje wat ik Pass altijd heb gevonden is de VV's die ik niet zo heel mooi vind. Maar ja dat is puur smaak :D
scrutinizer
Quote from: twani on October 20, 2014, 07:33:41
Ondanks Nelson een aardige vent is, hoor ik Crosby toch liever.....
.....en die is, net als Bas in zijn zoektocht, besluiteloos.....and almost cut his hair
scrutinizer
Quote from: YamahaRXV on October 20, 2014, 00:01:43
Mijn interesse en beleving ligt toch meer "by the real gems " het prille begin Aleph o en 1 ;)
Kwabbernoot
Vreemd dat in de openingspost Threshold en Nakamichi niet genoemd worden.
Waar ik toch wel een beetje verlekkerd naar zit te gluren zo af en toe zijn de XA30.5 of XA30.8 eindversterkers.
Maar dan de 30.8 dus.
Ook interessant vind ik de INT30A.
Het zal waarschijnlijk wel altijd bij dromen blijven, ben ik bang.
Groeten...
Raymond187
De looks  :inlove:
Zal vast erg mooi klinken.
Pre amp van 38k....zal daar zoveel verschl in zitten met 1 van 10k? Of is dat alleen voor die het denken te horen?
sultankat
Quote from: twani on October 20, 2014, 09:26:11
;) ;D Je hebt gelijk. Is ook subliem.
sultankat
Quote from: Kwabbernoot on October 20, 2014, 15:12:50
Zeker! En Nakamichi is zo'n merk dat ook wel een apart topic verdient. Alleen is het echte Nakamichi helaas ter ziele. Heb nog steeds zeer goede herinneringen aan mijn eerste cd speler: de Nakamichi OMS 4E die ik in '89 kocht.
De versterkers van Nak uit die tijd hadden veel Stasis techniek van Threshold.  De PA-5 en PA-7 van deze serie zijn nog steeds zeer gewild. Maar de verhouding tussen Nakamichi en Nelson Pass was op z'n zachtst gezegd onderkoeld omdat vlgs Pass zijn ontwerp verkeerd werd gebouwd door Nakamichi.
YamahaRXV
Threshold had ik idd. ook nog even moeten noemen, maar helaas vergeten te vermelden  ???
De beste man heeft ook in korte tijd zo bizar veel indrukwekkende projecten gedaan op versterkergebied...
Met Nakamichi was het meer een zakelijke samenwerking over het toepassen, of beter gezegd het verkopen van de rechten van het Threshold principe aan Nakamichi  ;)
Erg mooi ook klankmatig, heb voordat ik definitief de keuze had gemaakt voor de Int 150 ook nog aan de Int.30 A zitten denken, maar heb toch de keuze gemaakt voor de Int. 150 omdat deze toch wat meer kracht en slam laat horen en in het laag strakker klinkend is  ;)
gerzom
Gisteravond een vraag gesteld aan Pass Labs, kreeg net een email terug van Desmond Harrington (President Pass Labs).
Toch leuk dat hij zelf emails beantwoord en nog snel ook (en hij vindt de combi XA60.5 met SF een erg geslaagde  ;D )
Ik had op een ander forum al gelezen dat ze bij Pass allemaal erg toegankelijk zijn.
Nog 4 nachten...................
en dan
Kwabbernoot
Zo! Mooi zeg. Gekocht of op proef?
Groeten...
gerzom
Quote from: Kwabbernoot on October 20, 2014, 22:43:51
Groeten...
Gekocht, vrijdag ophalen  ;D
Kwabbernoot
Gaaf. Gefeliciteerd.  :pompom:
Groeten...
