Yippie
Author Topic: Het Schiit topic  (Read 80182 times)
Offline gerzom
Re: Het Schiit topic
« Reply #50 on: October 12, 2013, 17:24:34 »
 :pompom:
Was Ragnarok geen geintegreerde versterker?
Erwin B
RAGNAROK:
"Ragnarok is the world’s first universal amplifier, fully capable of powering everything from ultra-sensitive IEMs to loudspeakers. With 100WPC RMS into 4 ohms, 3 selectable gains, a relay-switched stepped attenuator volume control, and Crossfet™ circlotron-style output topology, Ragnarok befits its name—in Norse legend, Ragnarok was the “end of the world.”
Power Output: 100W into 4 ohms, 60W into 8 ohms, 15W into 32 ohms, 9.6W into 50 ohms, 1.6W into 300 ohms, 800mW into 600 ohms
Inputs: 2 balanced, 3 single-ended stereo inputs
Outputs: speaker terminals, 4-pin balanced XLR headphone, TRS unbalanced headphone, balanced and unbalanced preamp outs
Gain: selectable gain of 20, 7, or 1
Volume: (64) 1.25dB steps via relay-switched stepped attenuator
Topology: Fully discrete Crossfet™ circlotron-style stage with no caps in the signal path and no DC servos, all solid state
Management: microprocessor control of quiescent current and DC levels, with monitoring of all fault conditions
Power Supply: 400VA transformer with 4 separate circlotron output rails, over 100,000uF filter capacitance total
Size & Weight: 16 x 12 x 3.875”, 30 lbs
Estimated Price & Availability: $1400-1600, late 2013"
Offline AbZ
« Reply #51 on: October 12, 2013, 18:06:11 »
Ja.  Output voor luidsprekers is echter vrij beperkt.
Geen idee wat dit is:  Crossfet™ circlotron-style stage
Offline Oud lid
« Reply #52 on: October 12, 2013, 18:20:51 »
:pompom:
RAGNAROK:
Nou, the world’s first universal amplifier... Heeft hij digitale ingangen? Phonostage?
Erwin B
Offline gerzom
« Reply #53 on: October 12, 2013, 18:50:05 »
Unique, Simple Crossfet™ Topology
Mjolnir is the only dedicated headphone amp using a Circlotron-style, or cross-shunt push-pull topology. This Crossfet™ topology allows us to use only N-channel MOSFETs, for better matching and lower distortion. It also significantly simplifies the output stage.
Geen idee wat het nu echt is/doet. Klinkt wel mega indrukwekkend  ;D
« Last Edit: October 12, 2013, 19:08:30 by gerzom »
Offline gerzom
« Reply #54 on: October 14, 2013, 13:16:51 »
Ik heb mijn Schiit-collectie ook weer uitgebreid, ik ben sinds vorige week de trotse eigenaar van Asgard 2 hoofdtelefoon versterker.
Ik heb nog niet echt de tijd gehad om te gaan zitten en er uitgebreid naar te gaan luisteren, maar de eerste (snelle) indruk is dat het vele, vele malen beter klinkt dan mijn Grado direct aangesloten op mijn iPad. Vanavond maar eens goed ervoor gaan zitten en flink luisteren.  :music:
Ik heb mijn Asgard 2 direct aangesloten aan mijn Gungnir omdat mijn 2 bronnen (cd-speler en Spotify) alle 2 via mijn Gungnir lopen.
Ook voor dit ding geldt weer dat hij zeer degelijk gebouwd is.
Offline Sonority audio
  • HT forum sponsor
  • senior member
  • Trade Count: (0)
  • Total likes: 0
  • Gender: Male
« Reply #55 on: October 15, 2013, 10:24:12 »
Helaas nog geen nieuws over de nieuwe DAC.
SCHIIT YGGDRASIL DAC:
"Yggdrasil is the ultimate expression of Schiit’s bitperfect approach, and the antithesis of noise-shaping DACs and technologies such as DSD. With proprietary technology from input stage to clock regeneration to digital filter to D/A conversion and analog output stage, Yggdrasil (the world tree in Norse legend, and the source of all things) resets the bar for DACs.
Inputs: USB, Toslink, Coax, BNC, AES/EBU
Outputs: balanced XLR and single-ended RCA
Clock Regeneration: proprietary Adapticlock topology with analysis of quality of incoming datastream, as well as VCO and VCXO reclocking
Phase Inversion: selectable via front panel button
Digital Filter: proprietary Schiit closed-form bitperfect digital filter based on <REDACTED>
D/A Conversion: proprietary fully differential configuration based on <REDACTED>
Analog Stage: proprietary Schiit Pivot-Point differential current-feedback topology, fully discrete, with ultra-low-noise JFET and bipolar devices
Power Supply: 4 choke-input, shunt-regulated supplies feeding 20+ stages of discrete and integrated local regulation
Availability: early 2014"
Quote
thanks for your patience in waiting for these products. We know, we’re insanely late. We can blame lots of things for that, like platforms going end-of-life, and having to deal with DSD, and discoveries we made as we developed the statement gear. We can also blame our desire to improve these products, add performance, add features, etc. We can also blame field agents from alternate universes that have been scoping out our technology for their plans to take over our world. But that’s bullshit. Or a TV show. The reality is, these products are complicated. They take a lot of time to develop. And we want to get them right. When they’re available, the skies will open, beautiful music will stream down, and your life will never be the same again. No, wait, that’s also bullshit. In any case, thanks again for your patience. We can say these are the highest-end products we expect to develop—there will be no “super statements” coming. So sit back, relax, and enjoy what you’re listening to!
Quote
Here-to-for, it was deemed not possible to utilize an integrated circuit based DAC without implementation of some filtering which is required due to aliasing. Aliasing is frequency based distortion will affect everything in the audio band above ~ 10 kHz. (see the link for a graphic depiction of what aliasing is http://en.wikipedia.org/wiki/Aliasing) Supposedly even the best DAC’s made have to add filtering, which will always be degrading to some extent of the original signal, in order to cope with aliasing.
Jason has hinted that the new Yddrasil DAC will implore “true closed-form digital filters”. If I understand this correctly, this means Schiit has created a way to eliminate upsampling & filtering effects in the Digital to analogue process. This could be a revolutionary event in the evolution of digital music.
Schiit audio : www.schiit-europe.com
Ludic Audio Cables :new Affordable standards
Mrspeakers: www.mrspeakers-europe.com
Soundaware streamers : www.soundaware-europe.com
Offline Oud lid
« Reply #56 on: October 15, 2013, 10:50:54 »
Is die versterker al leverbaar? De Ragnarok.
Erwin B
Offline gerzom
« Reply #57 on: October 15, 2013, 11:06:21 »
Mijn huidig hoopje Schiit:
http://i194.photobucket.com/albums/z243/gerzom/IMG-20131015-00331_zps873c69d4.jpg
Het Schiit topic
 :music:
  • HT forum sponsor
  • senior member
  • Trade Count: (0)
  • Total likes: 0
  • Gender: Male
« Reply #58 on: October 15, 2013, 11:23:57 »
Erwin B
Die is nog niet leverbaar,verwachting is December.
Dit is trouwens een prototype,looks zullen wel zo ongeveer blijven vermoed ik,alleen er zitten een paar gaten teveel in ,welke in het eind product bijv niet zitten.
zit er met smart op te wachten (word ook mijn eigen aanwinst.)
  • HT forum sponsor
  • senior member
  • Trade Count: (0)
  • Total likes: 0
  • Gender: Male
« Reply #59 on: October 15, 2013, 11:25:02 »
@ Gerzom
al een beetje kunnen luisteren?
of te weinig tijd ?  :thumbs-up:
Offline gerzom
« Reply #60 on: October 15, 2013, 11:33:26 »
@ Gerzom
Gisteravond zitten genieten, hele stapel CD er doorheen gedraaid en wat dingen op Spotify geluisterd. Ik ben erg blij, het klinkt gewoon erg goed en qua "sound" zit het heel dicht bij mijn "Sonus Faber / Electrocompaniet - geluid"; relaxed, laid-back en gewoon lekker  :)
Mooie aanvulling op het geheel dus weer!
En nu maar hopen dat YGGDRASIL nog een tijdje op zich laat wachten, anders heb ik thuis zoveel uit te leggen  ;)
  • HT forum sponsor
  • senior member
  • Trade Count: (0)
  • Total likes: 0
  • Gender: Male
« Reply #61 on: October 15, 2013, 11:52:12 »
dat klinkt goed!!
Quote
doosje bonbons,een bosje bloemen,en zo nu en dan wat liefs in haar oor fluisteren doen wonderen  :D ;D
Offline gerzom
« Reply #62 on: October 15, 2013, 11:54:45 »
dat klinkt goed!!
Ja, maar die DAC is wel heeel groot vergeleken bij de Gungnir en niet zwart zoals de rest  8)
Offline Nahpets
  • HT forum donateur
  • Trade Count: (+76)
  • Total likes: 143
« Reply #63 on: October 15, 2013, 11:56:30 »
Begrijp ik nu goed dat ze een voorkeur heeft voor grote zwarte 'apparaten'? :angel:
I love everybody!
Some I love to be around,
some I love to avoid,
  • HT forum sponsor
  • senior member
  • Trade Count: (0)
  • Total likes: 0
  • Gender: Male
« Reply #64 on: October 15, 2013, 11:59:09 »
:crazy:
Offline Thanatos
« Reply #65 on: October 15, 2013, 12:02:11 »
 O0 :D
Die nieuwe dac heeft mijn oortjes ook gespitst  :angel:
Focal Sopra 1 - Line Magnetic LM-219IA aka 'Frankenstein' - Schiit Yggdrasil - Nottingham Analogue
Offline gerzom
« Reply #66 on: October 15, 2013, 13:19:35 »
Van Noorse afkomst  :clapping: (niet mijn vrouw maar die apparaten)
« Last Edit: October 15, 2013, 13:22:51 by gerzom »
Offline gerzom
« Reply #67 on: October 15, 2013, 15:54:06 »
Betere foto van mijn Schiit:
http://i194.photobucket.com/albums/z243/gerzom/Asgard1_zps06782022.jpg
Het Schiit topic
Offline Nahpets
  • HT forum donateur
  • Total likes: 143
« Reply #68 on: October 15, 2013, 15:55:55 »
Prachtig!
Die Schiit is zo strak  :pompom:
I love everybody!
  • HT forum sponsor
  • senior member
  • Trade Count: (0)
  • Total likes: 0
  • Gender: Male
« Reply #69 on: October 15, 2013, 16:14:19 »
Prachtig!
strak,grote zwarte apparaten..
 :blink:
mooi gerzom!! :thumbs-up:
Offline gerzom
« Reply #70 on: October 15, 2013, 16:22:25 »
Nog een foto dan  ;)
http://i194.photobucket.com/albums/z243/gerzom/Grado1_zpsc6cb01c8.jpg
Het Schiit topic
Offline Lightspeed
  • full member
  • Trade Count: (0)
  • Total likes: 0
  • Gender: Male
  • ziet mooi in beeld, net echt
    • elektrieke musique - 50 jaar overzicht
« Reply #71 on: October 15, 2013, 16:38:23 »
Nou nou nou, prachtig weer hoor.   :bigsmile:
Zo wel een hele hoop Schiit de afgelopen dagen te zien.   8)
Die mannen zijn wel goed bezig de laatste tijd!
[ Dual 505-1 (Ortofon) ]
  • HT forum sponsor
  • senior member
  • Trade Count: (0)
  • Total likes: 0
  • Gender: Male
« Reply #72 on: October 15, 2013, 17:00:53 »
http://youtu.be/lORYeGtEY88
spreek uit als ....  :withstupid: :crazy: :D
« Last Edit: October 15, 2013, 17:01:36 by Sonority audio »
Offline Thanatos
« Reply #73 on: October 15, 2013, 19:10:14 »
Nice Schiit and some things on fire  :D
Blijft heerlijk om te zien hoe die gasten no-nonsense blijven en zijn. Zelf in hun interviews gewoon rechtdoorzee een geen gel**ter  :D
« Last Edit: October 15, 2013, 19:10:42 by Thanatos »
Offline DofN
  • Trade Count: (0)
  • Total likes: 1235
  • Gender: Male
  • Weest allen vrolijk en blij, hup hup hup ook Gij
« Reply #74 on: October 15, 2013, 19:20:44 »
Ik heb voor mijn ouders de schiit modus USB DAC gekocht, maar zelf ook even geprobeerd. Mooi degelijk en compact apparaatje, werkte meteen.
Met foobar en wat FLACjes klonk dat echt prima!
Lyngdorf TDAI 2170, SDA2400 Mano ULTRA mkII Music Streamer, Dali Epicon 6 en 2 x JL-E112
