Author Topic: Saven van de input sensitivity setting op Anti-Mode 2.0 Dual Core  (Read 9342 times)
Deleted member
  • Guest
Zojuist heb ik onderstaande mail gestuurd naar DSpeaker omdat mijn Anti-Model 2.0 Dual Core de setting voor de  input sensitivity maar niet wil bewaren. Als ik de terugkoppeling krijg plaats ik die hier uiteraard 'ter lering ende vermaak' voor andere eigenaren.  :)
Quote
Dear sir/madam,
Last week I received my own Anti-Model 2.0 Dual Core with which I am very happy so far! I’m running a 2.1 setup with the Von Schweikert VR-5 Anniversary fronts, JL Audio F112 Fathom subwoofer and Devialet D-Premier amplifier. The Devialet has the crossover set to 80Hz so the Anti-Mode only corrects my subwoofer, not the fronts. For your information I have included a picture of the before/after screen of my setup but if you have some tips on how to improve on this result further of course I won’t decline. :-)
The real reason I email you is to report/ask you about a small issue I have. The Anti Mode 2.0 doesn’t seem to remember my setting for input sensitivity which I have set to ‘high’. After a power off -> power on I always have to manually set it back to high. I haven’t used the back button to save it but used the OK and menu buttons. Also I have set the Anti-Mode to standby to try to force a save but this doesn’t seem to have an effect. I’m running the October 4th firmware so am up to date. Is this a known issue which will be corrected in a future firmware release?
Thank you in advance for your reply!
« Last Edit: November 7, 2012, 13:03:57 by Antoine »
Offline R0N
  • HT forum sponsor
  • senior member
  • Trade Count: (0)
  • Total likes: 13
  • Gender: Male
  • Mooier geluid door akoestiekcorrectie
    • Mooier geluid, daar gaat het om!
Re: Saven van de input sensitivity setting op Anti-Mode 2.0 Dual Core
« Reply #1 on: November 7, 2012, 13:47:35 »
Hoi,
Het antwoord is dichter bij huis dan je denkt.
Wij zijn de distributeur voor Benelux.
Wat je moet doen is een update van de firmware. Onlangs is er een 'stealth update' gedaan waarmee het door jou geschetste probleem wordt opgelost. Je kunt het hier vinden.
Overigens worden de klanten die hun apparaat hebben geregistreerd bij ons automatisch op de hoogte gebracht.
ron
Hoe klinkt mooier geluid? Kom eens luisteren!
Offline Peerless Monster
  • Mr. Plinius
  • HT forum donateur
  • Beyond The Elite Upper Class
  • Trade Count: (+55)
  • Total likes: 166
  • Gender: Male
  • Note to my self: Don't lose it!!!
« Reply #2 on: November 7, 2012, 13:55:30 »
Hoi,
ron
Welke versie is momenteel de meest courante Ron? Het is nogal dynamisch...
STEREO 1: Audio Research SP-10 | Jeff Rowland model six | Acoustat model one + one | Mac mini | Michell | Mark Levinson 39 CD-speler | Sennheiser HD800
STEREO 2: Audio Research SP-10 | Audio Research DAC2 | Audio Research V70 | Tannoy DC10T
STEREO 3: Plinius 8150 | Cyrus DAC XP | Acoustat model one gemodificeerd door Audiofiel & STEREO 4: Dual CS510 platenspeler | Akai AM75 | Sonos | Mission 753
HT:  Samsung 82 inch| Classe SSP-600 | Acoustat one
Deleted member
  • Guest
« Reply #3 on: November 7, 2012, 13:57:04 »
Hoi Ron, bedankt voor je reactie!
De DC2.0 is vorige week door RA Subs besteld en geleverd bij me. Omdat m'n DC2.0 met de 4 oktober release draait dacht ik dat ik volledig 'up to date' was. Gezien jij 't een "stealth update" noemt vermoed ik dat die dus niet genoemd wordt op de website. Moet ik dan toch de "4 oktober" release downloaden en installeren omdat die 'onder water' nog ergens na 4 oktober is aangepast?
NB. Ik zal me nog even registreren op jullie website voor nieuws en updates!  :)
edit: even gedownload en ik zie in de ZIP inderdaad dat de datum van de firmware 30-10 is! Ik zal 'm vanavond installeren.  :)
« Last Edit: November 7, 2012, 13:59:12 by Antoine »
Deleted member
  • Guest
« Reply #4 on: November 7, 2012, 14:15:24 »
Nu ook al antwoord van DSPeaker!  :worship: Het klopt dus helemaal wat je zegt Ron. (Niet dat ik daar over twijfelde hoor! ;))
Quote
Dear Antoine,
thank you for contacting us! I'm really glad to hear you like the product.
There was indeed a known issue in the Oct-4 firmware that slipped into production -- it won't remember the screen dim setting or the input sensitivity setting after power down. This has already been fixed but we're collecting more changes until the next official update will be announced.
However, we figured someone might want to get rid of the problem right away so we made a "silent" update to the firmware found on our website. I.e. even though the version number is identical you can still download and install the update if you wish.
Best Regards,
[naam verwijderd]
DSPeaker
ps. Your bass response looks practically flawless to me. The dip near 110 Hz is very narrow and very likely not audible at all. The dip near 30 Hz is nothing tho worry about either. Those are probably cancellations due to wall reflections and no DSP system can correct for them. Trying to do so could cause more problems than it would solve. One could try and experiment with relocating the sub within the room to find the optimal placement regarding the cancellations but as I said your response is already so good that I doubt its worth the trouble.
Offline R0N
  • HT forum sponsor
  • senior member
  • Trade Count: (0)
  • Total likes: 13
  • Gender: Male
« Reply #5 on: November 7, 2012, 14:20:46 »
Die van 4 oct 2012 (die in werkelijkheid van 30 okt. is) ;D
Ja, het is dynamisch. Dat komt omdat DSPeaker snel reageert op de reacties van de gebruikers. Omdat ze de hard- en software zelf maken, kunnen (en willen) ze snel inspelen op vragen uit de markt. Kleine staf, korte lijnen.
Dat is één van de redenen dat ik Anti-Mode zo'n geweldig product vind. Ieder product is net zo goed als de support die je er bij krijgt. (En dat houd mij ook bezig :hehe: )
ron
  • Mr. Plinius
  • HT forum donateur
  • Total likes: 166
  • Gender: Male
« Reply #6 on: November 7, 2012, 14:21:50 »
ron
Dat krijg je wel met software natuurlijk.
Was dat vroeger maar zo met alle digitale apparatuur.
Elke keer hardware kopen loopt flink in de papieren... ;)
Deleted member
  • Guest
« Reply #7 on: November 7, 2012, 14:27:55 »
Dynamisch is goed!! In alle gevallen!  :D :thumbs-up:
  • Mr. Plinius
  • HT forum donateur
  • Total likes: 166
  • Gender: Male
« Reply #8 on: November 7, 2012, 14:31:36 »
Offline Dr Acoustat
  • HomeTheater with ESL's
  • New member
  • Trade Count: (0)
  • Total likes: 1
  • Gender: Male
« Reply #9 on: November 24, 2012, 21:58:42 »
Hmmm,
ik had dan wel verwacht dat ik een berichtje in de mailbox zou vinden over deze stealth-update. Kennelijk in het digitale walhalla terecht gekomen. Nou ja, reden om de website wat frequenter te bezoeken. De DS draait trouwens overuren hier, net of je al de muziek herontdekt.
Groet, Ronald
Dr. Acoustat, Toe aan verandering...... bezig met veranderen. MarantzSR8012, Oppo BD105, luidsprekers tja.
