Yippie
Author Topic: Het Linn topic  (Read 445612 times)
Offline myself
Re: Het Linn topic
« Reply #2800 on: September 25, 2018, 19:18:28 »
Nog wat meer gevonden over s.o.
The Space Optimization function of DSM players will be upgraded across the Linn universe; all Space Optimization capable players will be welcomed for upgrade. Transition has been made from application-based setup of Space Optimization to an internet device-based setup. In addition to addressing room modes, as the previous version, the upgraded S.O. will address speakers placed in non-ideal locations and adjusting L/R balance through time delay to ensure symmetry at the listening position.
Now included in S.O. is capability to accommodate irregularly shaped rooms by using a dynamic model versus static model in the previous version. Not only can room modes (“one note bass”) be addressed, but also decay of bass improved. The room can be configured entirely, except for the ceiling, which will be included in future updates. Doors and windows can be placed in the model, as well as optimizing toe in of the speakers. Advanced functions include temperature of the listening environment, Absorption of room construction and treatment materials, and “Optimization”, or time delay adjustment to allow stronger bass response.
Stereo: Linn Akurate DSM/3 + Akurate 4200 (bi-amp), Arcam CD33T, B&W 802D3
HT: Sony W850B (65"), Arcam AVR300 + DV79, Dreambox 8000 (HTM-1, SCM-1, Rel strata II gaan weg)
LS.kabel:Crystal Cable Reference, Nordost Blue Heaven II (center), Digitaal: Siltech, Chord, Analoog: Linn black interlinks, Stroom: AQ Blizzard/Crystal Cable Reference, Vibex, Kemp powerstrip
Offline Mitch--
  • Trade Count: (+5)
  • Total likes: 75
  • Gender: Male
  • music is all that matters!
Re: Het Linn topic
« Reply #2801 on: September 25, 2018, 19:27:05 »
nou nou, is dit al live of komt het eraan?? klinkt interessant!
Harbeth Compact 7ES-3 40th Anniversary - Linn MDSM/3 - Lejonklou Tundra 2.5 - Linn K200 - Linn Silver - BJC Cat6 - BlackNoise Six
Offline denoontje
  • Linnoontje Akurate katalyst Wilson Benesch Square 5 stereo power, Arcamoontje Wilson Benesch Square / Velodyne 7.2.4 dirac atmos jvc n7 4k HDR power
  • Trade Count: (+10)
  • Total likes: 259
  • Gender: Male
  • denoontje + primoontje -> linnoontje + arcamoontje
Re: Het Linn topic
« Reply #2802 on: September 25, 2018, 19:45:22 »
Spannend.....
Offline bmateijsen
  • Forever Addicted
  • Trade Count: (+35)
  • Total likes: 71
  • Gender: Male
  • Hifi & AV Specialist
    • Beter Beeld & Geluid
Re: Het Linn topic
« Reply #2803 on: September 25, 2018, 20:24:18 »
Alan Sircom van Hifi+ heeft een exclusieve preview van Selekt! Zie http://www.hifiplus.com/articles/linn-selekt-dsm-digital-streaming-platform/. Lees voer! 8)
Home Cinema, HiFi en streaming specialist
WebsiteFacebook | Twitter
Offline Mitch--
  • Trade Count: (+5)
  • Total likes: 75
  • Gender: Male
Re: Het Linn topic
« Reply #2804 on: September 26, 2018, 08:32:02 »
Iemand de nieuwe Davaar 64 al geistalleerd, gisteren is die uitgekomen? Ik ben toch zeer positief verrast door de update, lijkt echt beter te klinken..... ondanks dat het wat software is... :omg:
Offline Kerkhoffd
Re: Het Linn topic
« Reply #2805 on: September 26, 2018, 09:59:05 »
Wat ervaar je als beter bij Davaar 64, Mitch?
Ik ben gestopt met updaten nadat ik een aantal keren heb vergeleken tussen de Davaar versies geschreven na introductie van de Exakt DS-en. Vond mijn Akurate DS daarmee niet optimaal presteren. Vertrouwde geluid was toen terug door te downgraden. Misschien nu weer eens proberen.
Linn Akurate DS/1 - AudioQuest Diamond Digital Coax v2 BNC to RCA - Devialet 400 - AudioQuest Diamond Digital Coax v2 RCA to AES/EBU - MIT Matrix 28s luidsprekerkabel - Audio Physic Virgo 25 Plus+ - IsoAcoustics Gaia II - AudioQuest Carbon 72v DBS RFI filters - Vibex One 6 Cu - Shunyata Research Ξtron™ α Digital en ΞTron™ Z PC-10 Analog - Silent Angel Bonn N8 - AudioQuest Diamond v2 netwerkkabel - Qobuz Sublime
Offline Mitch--
  • Trade Count: (+5)
  • Total likes: 75
  • Gender: Male
Re: Het Linn topic
« Reply #2806 on: September 26, 2018, 10:57:50 »
Sound is vooral opener, losser en natuurlijker, tevens is de laagdefinitie beter.... heel bizar dat software dit kan doen, misschien zit het tussen de oren maar ik ben er happy mee :)
Offline Kerkhoffd
Re: Het Linn topic
« Reply #2807 on: September 26, 2018, 11:13:02 »
Ben benieuwd. Vanavond even proberen. Wie weet ook op de Akurate DS/1 een verbetering, en anders weer terug naar Davaar 37.
Offline Kerkhoffd
Re: Het Linn topic
« Reply #2808 on: September 26, 2018, 18:59:03 »
Eerste indruk van Davaar 64 is inderdaad prima Mitch. Dank je voor de heads-up. Komende dagen even rustig voor gaan zitten om goed te luisteren.
Offline Brammus
Re: Het Linn topic
« Reply #2809 on: September 26, 2018, 21:15:41 »
Klonk al prachtig en nu nog steeds. Lastig vergelijken aangezien ik ook niet dagelijks serieus luister.
Hoopte alleen dat het probleem met de niet werkende DS tab in config nu opgelost was maar helaas doet die het nu nog niet.
Ik vind het wel prettig om zo nu en dan de balans wat bij te regelen maar dat gaat niet wanneer de DS tab niet werkt. Vervolgens moet ik elke keer een reset doen maar dan moet ik mijn settings weer opnieuw invoeren.
Is dit een bekend probleem?
Verstuurd vanaf mijn SM-N9005 met Tapatalk
Whenever you find yourself on the side of majority, it is time to reform.
Offline bmateijsen
  • Forever Addicted
  • Total likes: 71
  • Gender: Male
Re: Het Linn topic
« Reply #2810 on: September 27, 2018, 10:19:01 »
Wat bedoel je met een niet werkende DS tab? Je ziet de DS niet in Konfig?
Indien ja, dat ligt vooral aan je netwerk, niet aan Linn.
Dus wat voor netwerk heb je? Router, modem, etc.
Bjorn
Offline Brammus
Re: Het Linn topic
« Reply #2811 on: September 29, 2018, 15:04:46 »
Bjorn
Hoi Bjorn,
Bedankt voor je antwoord, ik zal eens kijken of ik hier iets aan kan veranderen.
Zover ik weet heb ik een standaard modem van Ziggo die in bridgemodus staat met daarachter een Netgear R7000. De Linn hangt aan een Sitecom switch.
Toch zie ik de DS in config soms wel en soms niet dus hoe dit kan begrijp ik niet helemaal. Verder heb ik ook geen kaas gegeten van het opzetten van degelijk netwerk. Mijn PC heeft echter nooit verbindingsproblemen verder.
Gr. Bram
Offline bmateijsen
  • Forever Addicted
  • Total likes: 71
  • Gender: Male
Re: Het Linn topic
« Reply #2812 on: September 29, 2018, 15:12:15 »
Sitecom vind ik echt troep.... dus die switch zou ik er als eerst uitgooien. Check verder echt of je niet in beide routers een DHCP server hebt aan staan.
Bjorn
Offline advr
  • ben er klaar voor, ben er klaar voor, als
  • HT forum donateur
  • Trade Count: (+4)
  • Total likes: 27
  • Gender: Male
Re: Het Linn topic
« Reply #2813 on: September 29, 2018, 15:14:27 »
Met de laatste update ben ik mijn DSi ook regelmatig 'kwijt' en krijg die pas terug na een herstart van de DSi. Mijn Sneaky is wel altijd te zien en heeft dezelfde laatste firmware. Ligt normaal gesproken niet aan de switch.
Ollinn SET 300B, Linn Majik DS-i, Sneaky DS, Mc Systems M3 (mod), Linn LP12, Linn Ekos SE/1, Linn Dynamiked Radikal, Linn Urika, Linn Kandid, Audio Note Zero CDT/2, CD-STR+, Steve Herbelin's Tube Dampers, DH Lab powercords, Linn powercords, Nessie Vinylmaster
Offline Blue-Eyes
Re: Het Linn topic
« Reply #2814 on: September 29, 2018, 21:59:06 »
Idem, niet altijd, maar significant vaker dan voorheen. Voor de update niet of nauwelijks, nu frequent.
Speakers: WB Vector, WB Vertex, WB Fulcrum 650, Velodyne DD15, Atmos: Revel W783; App.: PRE: Linn Akurate DSM/2 & Arcam AV860, EV: Linn Akurate 2200, 2*Arcam P429, Bron: Apple TV 4k, Oppo UPD-203, Dune 4K Solo; Kabel: HDMI: Audioquest Vodka / Carbon, LS: Linn K200 / DHZ, Audioquest, XLR: Linn, DHZ, Cinch: Linn, TV: Sony KD-75XE9005; Stroom: AH! DC; Belden 4mm2, Furutech; Data: 2 * Synology, Rack: Finite Pagode Signature; AB: NEEO&Homey
Offline advr
  • HT forum donateur
  • Trade Count: (+4)
  • Total likes: 27
  • Gender: Male
Re: Het Linn topic
« Reply #2815 on: September 29, 2018, 22:05:36 »
Voorheen eens per jaar zeg maar, nu veel vaker.
Verstuurd vanaf mijn SM-G960F met Tapatalk
Offline denoontje
  • Total likes: 259
  • Gender: Male
Re: Het Linn topic
« Reply #2816 on: September 29, 2018, 22:44:29 »
Hier geen problemen met connecten.
Offline FWK
  • HT forum donateur
  • senior member
  • Trade Count: (+3)
  • Total likes: 153
  • Gender: Male
  • Teleurstelling is uitgestelde hoop.
Re: Het Linn topic
« Reply #2817 on: September 29, 2018, 23:37:15 »
Hier met een oude akurate dsm ook geen problemen en op de een of andere manier klinkt het geheel lekkerder ;D
Arcam SR 250- Arcam DV137 -  Dynaudio Contour 1.4s le- REL t5i subwoofer - Linn Akurate ds - Ocos - Audioquest en Grimm bekabeling-QNAP NAS
Offline Mitch--
  • Trade Count: (+5)
  • Total likes: 75
  • Gender: Male
Re: Het Linn topic
« Reply #2818 on: October 8, 2018, 22:37:23 »
Jammer, een van de betere audioforums is helaas 'opgeheven', het Linn forum is niet meer....https://www.linn.co.uk/forums  :(
Offline denoontje
  • Total likes: 259
  • Gender: Male
Re: Het Linn topic
« Reply #2819 on: October 8, 2018, 22:56:08 »
Offline br@m
  • HT forum donateur
  • senior member
  • Trade Count: (+2)
  • Total likes: 61
  • Science is progress
Re: Het Linn topic
« Reply #2820 on: October 8, 2018, 23:10:22 »
Zijn hier meer leden die problemen ervaren met Kazoo onder OSX Mojave?
Offline Kerkhoffd
Re: Het Linn topic
« Reply #2821 on: October 8, 2018, 23:45:52 »
Zonde. Was zeer informatief dat Linn forum.
Offline Doubleoz
Re: Het Linn topic
« Reply #2822 on: October 9, 2018, 05:55:56 »
Kun je iets concreter zijn wat je problemen zijn? Ik heb zelf wel het probleem gehad dat mijn Majik DSM niet meer kon worden gevonden door zowel Konfig als Kazoo maar uiteindelijk heb ik dit kunnen oplossen door mijn router te resetten.
Linn Majik DSM | Majik 109 | Audioquest Rocket 44 | Chord Powerchord | Synology DS214play | Raspberry Pi 2 | Apple TV3
Offline Mitch--
  • Trade Count: (+5)
  • Total likes: 75
  • Gender: Male
Re: Het Linn topic
« Reply #2823 on: October 9, 2018, 07:49:55 »
Heb ik net ook gehad, even Garmt om advies gevraagd en blijkt dat dit met modems en routers te maken heeft.
Volgende issue: Ik gebruik een Ziggo Technicolor broddel ding en een Airport Extreme, de Extreme als draadloze router in dit geval. Nu stond mijn AE in Bridge modus en dus managed de Technicolor het netwerk, fout (!), de AE is veel stabieler en kan dus veel beter het netwerk 'managen'. Zo geschiedde en moest de Technilocor in Bridge mode gezet, na wat onderzoek bleek dat alleen dit inschakelen van de Bridge mode door Ziggo zelf gedaan kan worden op afstand, dus even Ziggo gebeld en voila, netwerk is nu een stuk stabieler en gisteren geen moment de DSM 'kwijt' geweest in zowel Kazoo als Konfig, maybe it works for you!
Offline i2Paq
  • HT forum legend group
  • Trade Count: (0)
  • Total likes: 699
  • Gender: Male
  • Bij een ander klinkt het nooit zoals thuis
Re: Het Linn topic
« Reply #2824 on: October 9, 2018, 08:03:46 »
Crap, en de opmerking dat er een "Linn Space" is opgezet is je reinste kul.
Playground: Marantz 2016, B&W DM70
