Author Topic: iRule with Global iTach gateway and IR/RF 7243 to X10  (Read 18105 times)
Offline TeamKleijn
« on: March 30, 2012, 01:17:36 »
Hello ALl,
Does anyone some experience with controlling X10 devices by using iRule on Ipad and Global Cache Itach gateway ?
I want to use my ipad with Irule in the following link
Ipad->Wifi->Wifirouter->Ethernet Cable->Itach gateway->Irda->Device X->RF->Marmitek SC 9000 security Central->220 Volt Network->X10 switch and voila, light is ON (of Off whatever)
I've tried for device X
1. The transceiver of a Marmitek PowermidXL (Remote Enhancer set). This device transcode the Irda Signal to RF and send it to the SCR 9000.
2, The IR/RF 7243 Transceiver, this one convert the IRDA signal directly to X10 protocol on the AC 200 Volt power network.
Both devices don't work. Last test is trying Following codes to the IR/RF 7243 from out iRule app from my Ipad.
Light 2 ON in HouseCode K
0000 006F 0000 0022 0156 00AB 0013 0039 0013 0039 0013 0013 0013 0013 0013 0013 0013 0013 0013 0013 0013 0013 0013 0013 0013 0013 0013 0039 0013 0039 0013 0039 0013 0039 0013 0039 0013 0039 0013 0013 0013 0013 0013 0013 0013 0039 0013 0013 0013 0013 0013 0013 0013 0013 0013 0039 0013 0039 0013 0039 0013 0013 0013 0039 0013 0039 0013 0039 0013 0039 0013 05F0
Light 2 OFF in HouseCode K
0000 006F 0000 0022 0156 00AB 0013 0039 0013 0039 0013 0013 0013 0013 0013 0013 0013 0013 0013 0013 0013 0013 0013 0013 0013 0013 0013 0039 0013 0039 0013 0039 0013 0039 0013 0039 0013 0039 0013 0013 0013 0013 0013 0039 0013 0039 0013 0013 0013 0013 0013 0013 0013 0013 0013 0039 0013 0039 0013 0013 0013 0013 0013 0039 0013 0039 0013 0039 0013 0039 0013 05F0
It's tested while the housecode at the IR/RF 7243 is switched to K
But the documenttaion say it must be set on HouseCode P to transceive all X10 Irda commands to RF.
Same test done while the housecode at the IR/RF 7243 is switched to P
Both tests gives no results
Anyone suggestions?
Thanks a lot
Met vriendelijke groeten,
"Team Kleijn"
[M] +31857853503
  • info@teamkleijn.nl
[Tracking] www.trackr.nl/user/TeamKleijn/live/
Offline hifiman
  • HT forum donateur
  • Forever Addicted
  • Trade Count: (+26)
  • Total likes: 250
  • Gender: Male
  • (voorheen bekend onder de naam "audioloog")
Re: iRule with Global iTach gateway and IR/RF 7243 to X10
« Reply #1 on: October 29, 2013, 20:19:23 »
Weet niet of je er wat aan hebt maar dit zijn de hex codes die ik gebruik met irule voor de IR7243 en die doen het prima...
[1]   0000 006A 0000 0016 00A5 0097 002E 00FF 008F 0096 008E 0097 002E 0100 002E 00FF 008F 0096 002E 0100 002E 0100 008E 0096 008F 0096 01C3 0097 00A5 0097 002E 00FF 008F 0096 008E 0097 002E 0100 002E 00FF 008F 0096 002E 0100 002E 0100 008E 0F36
[2]   0000 006A 0000 0016 00A5 0097 008E 0097 008E 0096 008F 0096 002E 00FF 002E 00FF 002E 00FE 002F 00FE 002E 00FF 008E 0097 008E 0097 01C3 0096 00A5 0097 008E 0097 008E 0096 008F 0096 002E 00FF 002E 00FF 002E 00FE 002F 00FE 002E 00FF 008E 0F29
[3]   0000 006A 0000 0016 00A6 0096 002E 0100 002E 0100 008E 0097 002E 00FF 002E 0100 008E 0097 008E 0097 002E 00FF 008F 0096 008E 0097 01C3 0096 00A6 0096 002E 0100 002E 0100 008E 0097 002E 00FF 002E 0100 008E 0097 008E 0097 002E 00FF 008F 0F36
[4]   0000 006A 0000 0016 00A5 0097 008E 0096 002E 00FF 008E 0097 002E 00FF 002E 00FE 002E 00FF 008E 0097 002E 00FF 008E 0096 008F 0096 01C3 0097 00A5 0097 008E 0096 002E 00FF 008E 0097 002E 00FF 002E 00FE 002E 00FF 008F 0096 002E 00FF 008E 0ED8
[5]   0000 006A 0000 0016 00A5 0096 002E 0100 002E 0100 002E 0100 008E 0097 002E 00FF 008F 0096 008E 0097 008E 0097 002E 00FF 008F 0096 01C3 0097 00A5 0096 002E 0100 002E 0100 002E 0100 008E 0097 002E 00FF 008F 0096 008E 0097 008E 0097 002E 0ED8
[6]   0000 006A 0000 0016 00A5 0097 008E 0097 002E 00FE 002E 00FF 008E 0097 002E 00FF 002E 00FE 008F 0096 008E 0097 002E 00FF 008E 0096 01C4 0096 00A5 0097 008E 0097 002E 00FE 002E 00FF 008E 0097 002E 00FF 002E 00FE 008F 0096 008F 0096 002E 0ED8
[7]   0000 006A 0000 0016 00A5 0097 002E 00FE 008F 0096 002E 00FF 008E 0097 002E 00FF 008E 0096 002E 00FF 008E 0097 002E 00FF 008E 0096 01C3 0097 00A5 0097 002E 00FE 008F 0096 002E 00FF 008E 0097 002E 00FF 008E 0096 002E 00FF 008E 0097 002E 0ED8
[8]   0000 006A 0000 000E 00A5 0097 008E 0097 008E 0096 002E 00FF 008E 0097 002E 00FF 002E 00FE 002E 00FF 008E 0097 002E 00FF 008E 0096 01C4 0096 00A5 0097 008E 0ED8
[9]   0000 006A 0000 0016 00A5 0097 002E 0100 008E 0096 008F 0096 008F 0096 002E 0100 008E 0096 002F 00FF 002E 0100 002E 0100 008E 0097 01C3 0096 00A5 0097 002E 0100 008E 0096 008F 0096 008F 0096 002E 0100 008E 0096 002F 00FF 002E 0100 002E 0ED8
[10]   0000 006A 0000 0016 00A5 0097 008E 0097 008E 0096 008F 0096 008E 0097 002E 0100 002E 00FF 002E 0100 002E 0100 002E 0100 008E 0096 01C4 0096 00A5 0097 008E 0097 008E 0096 008F 0096 008E 0097 002E 0100 002E 00FF 002E 0100 002E 0100 002E 0ED8
[11]   0000 006A 0000 0016 00A5 0097 002E 00FF 002E 00FE 008F 0096 008E 0097 002E 00FF 008E 0096 008F 0096 002E 00FF 002E 00FF 008E 0096 01C4 0096 00A5 0097 002E 00FF 002E 00FE 008F 0096 008E 0097 002E 00FF 008E 0096 008F 0096 002E 00FF 002E 0ED8
[12]   0000 006A 0000 0016 00A6 0096 008E 0097 002E 0100 008E 0096 008F 0096 002E 0100 002E 0100 008E 0096 002F 00FF 002E 0100 008E 0097 01C3 0096 00A6 0096 008E 0097 002E 0100 008E 0096 008F 0096 002E 0100 002E 0100 008E 0096 002F 00FF 002E 0ED8
[13]   0000 006A 0000 0016 00A5 0096 002F 00FF 002E 0100 002E 0100 002E 0100 002E 00FF 008F 0096 008E 0097 008E 0097 008E 0096 008F 0096 01C3 0097 00A5 0096 002F 00FF 002E 0100 002E 0100 002E 0100 002E 00FF 008F 0096 008E 0097 008E 0097 008E 0ED8
[14]   0000 006A 0000 0016 00A5 0097 008E 0097 002E 00FF 002E 0100 002E 0100 002E 0100 002E 00FF 008F 0096 008F 0096 008E 0097 008E 0096 01C4 0096 00A5 0097 008E 0097 002E 00FF 002E 0100 002E 0100 002E 0100 002E 00FF 008F 0096 008F 0096 008E 0ED8
[15]   0000 006A 0000 0016 00A6 0096 002E 00FF 008E 0097 002E 00FE 002F 00FE 002E 00FF 008E 0097 002E 00FF 008E 0096 008F 0096 008E 0097 01C3 0096 00A6 0096 002E 00FF 008E 0097 002E 00FE 002F 00FE 002E 00FF 008E 0097 002E 00FF 008E 0096 008F 0ED8
[16]   0000 006A 0000 0016 00A5 0096 008F 0096 008F 0096 002E 00FF 002E 00FF 002E 00FE 002E 00FF 002E 00FF 008E 0097 008E 0096 008F 0096 01C3 0097 00A5 0096 008F 0096 008F 0096 002E 00FF 002E 00FF 002E 00FE 002E 00FF 002E 00FF 008E 0097 008E 0ED8
[ON]   0000 006B 0000 000E 00A5 0094 002F 00FA 002F 00FA 008F 0093 002F 00FA 008F 0092 0090 0092 0090 0092 002F 00FA 008F 0093 002F 00FA 01C3 0091 00A5 0094 002F 0ED8
[OFF]   0000 006B 0000 000E 00A5 0094 002F 00FA 002F 00FA 008F 0093 008F 0093 008F 0093 008F 0092 0090 0092 002F 00FA 002F 00FA 002F 00FA 01C3 0091 00A5 0094 002F 0ED8
[BRIGHT]   0000 006B 0000 000E 00A5 0094 002F 00FA 008F 0093 002F 00FA 008F 0093 008F 0093 008F 0093 002F 00FA 008F 0092 002F 00FA 002F 00FA 01C3 0091 00A5 0094 002F 0ED8
[DIM]   0000 006B 0000 000E 00A6 0093 002F 00FB 008F 0093 002F 00FB 002F 00FB 008F 0093 008F 0093 002F 00FB 008F 0093 008F 0093 002F 00FB 01C2 0091 00A6 0093 002F 0F12
[ALL-ON]   0000 0066 0000 0027 002F 0112 002F 0112 009E 00A2 009E 00A2 009E 00A2 009E 00A2 009E 00A2 009E 00A2 0030 0112 01DD 00A3 009E 00A2 002F 0112 002F 0112 0030 0111 0030 0111 009E 00A2 009E 00A3 009D 00A3 009E 00A2 009E 00A2 002F 0112 01DD 00A3 009E 00A2 0030 0112 002F 0112 002F 0112 002F 0112 009E 00A2 009E 00A2 009E 00A2 009E 00A2 009E 00A3 002F 0112 01DD 00A3 009E 00A2 002F 0112 002F 0112 0030 0111 0030 0FA0
[ALL-OFF]   0000 0066 0000 0027 0030 0112 002F 0112 009E 00A2 009E 00A2 009E 00A2 009E 00A2 009E 00A2 009E 00A2 0030 0112 01DD 00A3 009E 00A2 002F 0112 002F 0112 002F 0112 0030 0111 009E 00A2 009E 00A3 009D 00A3 009E 00A2 009E 00A2 002F 0112 01DD 00A3 009E 00A2 0030 0112 002F 0112 002F 0112 002F 0112 009E 00A2 009E 00A2 009E 00A2 009E 00A2 009E 00A2 0030 0112 01DD 00A3 009E 00A2 002F 0112 002F 0112 0030 0111 0030 0FA0
« Last Edit: October 29, 2013, 20:35:02 by Audioloog »
Offline emeulen
« Reply #2 on: November 3, 2013, 19:51:07 »
Bedankt voor deze codes.
Helaas werken ze bij mij niet goed (of eigenlijk niet)
Ik zet de IR7243 op de huiscode P.
Ik programmeer in Irule dan bv. commando "1"- delay 0.2s - commando "On".
Doe ik iets fout of is mijn IR7243 defect?
Groeten  Etienne
Online J.A.F._Doorhof
  • All your base are belong to us / JonDoe297
  • Owner
  • Forever Addicted
  • Trade Count: (+12)
  • Total likes: 3100
  • Gender: Male
  • Tja, je hebt van die dagen
    • J.A.F._Doorhof
« Reply #3 on: November 4, 2013, 09:11:50 »
Wij hebben er ook wat problemen mee gehad, uiteindelijk werkte een pauze tussen de codes perfect.
Probeer de pauze iets langer.
« Last Edit: November 4, 2013, 09:12:12 by J.A.F._Doorhof »
Offline hifiman
  • HT forum donateur
  • Forever Addicted
  • Total likes: 250
  • Gender: Male
« Reply #4 on: November 4, 2013, 12:03:17 »
Same here, delay wat langer gemaakt en dat scheelt een hoop ;-)
O en ik gebruik gewoon huiscode A
« Last Edit: November 4, 2013, 12:03:56 by Audioloog »
Offline hifiman
  • HT forum donateur
  • Forever Addicted
  • Total likes: 250
  • Gender: Male
« Reply #5 on: November 4, 2013, 12:05:23 »
Overigens heb ik ook iets raars. Af en toe werkt het wat onbetrouwbaar (gebruik de IR blaster), dus ik dacht dan plak ik er een emitter op. Vanaf dat moment werkt het voor geen ene meter meer... Iemand enig idee hoe dat kan?
  • Owner
  • Forever Addicted
  • Total likes: 3100
  • Gender: Male
    • J.A.F._Doorhof
« Reply #6 on: November 4, 2013, 12:24:56 »
Wij hebben een emiter op de IR7243 zitten.
Je moet wel erg goed opletten dat je de goede poort activeert in de software en de juiste hardware selecteert. Daar gaan de meeste mensen de fout in.
Offline Kjelt
  • HT forum donateur
  • Forever Addicted
  • Total likes: 3373
  • I also love the HTforum
« Reply #7 on: November 4, 2013, 13:41:30 »
Check eerst even of er wel ir uitgezonden wordt (met bv webcam of andere ir gevoelige camera op iPad/pod ofzo)
-NEE geen ir:  dan kan het de configuratie zijn als wat Frank hierboven aangeeft OF het plugje zit er iets te ver in (google maar eens schijnt een klein issue te zijn) klein ringetje ertussen of plugje iets terug trekken zou het oplossen.
-JA wel ir: dan kan het zijn dat de emitter de ontvanger overstuurt oftewel simpel gezegd de ontvanger clipped. Dit kun je testen door de emitter op wat grotere afstand van het oogje te houden en kijkt of het dan wel werkt. Als dit het is en het werkt op grotere afstand wel dan wil je er een serieweerstand tussen solderen om de stroom van de led te verkleinen. Groote van de serieweerstand moet je proefondervindelijk vaststellen maar zou qua orde grootte ongeveer een 220-680 ohm zijn (GC-100 heeft als uitgang een 5V met 470ohm R dat geeft met een voltage drop over de ir led van 1,4 V een stroom van ongeveer 7,7mA. Met een extra serieweerstand van 470 ohm zou je op 3,8mA uitkomen.
Offline hifiman
  • HT forum donateur
  • Forever Addicted
  • Total likes: 250
  • Gender: Male
« Reply #8 on: November 5, 2013, 13:38:40 »
O ok, en dat werkt goed begrijp ik?
Uiteraard heb ik dat gecheckt  ;) Het werkt ook af en toe wel, een op de 30x ofzo dat ik een button indruk...
Offline hifiman
  • HT forum donateur
  • Forever Addicted
  • Total likes: 250
  • Gender: Male
« Reply #9 on: November 5, 2013, 13:40:22 »
IR doet het, zie ik ook op de led op de IR7243 die aangeeft dat er een signaal binnenkomt. Denk dat je gelijk hebt, immers met IR  blaster op afstand werkt het wel. Het rare is dat de emitter op een afstandje houden ik ook al geprobeerd had en dat werkt ook niet.
Offline Kjelt
  • HT forum donateur
  • Forever Addicted
  • Total likes: 3373
« Reply #10 on: November 5, 2013, 13:55:24 »
Scope op de (gebufferde) uitgang van het oogje in het apparaat hangen en kijken wat er binnenkomt.  ;)
Offline hifiman
  • HT forum donateur
  • Forever Addicted
  • Total likes: 250
  • Gender: Male
« Reply #11 on: November 5, 2013, 13:58:38 »
Net even getest en ik maakte de afstand niet groot genoeg! Met wat meer afstand werkt het inderdaad wel. Kortom ga aan de slag met een weerstandje  ;D
Enne de scoop binnenkort ook maar eens gebruiken anders wordt tie stoffig  ;)
Offline hifiman
  • HT forum donateur
  • Forever Addicted
  • Total likes: 250
  • Gender: Male
« Reply #12 on: November 5, 2013, 18:08:18 »
Probleem opgelost middels een 4K7 serie weerstand tussen de emitter en het ip2ir kastje. Met 2K7 deed tie het nog steeds niet, met 3K3 net wel. Uiteraard trad de wet van behoud van ellende in werking en reageert 1 X10 module nu niet betrouwbaar meer, maar dat is een X10 probleem dat te maken heeft met het feit dat ik om de emitter op de IR7243 moest kunnen  plakken ik deze fysiek naar een anders stopcontact heb verhuisd  :yawnee:
« Last Edit: November 5, 2013, 18:08:53 by Audioloog »
Offline Kjelt
  • HT forum donateur
  • Forever Addicted
  • Total likes: 3373
« Reply #13 on: November 5, 2013, 19:22:34 »
Zo he, 4k7? Dan stuur je nog maar 700uA door die led, (over)gevoelig oogje heeft dat ding dan  :-\
Mooi dat het nu werkt.
Offline emeulen
« Reply #14 on: November 27, 2013, 22:29:49 »
Ik een Sw10 module, die geen P codes kan schakelen. in plaats van de P zie ik een ster staan, dit is om de standen te programmeren. Mijn systeem werkt alleen in de P huiscode met de bovengenoemde codes.
Met welke codes zou ik deze schakelaar kunnen bedienen?
