InterVideo Releases WinDVD 4
Started by J.A.F._Doorhof, May 9, 2002, 15:36:56
InterVideo, Inc. has reported the availability of WinDVD 4, the latest version of its popular DVD player. WinDVD 4 features over 30 new features and enhancements such as easier-to-use Time-Stretching and Video Desktop -- which lets you watch movies under your desktop icons while you work or check email. The new version also includes 10 new audio features including TruSurround XT from SRS Labs, for virtual surround sound over two speaker systems or headphones, plus over a dozen other improvements.
"SRS Labs is pleased that InterVideo has adopted TruSurround XT for this new release of WinDVD," said Jennifer Drescher, vice president of marketing for SRS Labs, Inc. "In this new version of their industry leading software, InterVideo continues to raise the standard for DVD software players. With TruSurround XT, SRS Labs and InterVideo are truly bringing the home theater experience to the desktop by allowing users to enjoy virtual 5.1 surround sound experience from their existing two speakers or headphones."
WinDVD 4's proprietary Time-Stretching feature allows a user to play a movie faster or slower without distorting the audio -- and with full multi-channel audio support. With WinDVD 4's updated time-stretching capabilities a user can utilize new "Finish by ... " and "View in ... " commands to control the time the movie will end. For example, a user might choose "Finish by 10:00 pm" or "View in 1 hour" and the playback speed of the movie is automatically adjusted by WinDVD 4 -- ideal for business travelers who want to get the most out of short flights and battery life. Time-stretching is not available on any other DVD player.
CONTACT:
http://www.intervideo.com
Henk
Ik benieuwd wat ze nou precies met het geluid doen bij dat 'Time-Stretchen'? Gaan ze het alleen sneller/langzamer afspelen (waarbij de toonhoogte verandert) of worden er nog correcties toegepast om de toonhoogte op peil te houden?
In ieder geval kan deze functie bruikbaar zijn om film-materiaal op een PAL disc weer in de correcte snelheid te laten afspelen.
Hé dat is een slimme  :o.
Vraag me af of dat ook echt wil.
Iemand al mee getest ?
MvrGr.
Profisound
Wooooow! Vandaag de nieuwste versie WinDVD 4 Plus gedownload! Je ga kompleet uit je dak met deze nieuwe speler! Voor de CRT freaks is dit volgens mij DE speler op dit moment!
Met "Time-Stretchen" kan je de film een stukje korter of langer laten duren zonder dat het geluid beinvloed wordt! Er zit zelfs een "PAL Tru Speed" op ,om het verschil van 4% wat de "PAL dvd" te snel loopt op te lossen!
De geluidskwaliteit is echt uniek! Hij geeft alles perfect weer DD ,DD-EX ,DTS ,DTS-ES ,DPL2 enz enz!
Waanzinnig is het "Collor Subpanel" waar je de Brightness ,Contrast ,Collor ,Hue en Gamma Corection in kunt stellen! Dit werkt erug smoot!
Wat ook erg mooi is ,is dat je de subtitles "transparant" kunt maken ,vooral met een film kijken met je CRT op een groot scherm is dit gaaf ,want de letters zijn nu heel mooi en het geflits van je subs is een STUK minder!
En dan het beeld ,woow wat een plaatje zeg! Nog niet eerder gezien!
Hier kun je hem downloaden! Wel registreren he als hij beval! ;D
xxxxxxxxxxxxxxxxxxxxxx (geen illegale links aub:forumbeheer)
