Von Schweikert VR-35 Export Deluxe review
Started by Deleted member, July 1, 2011, 07:56:53
Deleted member
De eerste review van de Von Schweikert VR-35 Export Deluxe is uit op EnjoyTheMusic.com. :) Dit is een meer betaalbare full-range vloerstaander uit 't Amerikaanse Von Schweikert's gamma en is ontworpen voor kleinere luisterruimtes en plaatsing dicht bij een muur. Is in Nederland ook te koop (€8000/paar) met verschillende kleuren stof en top- + bottomplates.
Specs:
Type: Reference floorstanding loudspeaker
Frequency Response: 25 Hz to 30 kHz (+/- 3dB)
Sensitivity: 90dB/W/m
Impedance: 8 Ohms nominal, with a minimum of 5 Ohms @ 25 Hz.
Subwoofer: Scan-Design custom 10" with Low Distortion Motor, laminated composite cone, elevated spider, long throw design, and copper clad pole piece.
Midrange: Two Scan-Design 6" treated paper cast-frame bass-mids with low distortion motors, elevated spiders, copper clad pole pieces, and composite laminated cones using cellulose acetate pulp, plastic resin, and carbon impregnation to eliminate standing waves on the cone surface.
Tweeter: 1" treated fabric dome, Danish-designed Dual Ring design with rear chamber for low resonance and powerful response down to the midrange band, Low Distortion Motor, and custom voice coil/top plate design for low distortion.
Crossover: First order circuit using "audiophile-grade" parts, with cross points set  at 80 Hz and 6 kHz. All crossover parts are made by Mundorf and Erse, with custom solid copper foil capacitors insulated with Teflon dielectric film.
Woofer Alignment: Quasi-transmission line design using three chambers, each tuned to a different resonant frequency to extend the bandwidth and reduce "one note bass" typical of ported boxes. Woofer "fires" at rear wall to boost the bass at 20 Hz by 3dB, and can be "tuned" by user.
Power Rating: 35 watts minimum, up to 500 watts on peak music.
Dimensions: 50 x 16 x 12 (HxWxD in inches)
Weight: 112 lbs. each
Warranty: Five years parts and labor (excluding abuse), non-transferable.
http://www.enjoythemusic.com/superioraudio/equipment/0711/von_schweikert_vr_35_export_deluxe.htm
clockwork
Wow! Klinkt aanlokkelijk.  :pompom:
Qua looks weet ik het nog niet. :unsure: Ik vind de andere modellen wel mooier.....
Nordost/ Shunyata bekabeling
Deleted member
Ben ik met je eens Clockwork.  ;) Er is dan ook echt bewust bespaard op de kosten ten koste van de looks bijvoorbeeld door geen fineer te gebruiken maar stof.
clockwork
Het moet ook uit de lengte of uit de breedte komen.....
Denk wel dat ik een keer ga luisteren. Dat stukje over kippevel klinkt wel verleidelijk.......
twani
Ze zijn nóg lelijker dan die van mij ;D  Zeg Antoine wanneer ga jij nou eens upgraden naar VR9 of 11? komen die van jou tenminste op de markt :D
Moet je wel eerst weer 2 gaten in je "Akoesplafo" maken, anders passen ze niet :D
Deleted member
Quote from: twani on July  2, 2011, 15:52:31
Hahaha...helaas geen winnend lot nog in de loterij dus een upgrade naar die modellen zit er nog niet in voorlopig!  :D
twani
Speel jij de Von Schweikerts maar zeer langdurig in, ik heb nog jaaaren de tijd.
