Goldmund nieuws
Gestart door jan-rotterdam, december 20, 2004, 19:52:56
jan-rotterdam
#150
Goldmund komt met een nieuwe "universal player" in de Metis lijn, deze speler is gebaseerd op het Oppo 93 loopwerk en kan via iPhone / iPad bediend worden.
Prijs nog niet bekend
CiteerThe new Metis player is planned for delivery in November.
More compact than the Metis C/DVD player, it can be controlled by iPhone or iPad thanks to the new iGoldmund remote.
This small player has most of the features of its big brother, the Eidos 20BD Universal but for a much more reasonable
price. With an Oppo 93 inside as well, it plays all formats including 3D.
Groeten Jan
jan-rotterdam
Goldmund komt met een tweetal nieuwe eindversterkers, 3 en 4 kanaals
Citeer
The Telos 153/154 Proteus Amplifiers: NEW
Two new Telos amplifiers will be born this year: the Telos 153 (3 channels) and the Telos 154 (4 channels).
These amplifiers have been created to function with Proteus in mid-range high end systems and will allow customera with a modest budget to benefit from the Proteus technology at a reasonable price.
They will have the size and look of a Telos 250 and avoid the loss of space due to the multiplication of power amplifier units required by Proteus.
They are available for order and will be delivered next December.
Groeten Jan
jan-rotterdam
#152
Goldmund komt met een nieuwe processor, de Mimesis 15.
Ik ben bang dat dit geen groot succes gaat worden, is aan de specificaties te zien een Metis 10 in een andere behuizing, tevens geen HDMI in- / uitgangen...
Citeer
INPUTS
3 analog 2-channel inputs
4 digital inputs RCA (up to 96 kHz)
2 digital inputs optical toslink (up to 96 kHz)
1 digital input USB (up to 48 kHz PCM Stereo only)
The audio format supported are:
•PCM 44.1kHz to 96kHz
•Dolby Digital
•DTS
•DTS-CD
•AAC
DIGITAL OUTPUTS
•8 digital RCA SPDIF outputs.
•Front panel and remote-control adjustable level control with 65dB range and 0.05dB accuracy in the 0-> -34dB range.
REMOTE-CONTROL
•RC5 Standard remote system compatible with standard programmable remote control transmitter (codes available on request).
•Volume and balance control
•Selection of the source
•Remote Muting and Standby
•2 IR Jack output for other device control
FRONT PANEL CONTROLS
•2 knobs for input selection and volume control
•2-character numeric display for input selection
•2-character numeric display for volume
•Direct Led format, balance and function display
POWER
•1 separate transformer
•6 separately regulated power supplies
•Nominal AC line voltage: 117V or 234V (+/- 10%)
•Maximum power consumption: 8W
•Fuse: 100mA /250V (slow-blow)
SIZE AND WEIGHT
•440 W x 404 D x 130 H (mm)
•Weight: 12kg
WARRANTY
•3 years parts and labor
Link naar user manual
Groeten Jan
jan-rotterdam
#153
Goldmund komt met een Blu-Ray speler in de Metis lijn, de Metis 30.
Speler speelt ook SACD + DVD-Audio.
Citeer
COMPATIBILITY
•BD-VIDEO, DVD-Video, DVD-Audio, AVCHD, SACD, CD, HDCD, Kodak Picture CD, CD-R/RW, DVD±R/RW, DVD±R DL, BD-R/RE BD Profile:
•BD-ROM Version 2.4 (also compatible with Profile 1 Version 1.0 and 1.1)
OUTPUT
•Analog Audio: stereo Right & Left
•Digital Audio: Coaxial, Optical.
•HDMI Audio: Stereo, up to 7.1ch high-resolution PCM, up to 5.1ch DSD, bitstream or LPCM conversion of Dolby Digital, Dolby Digital Plus, Dolby TrueHD
•DTS, DTS-HD High Resolution Audio, and DTS-HD Master Audio.
•Digital Video: HDMI with HDCP (NTSC480i/480p/INPUT
•External IR Remote Control
AUDIO CHARACTERISTICS
•Frequency: 20Hz – 20kHz (-0.3 ±0.05dB)
•Signal-to-Noise Ratio: >110dB (A-weighted)
•THD+N: < 0.002% (1kHz at 0dBFS, 20kHz LPF)
POWER
•Power Supply: ~ 100V – 240V, 50/60Hz AC
•Power Consumption: 35W (0.5W Standby)
SIZE AND WEIGHT
•440 W x 300 H x 70 D (mm). 5.5 kg.
WARRANTY
•3 years, parts and labor.
Link naar User Manual
Groeten Jan
Citaat van: jan-rotterdam op april 22, 2012, 10:10:58
Groeten Jan
Geen HDMI.. ongeloofelijk dom ontwerp Anno 2012  :withstupid:
jan-rotterdam
Citaat van: vik op april 22, 2012, 10:22:37
Helemaal mee eens !
Groeten Jan
Robbo
Zou je denken.   Dan vraag ik me toch af waarom er zoveel kopers voor de Oppo BDP95 zijn.
jaco
#157
Alleen normaal DTS en DD ?
Of je nu wel HDMI in wil hebben met alle shit die daar mee komt is weer wat anders. Maar ook geen multikanaals ingangen ?
The Mimesis 15 can be used as a 2-channel preamplifier and as a powerful home theater
processor. It can benefit from the Proteus technologies developed for the Goldmund Media
Room. This gives the Mimesis 15 the possibility to use numerous filter configurations
adapted to the set up of each room as well as the capability to better pan speakers in a
multi-channel system. In other terms, a better sound quality and a perfect surround.
Please contact your authorized Goldmund retailer for the configuration of your Mimesis 15
for home theater applications.
copy/paste uit de manual.
jan-rotterdam
Citaat van: vik op april 23, 2012, 16:49:31
Dit hebben alle Goldmund pre/pro's in zich, niets nieuws  ;)
Groeten Jan
jan-rotterdam
Goldmund komt met een nieuwe stereo eindversterker, de Telos 280
Specificaties:
POWER RATING:
• Nominal Line Voltage 117 ; 234V
• AC line range: 10%
• Fuse 8A for 115 and 230V
• 2 toroidal transformers
• Separated ground and earth signal
• Connection between earth and ground to cancel all ground loops
OUTPUT POWER:
• Power RMS (Goldmund FPP Standard): 320Wrms on 8 Ω.
• Maximum power (IEC60065): 2 x 215 Wrms on 8 Ω / 1%THD
• Rated Power Consumption (IEC60065): 300 Wrms
DISTORSION: With 1 Vrms output level, 80 KHz measurement bandwidth, 600 Ω termination impedance
• IMD < 0,04%
BANDWIDTH:
• 20Hz – 20KHz: +/-0,2dB on 8 Ω.
• +/- 3dB: 0Hz - >200KHz on 8 Ω.
SLEW RATE:
• 8V/μS
AMPLIFIER GAIN:
• 35dB
INPUT:
• Maximum input sensitivity: 1Vrms on 8 Ω
NO-CLIPPED OUTPUT VOLTAGE:
• Maximum voltage: 153Vpp
DAMPING FACTOR:
• 173
SAFETY FEATURES:
• Automatic switching to MUTING if the AC line drops or is interrupted.
FRONT PANEL:
• ON/OFF Switch
• Green LED for power
REAR PANEL:
• Power cord socket 3 lugs
• Voltage selctor 115/230V
• 1 pair of RCA connector (left and right)
• 2 pairs of output speakers connector (left and right)
DIMENSIONS AND WEIGHT:
• Dimensions: 440 W x 405 D x 130 H (mm)
• Weight: 15 Kg
WARRANTY:
• 3 year parts and labor.
Groeten Jan
jan-rotterdam
Goldmund heeft ook de Telos 153 / 154 is het programma opgenomen
CiteerTelos 153/154 - Power AmplifierThe Telos 153 and Telos 154 are the newest offering in the Goldmund Digital Power amplifier line. The Telos 153 comes with 3 channels whereas the Telos 154 comes with 4. These two models have been created to function with Proteus in mid-range high end systems.
For those who are not familiar with Proteus, here is a short summary (white papers are available in the technology page of this website for science versed readers): Proteus is a mathematical modeling technique created by the Goldmund fundamental research team. It computes acoustic corrections that have the unique particularity of perfectly aligning the frequency response, the phase response and the time response of a speaker. This level of perfection has never been achieved before in any other existing audio system. The corrections are included in a configuration file that is loaded inside the preamplifier and each driver is then amplified separately.
So the Telos 153/154 are your ideal partners if you are looking for a multi-amplified system as they will allow you to save space and money while delivering the extremely strong driver control that characterizes all the Goldmund amplifiers.
Designed with elegance and posh, the size and feel of both Telos 153/154 are very similar to these of Telos 250.
TELOS 153 POWER SUPPLY:
• 3 toroidal transformers
• 3 separated power supplies
• Power cord socket (3 lugs).
• Main Fuse (8A slow-blow)
FRONT PANEL CONTROLS:
• ON/OFF Switch
• Orange LED for lock
• Red LED for error
REAR PANEL CONNECTORS AND CONTROLS:
• Main fuse socket
• 3 digital input RCA connectors
• 3 pairs of output speaker connectors (left and right)
GROUNDING
SAFETY FEATURES
POWER
• Power RMS (Goldmund FPP Standard): 3 x 150W on 8 Ohms
• Peak Power/Maximum voltage: 3 x 275W on 8 Ohms
• Nominal line voltage: 117 or 234 V (+/- 10 %)
BANDWIDTH
• 20Hz-20kHz +-0.5dB typical
CIRCUIT SPEED
• Slew rate of the amplification stages: 60 V/us
• Rise time: < 500 ns
GROUP DELAY
• < 100 ns stable frequency from DC to 200kHz
DISTORTION
• THD < 0,002% (0dBFS, 80KHz bandwidth measurement)
SIZE AND WEIGHT
• 385W x 310D x 220H (mm)
• Weight: 25kg
WARRANTY
• 3 years parts and labor
TELOS 154 POWER SUPPLY:
• 4 toroidal transformers
• 4 separated power supplies
• ON/OFF Switch
• Red LED for error
• Main fuse socket
• 4 digital Input RCA connectors
• 4 pairs of output speaker connectors (left and right)
GROUNDING
SAFETY FEATURES
POWER
• Power RMS (Goldmund FPP Standard): 4 x 150W on 8 Ohms
• Peak Power/Maximum voltage: 4 x 275W on 8 Ohms
BANDWIDTH
CIRCUIT SPEED
GROUP DELAY
• < 100 ns stable frequency from DC to 200 kHz
DISTORTION
SIZE AND WEIGHT
• Weight: 25kg
WARRANTY
Groeten Jan
Citaat van: jan-rotterdam op oktober 20, 2012, 15:52:55
• ON/OFF Switch
• Red LED for error
• Main fuse socket
GROUNDING
SAFETY FEATURES
POWER
BANDWIDTH
CIRCUIT SPEED
GROUP DELAY
DISTORTION
SIZE AND WEIGHT
• Weight: 25kg
WARRANTY
• ON/OFF Switch
• Red LED for error
• Main fuse socket
GROUNDING
SAFETY FEATURES
POWER
BANDWIDTH
CIRCUIT SPEED
GROUP DELAY
DISTORTION
SIZE AND WEIGHT
• Weight: 25kg
WARRANTY
Groeten Jan
Dag Jan,
Mooi spul dat Goldmund en ik hoor goede verhalen van forum lid Roderick. Het valt mij wel alleen op dat er wereldwijd bijna geen enkele review te vinden is over dit merk, of dat er over gesproken wordt.
jan-rotterdam
#163
Uit de Goldmund newsletter:
Groeten Jan
jan-rotterdam
#164
Goldmund komt met een nieuwe eindversterker, de Telos-500.
Qua uiterlijk lijkt deze heel veel op de oude Telos-600
Link naar internet pagina: http://www.goldmund.com/en/products/telos_500
Groeten Jan
Blijft mooi spul om te zien..
Gr Hans
jan-rotterdam
Wat foto's van het inwendige van de Telos 390.5 versterker
Link naar internet pagina: http://www.goldmund.com/en/products/telos_390_5
Groeten Jan
Mooi spul Jan enkel het valt mij op dat er maar heel weinig over dit merk wordt geschreven. Bijna geen enkele review te lezen op internet.
Op de site zelf staan enkel magazines met reviews afgebeeld.
Op audiogon een enkele keer dat het veel te duur is voor wat het merk levert. Maar dit zijn persoonlijke meningen in het forum gedeelte van Audiogon.
jan-rotterdam
#168
@ Vik: Duur is het zeker, de laatste jaren enorm in prijs gestegen :-[
Reviews staan inderdaad op de website: http://www.goldmund.com/en/reviews
Groeten Jan
jan-rotterdam
Een link naar een review van de nieuwe Goldmund Telos 360 versterkers
Link naar review
En een link naar de webpagina van de fabrikant
Groeten Jan
