Denon geeft gratis DTS:X(Atmos) firmware update vrij in januari 2016.
Gestart door pharaoh, december 19, 2015, 10:23:38
Robbo
Is dat neural X nou de upmixer van DTS? Wat zie je bij een echte DTS-X track ?
Raymen
Alleen dts:x net als bij atmos
En dat neutral :x doet het echt goed
Mvrg
Raymen
HOMECINEMA :Jvc nz7- Screen Excellence Neo 4k 120 inch-Lyngdorf mp50-Gigawatte-PF-2 EVO-Ncore hypex 3X500W-Ncore hypex 6x250w-Madvr Envy Pro-Zidoo x3000pro-Apple tv 4K(2022)-5xFocal 300lcr6-4xFocal 300 inceiling-2 x Jl Audio F113 v2(v1)- 1m,2m AQ coffe hdmi-3X Pcord CM- -2 X Supra sword XLR (sub )9x WWorld XLR 5xAQ cinnamon ethernet-
Fox
http://www.avsforum.com/forum/286-la...2015-a-96.html
Stereo two channel films on DTS X.
I was really disappointed to find after the download that my older stereo BDs don't send dialog to the centre channel like DSU does. Its horrid listening to the dialog coming only from the L or R channels when I have 12 seats and not one of them is in the centre of the L&R speakers.
I know we can go back into the player and change from bitstream to PCM to bring up DSU, but its a real hassle and easy to forget to turn the player back after a stereo movie.
Do you think DTS X know about this, and maybe do a fix to anchor dialog to the centre channel on stereo films?
This is the very same reason I stopped using Auro 3D, dialog doesn't come from the centre channel on stereo films.
http://www.avsforum.com/forum/90-rec...hread-297.html
james_bond
Nog één nacht geduld en dan eindelijk de langverwachte DTS:X upgrade voor mijn avr-x6200w.  :pompom:
HT: Epson EH-TW9300, Epson EH-TW3200, DENON AVR-X6700H, Onkyo HT-S9405THX, 2 paar Translator Heliodoor, Translator Center 12, Dune Solo 4K,Apple TV 4K, Projecta Tensioned Elpro RF Electrol 122inch (zichtmaat 270 cm x 152 cm), Zyxel NAS540.
james_bond
#55
Update is inmiddels gestart en gaat 28 min. duren.
Update klaar; meer info volgt, eerst aan het werk.
Raymen
james_bond
Vanavond even aan het testen geweest met de nieuwe firmware en bij deze even een kort verslag. De update op zich ging zonder problemen en was binnen een half uur klaar. Waar ik mij voorheen aan ergerde was dat ik DTS bronnen niet kon upmixen met de DSU. Blijkbaar had Denon deze functie bij de x6200 geschrapt; bij de x7200 was dit nog wel mogelijk. Met de Neural:X upmixer is dit probleem nu verleden tijd en ik moet zeggen: de Neural:X upmixer klinkt goed. Ik speel zelf met een 6.2.4 opstelling met front height en rear height en de sound bubble is indrukwekkend. DTS:X heb ik wegens gebrek aan content niet kunnen testen.
destroyer2usa
Mijn Denon 6200W ook ge update en getest met mijn 7.1.2 opstelling met atmos upfiring speakers  o.a. met native dts-x content, van de demo discs 19 en 20.
Binnenkort eens een complete film in native dts-x bekijken.
Neural X Lijkt inderdaad meer content naar de hoogte kanalen te sturen als DSU.
Klinkt in ieder geval fantastisch.
Tip. Wil je Neural X aktiveren dan moet je tijdens het afspelen van DTS-X content de Neural X optie aan zetten. Die staat namelijk dom genoeg uit standaard. Is wellicht een bug?
Die kun je dus alleen aktiveren als je DTS-X content afspeelt...
destroyer2usa
Citaat van: Kjelt op februari 19, 2016, 23:23:58
Welke? Zoveel aanbod is er nog niet.
The Last Witch Hunter staat voor morgen op het programma.
Zijn er 4 nu en weer 2 aangekondigd dus er begint zoetjes aan wat te komen..
Gigantische achterstand op Atmos natuurlijk nu ze haast 1 jaar vertraging hebben opgelopen.
Vanavond een film gekeken met DTS-HA MA + Neural X upmixing en dat klinkt fantastisch... echt veel meer actie/geluid in de hoogtekanalen.
Heb tijdens de film sommige scenes teruggekeken met alleen DTS-HD MA en dan hoor je meteen het verschil....minder ruimtelijk.
Lijkt ook of de track met neural X upmixing meer laag heeft...
Allemaal subjectief natuurlijk en beoordeeld na/met het nuttigen van 2 glazen rum... :nowink:
Raymen
CiteerTip. Wil je Neural X aktiveren dan moet je tijdens het afspelen van DTS-X content de Neural X optie aan zetten. Die staat namelijk dom genoeg uit standaard. Is wellicht een bug?
wat je nu zegt klopt niet.
Ik denk dat je dts-hd bedoelt.
Met dts:x kan je niet nog eens neural x activeren, dat zou dubbel zijn.
Want dts:x gebruikt al de top speakers.
destroyer2usa
#62
Citaat van: Raymen op februari 19, 2016, 23:39:03
Daarom zeg ik ook bug want dat kun je namelijk WEL.
Ik zou zeggen kijk zelf maar eens.
Speel een DTS:X demo clip af, press AUDIO en dan bij surround parameters staat neural x uit en kun je op aan zetten en je hoort dan verschil!!
Raymen
maar bedoel je nu met dts   dts-hd of een dts:x track
Want bij die laatste heeft het geen nut om de neural x aan te zetten
Dat zou hetzelfde zijn als bij een atmos trackook nog eens + dolby surround aan te zetten
Mvrg,
Raymen
destroyer2usa
Citaat van: Raymen op februari 19, 2016, 23:46:33
Mvrg,
Raymen
Ik bedoel inderdaad wat ik schrijf DTS:X, want bij DTS-HD heb je niet de optie bij audio om Neural X aan te zetten.
Kortom wil je normale DTS-HD upmixen met neural X moet je een DTS:X bestand aan zetten en dan bij audio de neural x optie aanzetten.
Kortom een bug want dat heeft inderdaad geen nut.
james_bond
Citaat van: destroyer2usa op februari 19, 2016, 23:58:58
???  Lijkt mij niet juist, maar zal dit mogelijk vandaag eens bekijken en foto's maken van de audio opties.
Ik zou zelf wel een native DTS:X track willen uitproberen; hoe ben jij hieraan gekomen?
destroyer2usa
Citaat van: james_bond op februari 20, 2016, 08:20:14
De optie neural x is natuurlijk wel beschikbaar als je dts hd afspeelt, maar het aanzetten van die optie geeft wel verschil.
Alleen de aan en uitzetoptie van neural x is alleen beschikbaar als je een dts:x clip/film afspeelt.
Tja, hoe je er aan komt...Zoals we overal aan komen toch?  :police:
Raymen
Zoals ik lees is het bij jouw unit dan niet goed gegaan of alle 6200 van denon
Heb die bug hier niet hoor, en ook andere met een 7200 niet
Succces in ieder geval
Raymen
destroyer2usa
Citaat van: Raymen op februari 20, 2016, 08:28:34
Die "bug" zie je dus pas als je dts:x content afspeelt...En die heb jij ook hoor...
Lees er het AVSforum maar op na, reviews van gebruikers met een 7200W.
Raymen
Neehoir heb al verschillende dts:x films en demos maar daar heb ik echt geen last van hoor
destroyer2usa
Citaat van: Raymen op februari 20, 2016, 11:20:11
Je hebt dan dus tijdens afspelen de settings geopend, bent naar audio setting gegaan en dan surround parameters geopend?
Als jij dan geen optie ziet om neural X aan of uit te zetten dan is er bij jouw juist iets misgegaan tijdens updaten, want die optie hoort er te staan.
Raymen
Haaaa ja dat heb ik wel gedaan
Nu begrijp ik wat je bedoeld
Dat hoort dus niet
destroyer2usa
Citaat van: Raymen op februari 20, 2016, 12:10:38
Dat hoort dus niet
Precies dat is dubbel op bij native content.
Die optie had er moeten staan als je bij DTS HD content die surround parameters opent, maar dan staat er die optie dus NIET bij.
Fijn dat we er uit zijn, nu Denon nog....  ;D
james_bond
Het heeft  bij mij ook even geduurd voordat het kwartje viel. Moest eerst nog even een dts:x track scoren  ;). Overigens gaf het in/ uitschakelen van neural:x in de audiosettings bij mij geen hoorbaarverschil bij het beluisteren van de dts:x track.
