Set van Mario "Audio-GD DI25HE besteld"
holco
#3000
Ik denk dat ik dat het beste kan beantwoorden met een quote van Ian zelf.
https://www.diyaudio.com/forums/digital-line-level/192465-asynchronous-i2s-fifo-project-ultimate-weapon-fight-jitter-627.html
FIFO buffer and re-clock are two different things.
FIFO buffer uses buffer memory to replace the digital music stream with a brand new timing which generated by a new low jitter new (FIFO works as a clock timing isolator between two clock domains).
Re-clock makes I2S/DSD output signal re-align the the new MCLK to reduce the I2S/DSD jitter.
FifoPi has a built in re-clock stage. We can call it the first re-clock stage.
ReClockPi is a low noise low jitter secondary re-clock stage. By upgrading a FifoPi with a ReClockPi, the I2S/DSD signal quality (both noise and jitter) can be improved even more thus better sound quality will be expected.
To achieve the best possible low noise and low jitter performance, ReClockPi was implemented by all discrete logic chips. It has around 150 tiny SMT components on a four layers double side mounting PCB. It could be almost impossible to include the ReClockPi into a FifoPi because of the limitation of the size of the PCB. And even more, ReClockPi has ShiledPi function. So, the current independent configuration can reduce the EMI noise even more.
I have been using a prototype ReClockPi in my own system for more than two months. I listen to music with it everyday. I'm really happy with it.
Here is my system:
The Best Sound Quality Audiophile DIY DAC I Built in 2020 - YouTube
I'll have more details to post soon.
Regards,
Ian
My Showcase
Eversolo T8 streamer / Audio-GD R8HE mk3 DAC / Audio-GD HE-1 mk3 preamp / Daudio ASP / Hypex Nilai-500 mono's (mid-hoog) / Hypex Nilai-500 mono's (woofers) / Daudio C1 (diy versie) / Rythmik F18 subwoofer / Mundorf Angelique (mid/hoog) /  Sommer Cable Elephant SPM440 (woofers) / Preffair X430 XLR kabels / Curious Evolved USB kabel / Pink Faun i2s kabel / Power regenerator AG1500S / Supra LoRad Power cables.
vergeerr72
Ik ben echt erg benieuwd hoe de streamer klinkt. Net iets te technisch voor mij om zelf te bouwen.  Je mag wel eens op burenbezoek komen met de streamer[emoji6]
Plinius Tautoro/SA 103/Koru/Tiki, Audio Physic Caldera Mk2/ Rhea, Transrotor Zet 1 TMD Lager, Benz Micro ACE SL, Acrotec/Acrolink bekabeling, Labahua groundboxes, Audirvana, Synergistic Research zekeringen
holco
Dan ben ik bang dat je nieuwsgierigheid onbevredigd blijft, je praat hier over 3 aparte voedingen, de streamer zelf en de R8 DAC vanwege de i2s input, niet iets wat je ff onder de arm pakt ;)
Maar om een indruk te krijgen wil ik best wel hier een demo geven  8)
Citaat van: vergeerr72 op april 26, 2021, 19:35:59
My Showcase
vergeerr72
Dat klinkt inderdaad als een onderneming. Neem ik mijn allo wel in mijn broekzak mee[emoji3]
gizmo2
alles high-end verantwoord.
holco
Klopt, bij mij zitten er de accusilicon klokken in, die zitten trouwens ook in mijn R8 dac.
My Showcase
holco
Ronald, je inbox blijkt vol te zijn, tijd voor een cleanup  ;D
Citaat van: vergeerr72 op april 26, 2021, 19:54:11
My Showcase
vergeerr72
Citaat van: holco op april 27, 2021, 09:54:31
Is het weer zover.
holco
Was een glitch die schijnbaar weer opgelost is  ;D
My Showcase
holco
We hebben weer wat te doen van het weekend ;D
My Showcase
vergeerr72
Citaat van: holco op mei 12, 2021, 17:33:05
Wordt de streamer weer onderhanden genomen?
holco
Yep, met de laatste updates van Ian Canada.
My Showcase
vergeerr72
Straks de Allo weer meenemen?
holco
My Showcase
holco
De Raspian draait lekker met de nieuwe ReclockPi en de HDMIPi MKII, ook weer eens nieuwe filters in de amp's geschoten, beste wat ik tot nu toe uit mijn speakers gehoord heb  ;D
My Showcase
vergeerr72
Die curve is erg smooth.
holco
Er zit ook veel smoothing op  ;D maar dat is nu eenmaal zo als je vanaf de luisterplek wil tunen  ;)
Maar je herkent het iig niet terug tov de meet & greet laatst, laag is nog steeds rete strak en vol maar het
mid en hoog is nu duidelijk meer aanwezig (minder donker) met dus meer detail en ruimtelijkheid, ben er
erg happy mee met hoe het nu klinkt  ;D
My Showcase
vergeerr72
holco
Voor de leuk zaterdag een fraai setje Elac FS 247 halen, ben benieuwd!!
My Showcase
holco
Dit klinkt toch wel erg lekker  8)
My Showcase
AudioEnZo
Knappe jongens die Elacs  :clapping:. En een ommezwaai terug naar passief toch?
Gr. René
    ► Vinshine x LYH SW-10pro
► Xanadu HRS22YH-MG
Marco66
Prachtige speakers, altijd wel een keer willen proberen!
holco
Ja weer terug naar passief inderdaad en dat bevalt goed zover, maar het maakt wel nieuwsgierig hoe ze actief zouden uitpakken  :D
Citaat van: AudioEnZo op juni  9, 2021, 08:39:34
My Showcase
holco
Gewoon doen, speelt erg fraai en veel beter als dat je zou verwachten  ;D
Citaat van: Marco66 op juni  9, 2021, 08:45:08
My Showcase
Marco66
Citaat van: holco op juni  9, 2021, 11:21:21
Heb ooit een setje Elac monitoren gehad en die klonken al verrassend volwassen voor het formaat!
