Rythmik subwoofer topic
Gestart door Cobraatje, februari 25, 2015, 11:17:42
Cobraatje
#1400
Tech specs:
FV18/FV25 update
We are trying to get the FV25/FV18 to the market. Most likely will be end of this year, or early Jan.
We have made a change to FV18 from 2 ports to 3 ports (in order to be competitive with new SVS offering). Two port tuning is around 12.5hz. 3 port tuning will be around 16hz. The extension filter setting will be 12hz, 14hz, and 18hz. The depth of both models is 22'.
The following is the FR of FV18 in 2 port mode with extension setting at 12hz and low damping. It is the flattest among all 3 damping. FR is -4db @12hz . Upper edn extension is -4db @90hz in line-in mode. Price of FV18 will be around $1700 including freight shipping. Horizontal frequency scale is in log. To read the frequency, one can start with the line labeled as 10hz. The next vertical line to the right is 20hz, then 30hz, etc, until you hit the right edge of the denser vertical line which is 100hz. The plot stop 187.5hz.
The following is FR of FV25 with all 3 ports open with 12hz low damping. At 10hz, its response is about 3.5db better than FV18. Other than that, both are pretty flat. Finish is available with flat matte paint only. Price will be $2450 including freight shipping.
FV25 will be more demanding on power system. Poor wall electrical wiring (which manifests as often light flickering) can limit the maximum current available to the amp. If 240V option is available without sacrificing the eletrical wiring gauge, it is a better choice than 120V route because the current demand in 240V setup is only half of the 120V setup.
Monitor Audio Platinum 100 3G - Platinum C350 3G - Gold 50 6G - 2x M&K V12+ subs - LG OLED77CS6LA - Lyngdorf MP40 2.1 - Marantz MM8077 CineMike Stufe 2 + Brückung - Sony UBP-X800M2 Cinemike - NAD M50
papaleo
Wat zijn de maten (HxBxD) van een FV18,of zijn deze nog niet oficieel bekend?
Mmm...,nu ben ik niet iemand die zit te wachten op een 'goedkope' sub,maar als ik deze kwa maten zou kwijt kunnen.....de specs spreken me wel aan zeker icm de prijs ;)
Cobraatje
#1402
Exacte afmetingen zijn nog niet bekend, diepte is 55,88 cm.
Het prototype was 21"Wx23"Dx33"H
Ik neem aan dat jij lang genoeg meeloopt om te weten dat prijs regelmatig weinig zegt over kwaliteit  ;).
Duur spul kopen en dan proud owner zijn heb ik nooit begrepen, als je dezelfde of betere kwaliteit voor minder kunt krijgen :D.
Rythmik is wat b.v. SVS ooit ook was, een relatief klein bedrijf waarbij kwaliteit op no.1 staat.
De F15 of FV15 zijn, zowel qua diepgang, output als gebruikte onderdelen, een stuk beter dan de Velodyne die je nu hebt.
Een FV18 tav je Velodyne Dd15 is geen vergelijking.
'The FV18 will have more output below 20Hz, around 3dB - 4dB more than FV15HP @ 12Hz. Above 20Hz it will be very similar to FV15HP.
However, if somebody is looking for massive output at 12Hz I would save more money and hold on to the FV25HP.
The FV25HP would have around +9dB more than FV15HP @ 12Hz, so we are talking 108dB @ 12Hz. Kinda Danley DTS-10 output numbers.
papaleo
#1403
Citaat van: Cobraatje op november 13, 2016, 10:41:03
Ja,daarom staat de Rythmik nog steeds op mijn shortlist... ;)
Maar de maten van een proto FV18 zijn voor mijn situatie to much...,zeker de breedte zou in mijn geval niet meer dan 19,60" (50cm) mogen zijn,in de diepte en de hoogte heb ik nog wel wat speling wat dat betreft.
Maar goed 'n F15 ga ik zeker nog n keer beluisteren....,deze heeft wbt de maten de perfecte afmetingen  :worship:
Cobraatje
Met een F(V)15 beluisteren kan ik je niet helpen, ik heb inmiddels 2x F12, maar je bent van harte welkom voor een luistersessie.
martien
Shoalinmonk
Het luisteren naar dual F15HP kan hier ook geregeld worden....Flevoland.
Cinemike Marantz AV7702 mkII 'voll Stufe' ~ 2x MM8077: 1x Cinemike 'voll Stufe und Brucking' ~ Cinemike Marantz UD7007 'voll Stufe', Cinemike Zappiti Reference,  Cinemike Sony x800m2, Qnap TVS 673e 64gb, Monitor Audio Platinum: PL200II, PLC150II, PL100, PLICII, JL Audio F113v2, JVC NZ7, Philips 65PUK7120, in de tuin: Marantz M-CR511, Monitor Audio Climate 80
papaleo
Citaat van: martien op november 13, 2016, 11:56:45
Een fv15hp is 461mm breed
Kwa breedte en ook de hoogte van een FV15 die kan ik kwijt,maar 61cm diep...!! dat is iets te veel van het goede...55cm diep zou nog net gaan.
papaleo
Bedankt voor het aanbod dat ik de subs kan komen beluisteren... ;)
Maar jullie hebben beide een dual opstelling,ik zou het met een enkele sub moeten doen....dit zou niet echt eerlijk zijn tov mijn mono opstelling.
Hoe zit het met de integratie van een Rythmik,heeft deze bv ook autom. roomcorrectie onboard om de  sub af te regelen?
martien
Citaat van: papaleo op november 13, 2016, 16:46:48
Deurtje van de kast open laten? :D
Lucky.L
Citaat van: papaleo op november 13, 2016, 16:53:43
Nee,geen roomcorrectie.
Cobraatje
2 F12's is 0,5db minder dan 1 F15.
Betere integratie en beter laag is er wel met 2 subs .
Rythmiks hebben geen automatisch inregelsysteem, wel zeer uitgebreide instelmogelijkheden.
Maar waarom zou je een inregelsysteem op je sub willen hebben?
Dat zijn veel mindere inregelsystemen als Audyssey XT32 op je Marantz en ik zie geen toegevoegde waarde.
Sirius666
#1412
Hiero. Een F12 in 020 ;)
papaleo
Ik 'was' altijd in de veronderstelling dat de inregelsoftware van een sub,neem bv de Velodyne/SMs1 dit beter kon dan de software van een receiver/Pre...
Arcenon
Nog wat info voor geïnteresseerde:
FV18/FV25HP update:
The extension filter setting will be 12hz, 14hz, and 18hz. The FV18 is 21"(W) x 33"(H) x 22"(D). The FV25HP is 21"(W) x 41"(H) x 22"(D). We will post the weight later.
FV18 uses 900WRMS amp and FV25 uses 1800RMS amp.
FV18 will be 2db higher output than FV15HP. More improvement is from below 18hz where port output is significant. The improvement is via port compression reduction in the following way. In data-bass test data, our compression is the lowest because the servo feedback adjust the amp output so the output of woofer cone always maintain the consistent frequency response. The only exception is below 18hz where port output becomes significant. Since there is no sensor on ports, compression data show the loss of output even after we maintain correct woofer cone movement. Our observation from the data is 1db additional compression loss for every 5db SPL increase until eventually the port wind noise takes over. So I expect to gain 1db more output just from lower port compression. So overall, it is 2db more output.
For FV25, we expect 6db more output above 30hz. The enclosure size is reduced by 30% per driver, but we have 50% more power from amp. So in the end each driver in FV25 has approximately same output as FV15HP in the baseline comparison. But the number of ports (and port area) increases from 1 to 1.5 (per driver), therefore it cuts down the compression loss slightly.
One interesting information of FV15HP by data-bass is the 12.5hz max output from FV15HP in 1 port mode is not limited by the 2nd order or 3rd order harmonic distortion like in other tests. This means the amp output is not the limiting factor. Instead it is the upper band noise which is caused by port noise. So how can be reduce that upper band noise and allow for a higher output number with 2nd or 3rd order distortion becoming the limiting factor? First, 50% more port area per driver does help and second, we will use a bit more internal sound absorbing material. So that can give us up to 3db output improvement (or up to 9db total output as I referred early in this thread) at 12.5hz point.
For FV25HP we have also tried 2 port mode which pushes the port tuning frequency to 10hz. It improves the music sound more obviously. The bass line becomes just more detailed. The arias in the opera house scene of MI5 (rogue nation) just gives me goose bumps.
The FV18 will be $1700 including freight shipping and the FV25HP will be $2450 including freight shipping. The FV25HP will be available in black matte paint and the FV18 in black oak vinyl.
Bluesound Powernode 2I N330 + Dali Rubicon 6
Shoalinmonk
#1415
Te koop: Mijn Rythmik F15HP-SE
Link op MP.
Advertentie hier volgt vanavond.
Citaat van: Shoalinmonk op november 23, 2016, 17:29:41
Te koop een Rythmik F15HP
Link op MP.
Verrassend! Wat staat er op stapel?
Shoalinmonk
Richard70…
Staan er ineens twee te koop op het forum :blush:
Nog een optie om rekening mee te houden :wacko:
Cobraatje
Imo een veel betere optie dan de Velodyne.
Maar zelf gaan luisteren is natuurlijk het beste.
Cobraatje
LVX12 Black Friday Sale!!!
The LVX12 goes on sale this week starting on Black Friday and will last for one week. The sale price is $699 shipped. Regular price is $799 shipped.
Cobraatje
Diverse aanbiedingen bij Rythmik :headbanging::
LV12R is on sale for single sub purchase at $569 including shipping.
F15HP-BO and F15HP-BM are on sale for single sub purchase at $1174 plus shipping.
F8-BO and F8-BM (dual 8" driver sealed sub) are on sale for single sub purchase at $764 plus shipping.
L22 (dual 12" driver sealed sub) is on sale for single sub purchase at $819 including shipping.
LVX12 (multi-tuned ported sub) is one sale for single sub purchase at $699 including shipping - Black Friday Sale.
LV12R is one sale for for single sub purchase at $569 including shipping.
bask04
is er iemand die niet al te ver van omgeving schoonhoven afwoont
om een keer met kennis mijn sub in te regelen.
Heb alleen de crossover helemaal open gedraaid en de anthem
ARC laten doen maar hij klinkt bonkerig.
Dit hoeft niet voor nix uiteraard
Witalik
Maak anders eerst eens een foto van de achterkant hoe er nu bepaalde instellingen staan, misschien kunnen ze je al een stuk verder helpen hiermee.
Sony X80L - Marantz SR-7011 - Bowers en Wilkins 603-S1 / HTM6S2AE / 606S2AE Custom HTPC -  XTZ 12.17 EDGE W&M LS-03 - fronts en center No name HDMI kabels
"Showcase"
Cobraatje
#1424
Ik ben bang dat de plaatsing of ontkoppeling het probleem is.
Ik weet dat Bas eigenlijk maar 1 plaats heeft om de sub neer te zetten en ook met het zeer goede ARC in zijn Anthem blijft een goede plaats wel erg belangrijk.
Een Rythmik staat er juist bekend om dat ie retestrak klinkt.
