AM 2.0 DC beta firmware (2 december 2012)
Gestart door Deleted member, december 2, 2012, 22:52:51
Deleted member
Ik zie zojuist (toevallig) dat er vandaag een nieuwe firmware beschikbaar is gesteld voor de AM2.0!  :)
EDIT: het blijkt hier om BETA software te gaan.
http://www.dspeaker.com/en/products/20-dual-core/firmware-update.shtml
Dec 2 2012
Citeer
•   Asynchronous audio transmission in USB mode for improved audio quality
•   Improved compatibility in USB mode (Squeezebox Touch via USB etc.)
•   Two user-selectable volume control schemes in USB mode: by remote and by computer. "By remote" ensures that volume level stays consistent with other input modes but master volume requests from the computer are ignored. "By computer" setting routes all volume adjustments through the computer. In this mode, a sudden volume change is possible, especially when connecting the unit to a computer for the first time. Please use with caution. Both modes of operation still utilize the high quality analog volume control IC in Dual Core so audio quality is not compromised in either of the modes.
•   Added playback controls in USB mode (play/pause and next/previous track)
•   Compensation setting of the room correction can now be freely adjusted after calibration (using 0.5dB steps)
•   Improved user interface responsiveness (faster switching of sound profiles, faster bypass/Anti-Mode etc)
•   New settings menu layout
•   New homescreen menu (located in Settings menu) allows re-mapping the remote controller's arrow button actions within the homescreen. Separate functions can be assigned to left/right buttons and up/down buttons. The choices are: bass, treble, (full spectrum) tilt, loudness, next/previous track in USB mode, next/previous input switching and off. The OK button can be assigned to either Play/Pause function (in USB mode) or main menu access. (Playback control commands require compatible software on the computer side.)
•   Highpass and lowpass filters can now be assigned on per-channel basis (allows "1.1" operation).
•   Added numeric feedback for QuickTone adjustments
R0N
Citaat van: Antoine op december  2, 2012, 22:52:51
Dec 2 2012
LET OP: het is een bèta versie en bevat nog bugs. Ook wij zijn nog aan het testen/vertalen.
Ik beveel aan te wachten totdat de versie definitief is en ook een Nederlandse toelichting heeft.
Tenzij je houdt van experimenteren en zwarte schermen, gebruik de update van 2 dec niet.
Op dit forum maken we bekend wanneer de juiste versie beschikbaar is.
ron
Deleted member
Toen ik 't schreef stond 'ie er bij mij al in uiteraard.  :-X Ik ben niet zo geduldig met dit soort dingen.  :D
Anyway, er staat nergens op de officiële site dat 't om een beta gaat dus als dat wel zo is dan vind ik dit niet netjes. Gelukkig is/lijkt de upgrade hier goed te zijn gegaan. Ik gebruik 'm niet als USB DAC overigens waar de meeste functionaliteit voor is bijgekomen.
Ben benieuwd hoe de nieuwe manual compensation setting werkt/uitwerkt in 't resultaat maar ik wacht dan wel even tot ook jij klaar bent met testen/documenteren. ;)
R0N
Citaat van: Antoine op december  2, 2012, 23:31:38
Laten we het er op houden dat het uit enthousiasme zo vroeg is vrijgegeven. Morgen zal er bèta bij staan, want ik houd hier ook niet van  >:(
Overigens zijn er wel weer mooie functies bijgekomen. Maar zoals gezegd, beter nog even wachten todat alles klaar is.
ron
Deleted member
Op de DSPeaker.com website is de firmware nu inderdaad gemarkeerd als beta software.
