Teufel H600 C Speaker 2 stuks
Gestart door Maks, augustus 17, 2023, 11:17:27
Maks
Te koop Teufel H600 C Speaker
In uitstekende staat, altijd gebruikt als surround speaker. Officieel door Teufel gemaakt als zijnde center speaker, maar gezien de specs overal inzetbaar. Op de achterkant zitten wat kleine ondiepe gaatjes tbv het hoefprofiel als zijnde ophangmechanisme.
Nieuwprijs was 300 per stuk.
Vraagprijs: 100 per stuk of 2 voor 150 euro.
Specificaties:
Theater 6 Hybrid - H 600 C - white - Front Angled
The recessed tweeter and moulded waveguide ensure a wide sound dispersion as well as excellent speech intelligibility. High excursion carbon drivers produce enormous levels in even large rooms.
Dimensions
Width   42 cm
Height   18 cm
Depth   18,2 cm
Weight   6,18 kg
Connection
Terminal clamps   Screw terminals
Minimum amplifier output power recommended   30 W
Speaker
Suitable for AV receiver   Yes
Suitable for banana plug   Yes
Maximum cable diameter   4 mm
Diameter of the stand screw threads   6 mm
Removable front cover   Yes
Enclosure material   MDF
Enclosure surface   Laminate/lacquer
Magnetic shielding   Yes
Net internal volume   8 L
Tweeter (number per enclosure)   1
Tweeter (diameter)   25 mm
Tweeter (material)   Fabric
Bass/Midrange driver (number per enclosure)   2
Bass/Midrange driver (diameter)   130 mm
Bass/Midrange driver (material)   Fibreglas
Continuous power handling (IEC - Long Term)   110 W
Sensitivity (2.83 V / 1 m)   88 dB
Frequency range   80 - 22000 Hz
Peak power capacity (IEC - Short Term)   140 W
Maximum sound pressure level   105 dB/1m
Impedance   4 - 8 Ohm
Crossover frequency to Woofer (recommended)   80 Hz
Acoustic principle   2-way-system
Enclosure type   Closed
Crossover frequency internal switch   2400 Hz
JVC-N9, Panamorph DCR, IVisions Tab tensioned 21:9 screen (145x330), Klipsch THX-Ultra 2 - 9.2.4, JVC Exofield, Samsung 98QN90a, Oppo BDP-203, Zidoo UHD 3000, Madvr Envy, Marantz AV8805, Marantz MM88077, Marantz MM8008,  Synology DS1813 en veel te veel dure kabels!
