HDfury Integral 2 met GoBlue adapter
Gestart door Toni71, april 23, 2022, 10:29:10
Toni71
Overbodig hier. Leuke aanvulling om Dolby Vison op elke HDR10 display te krijgen, wanneer je DV / LLDV aanvoert. Dus ook op projectors.
Maar ook een switch en matrix. Waarmee je hdmi 1.4 en 2.0b in de keten kunt gebruiken zonder gedoe.
Integral 2 met Goblue adapter(+59 euro afzonderlijke aanvulling) met ir kabel.
Er mist alleen de rs232 kabel. Deze lever ik na bij aankoop. Ik lever mijn spullen altijd netjes af. Er mankeert niets aan.
Vaste prijs EUR 125.00
'HDfury Integral 2 is a 4K60 4:4:4 600MHz 18Gbps HDMI2.0b Level A smart converter for interoperability between legacy equipment, for integrators, content creators, calibrators, streamers, digital entertainment centers, UHDTV retail, show sites, data centers, schools, conference or home cinema.
HDfury Integral 2 is capable of converting HDCP, FHD<>UHD Resolution, Chroma, Color Depth, Color Space and more in order to individually feed any of the connected sinks at their best capabilities. GUARANTEED!
User can pass thru Dolby Vision or HDR from Source to TV while sending Dolby Atmos or any sound format to a non DV or HDR capable AVR.
Featuring a true 2×2 18Gbps HDMI matrix/splitter/switcher/scaler/converter/audio de-embedder, HDfury Integral 2 can also act as an Infoframe and HDR metadata Injector and Extractor, HDCP Doctor, CEC Commander, HDMI Doctor, EDID manager and more...
It supports any HDMI, any HDCP and any HDR up to HDR10+, HLG or Dolby Vision, including LLDV.
HDMI Audio is compatible with any sound format in existence today.
It provides full EDID management for an optimal handling of today's wide variety of sources and displays and comes with OSD, IR, RS232 and stereo or optical audio output for ARC up to Atmos®, DD+®, Dolby® 7.1, DTS® and LPCM for capable sink.
Instantly get and feel the HDMI supervisor power through OSD, Windows GUI, RS232, iOS/Android APP (with GoBlue) and more...
Note that it have the best 18Gbps signal integrity ever seen for a 5v device, thus ensuring seamless integration even with marginal cables that would otherwise not work with others devices for high bandwidth signals.
If you ever saw the following statement: "this TV does not support HDCP 2.2. Make sure you have HDCP 2.2 capable TV" or a similar HDCP error message, make sure you never see it again with HDfury Integral 2!.
Specs:
HDMI revision:   HDMI 2.0b (Level A) 600Mcsc – 18Gbps
Integral2 Support:   600MHz/18Gbps HDR, HDR10+, HLG, DV & LLDV, ARC, ALLM, IMAX
Max Resolution:   4K60 4:4:4 8b, 4K60 4:2:2 12b, 4K120 4:2:0 8b or 8K30 4:2:0 8b
I/O:   2 HDMI In, 2 HDMI Out, IR, RS232, USB, Analog Jack, Optical Out.
Upscale port:   FHD 1080p to UHD 2160p & 2K/DCI to 4K/DCI
Downscale port:   UHD 2160p to FHD 1080p & 4K/DCI to 2K/DCI
Signal Conversion:   Resolution, Chroma Subsampling, Color Space, Color Depth, HDCP
HDCP Conversion:   Any HDCP to any HDCP with CST1 support
Operating Modes:   18Gbps Scaler, Switcher, Splitter & Matrix with CEC, ARC and EDID management
Special Modes:   CEC Command, HTPC, Disable or inject HDR, HDMI Doctor and JVC Macro.
EDID Modes:   10 EDID Flags, 100 EDID Banks (10 custom)
Infoframe Modes:   Capture, edit, block or replace HDR metadata, AVI & VSIF.
Read SPD, Audio, HDMI Vendor, HDMI Forum
Control Modes:   IR, Windows GUI, RS232 for Linux/MAC/Win, Android/iOS with GoBlue
On Screen Display:   Editable with custom text and mask. (cover TV channel logo)
Dimension:   3.9″L x 2.4″W x 0.8″H – in CM: 10 x 6 x 3
Weight:   130g – 0.3 LBS
Other info:   Input Lag <1ms (nanoseconds count)
Kerre
Toni71
