Nieuwe video processor van DVDO: "EDGE".
Started by PeterPan, July 30, 2008, 17:52:43
PeterPan
Ik kwam deze vandaag pas tegen op avsforum.com. De nieuwe video processor van DVDO met dezelfde Anchor Bay ABT2010 'chip' als het huidige top model, de VP50 pro maar met wat uitgeklede functionaliteit:
QuoteThe DVDO® EDGE™ $799 retail is an affordable high quality video processor and A/V hub that converts standard definition, high definition and PC signals from up to ten sources (including six HDMI 1.3 compatible devices) to any HDTV resolution up to 1080p. EDGE has a very intuitive user interface which makes installation a breeze. EDGE has two HDMI 1.3 outputs, one with audio and video and one with audio only to facilitate connections to an HDMI/DVI equipped display and HDMI AV Receiver. An optical audio output is available for older AV Receivers. A backlit universal remote control with a luxurious "soft-touch" finish is also included. Images are available at the bottom of this post.
The DVDO EDGE incorporates all of Anchor Bay's acclaimed Video Reference Series, VRS™, technologies on the ABT2010 ASIC, including:
Precision Deinterlacing™ – 480i/576i/1080i 10-bit Motion, Edge & Source Adaptive Deinterlacer
• Five-field motion adaptive deinterlacing
• Edge adaptive processing to produce smooth diagonal edges
• Three frame video processing delay (Max)
• Game Mode with very low latency (sub-1 frame delay)
• Arbitrary cadence detection (any:any) to detect non-standard cadences in input signals.
o Reliable 2:2 pull-down detection for 50Hz countries
o Detection of 2:2 ↔ 3:2 crossfades and out of phase 3:2 crossfades
o Detection of multiple source types within a frame
o Bad edit detection and compensation to minimize artifacts caused by sequence breaks in film content
PReP™ - Progressive ReProcessing of 480p, 576p and 1080p input signals allows poor deinterlacing of any source to be undone and done correctly using Precision Deinterlacing™.
Mosquito Noise Reduction - Reduces random noise which appears along the edges of compressed images in SD and HD content
Fine Detail Enhancement – Extracts fine detail in low resolution or compressed SD or HD content
Edge Enhancement – Sharpens edges without adding ringing
Precision Video Scaling II™ - 10-bit Scaling up to 1080p
Progressive Cadence Detection™ of 480p, 576p, 720p and 1080p input signals – Allows source-locked framerate output of film-based content (24/25Hz)
Rightrate™ – High-Performance Framerate Conversion which enables 1080p-24Hz output of film-based content.
Precision A/V Lipsync™ - Intelligent digital audio delay technology to match Audio and Video timing
AutoCUE-C™ – Automatic Chroma Upsampling Error detection and correction
Features
Sleek New Product Design with luxurious "soft-touch" finish (Image available at the bottom of this post)
Intuitive Display/Source Setup Wizards make installation a breeze
User Definable Names for all inputs using keyboard entry
On Screen 'Hints' available for all controls
Dedicated HDMI Audio Only Output for connections to AV Receivers and Processors
Backlit Learning Universal Remote Control with luxurious "soft-touch" finish and Discrete Input selection. (Image available at the bottom of this post)
Rear Panel IR Input (mini-jack) for use with existing automation systems.
6 HDMI 1.3 Inputs which process 480i/p, 576i/p, 720p-50/60, 1080i-50/60, 1080p-24/25/50/60, and VGA-SXGA@60Hz signals. One of the inputs is hidden on the "front panel". All HDMI inputs/outputs have increased spacing between connectors for cables with large overmolding.
Internal Universal Power Supply
Input Aspect Ratio Controls
•Presets: 4:3 full frame, 4:3 letterbox, 16:9 full frame, Panorama (non linear stretch)
•Flexible Horizontal and Vertical Zooming & Panning controls
•Overscan Adjustment per input with separate memories for SD and HD
Output Aspect Ratio Controls
•Presets: 4:3, 16:9
•Underscan Adjustment to eliminate Overscan inherent in a display
•Advanced time base correction (TBC) with frame synchronization
•High performance, multi-standard video decoder, 10-bit high dynamic range, deep color processing and 3D noise reduction (DNR)
•NTSC/PAL 3D comb filter
•Flexible Digital and Analog Audio switching and routing – 6 HDMI audio/video inputs, 5 assignable audio inputs (3 optical/1 coaxial/1 analog) with 1 HDMI audio/video output, 1 HDMI 'Audio Only' output, and 1 optical audio output.
•Preset output resolutions:
480p-60 (720x480@60Hz)
720p-60 (1280x720@60Hz)
1080i-60 (1920x1080@60Hz)
1080p-60 (1920x1080@60Hz)
576p-50 (720x576@50Hz)
720p-50 (1280x720@50Hz)
1080i-50 (1920x1080@50Hz)
1080p-50 (1920x1080@50Hz)
1080p-24 (1920x1080@24Hz)
VGA (640x480@60Hz)
Technical Specifications
Ten Video Inputs
• One Composite (NTSC/PAL/SECAM)
• One S-Video (NTSC/PAL/SECAM)
• One Component (YPbPr or RGB/S) processes 480i/p-60, 576i/p-50, 720p-50/60, 1080i-50/60, 1080p-60
• One Component/RGBHV (YPbPr/RGBS/RGBHV) processes 480i/p-60, 576i/p-50, 720p-50/60, 1080i-50/60, 1080p-60, VGA/SVGA/XGA/SXGA@60Hz
• Six HDMI 1.3 processes 480i/p, 576 i/p, 720p, 1080i, 1080p- 24/25/50/60, VGA/SVGA/XGA/SXGA@60Hz
Eleven Audio Inputs
• Six HDMI (HDMI v1.3)
• One Coaxial Digital (assignable)
• Three Optical Digital (assignable)
• One Analog Left/Right (assignable)
One HDMI Audio/Video Output (For Display Connection)
• Backwards compatible with DVI displays
• Configurable for YCbCr or RGB
• Also carries audio (HDMI v1.3)
Two Digital Audio Outputs
• One HDMI 1.3 'Audio Only' output for receivers with HDMI
• One Optical Digital for receivers without HDMI
Controls
• Backlit Universal IR remote control with direct input access codes and rear panel IR connector for RF-to-IR remote controls(mini-jack)
• Functions accessible via On Screen Display (OSD)
• USB port for service updates (not intended for new features)
• Fully programmable controls for each separate video input with non-volatile memories:
- Automatic input source detection & input priority selection
- Picture controls with memory for each input: Fine Detail, Edge Enhancement, Brightness, Contrast, Saturation, Hue
• Output Controls: Format/Resolution
Physical Dimensions (height x width x depth)
• 2.2" x 17" x 10.4" (26.3cm x 43.4cm x 5.5cm)
MSRP: $799
Orginele avsforum thread met nog veel meer informatie en uitgebreide antwoorden van DVDO medewerkers op vragen:
http://www.avsforum.com/avs-vb/showthread.php?t=1051246
Frank, gaan jullie deze ook voeren? Is er al iets te melden over een Nederlandse introductiedatum en Nederlandse verkoopprijs?
Denon DVD-3930, OPPO BDP-83, PS3, Xbox 360 HD DVD, Popcorn Hour C-200, Pro-Ject Debut III, Humax iHDR-5050c.
DVDO iScan Duo, Panasonic 42PZ80, Epson EH-TW2900, Arcam AVR350, Kef XQ30 :wub:
jowi
Leuk ding, mooie prijs... helaas niet weggelegd voor de CRT projector bezitters onder ons, aangezien er met de EDGE geen custom timings gemaakt kunnen worden. Gemiste kans denk ik...
In principe leveren we gewoon DVDo dus deze ook.
Erik
Je zou denken dat met het oplopend gebruik van BR hier niet echt een markt meer voor is.
- Winston Churchill
Tuurlijk wel, er zijn nog zat uitzendingen op TV, download films etc. die via een scaler een goede winst halen.
DAARNAAST helpt een scaler ENORM als je moet downscalen voor een display (als je een goede scaler hebt tenminste).
jasjenl
Kan dit ding nu ook natural-motion-achtige frame interpolatie doen? Of zijn daar andere apparaten voor?
Waarom zou je dat willen?
Ik vind het gruwelijk.
Het verpest de hele film.
jasjenl
#7
Quote from: celerontje on August  1, 2008, 15:22:43
Dat is jouw mening :) Ik vind beelden met natural motion achtige interpolatie er wel mooier uitzien, ik houd niet van de typische schokkerige filmlook.
Bovendien vroeg ik niet om een oordeel over dat soort technieken, ik vroeg of dit apparaat zoiets kan.
Ik denk dat je bedoeld om van een 3/2 pulldown film 24 fps te maken of 72hz.
Natural motion van philips van een tijdje geleden zorgt voor een behoorlijke achteruitgang van scherpte.
Durk
kan deze ook gebruikt worden als hdmi switch zonder enige vorm van beeldbewerking?
jowi
Zonde van het geld.... daar koop je 10 switches voor ;D
Durk
jasjenl
Quote from: J.A.F._Doorhof on August  1, 2008, 21:52:35
Nee, ik bedoel echt natural motion of soortgelijke technieken (IFC bij Panasonic, DMM bij mijn huidige Loewe).
roland p
Quote from: jasjenl on August  2, 2008, 13:16:04
Er bestaat hier een kastje voor. Ik heb 'm voorbij zien komen op dit forum. Ook heb ik in een review gelezen dat de resolutie hierdoor achteruit gaat. Helaas werkt dit kastje alleen met SD bronnen. Voor de PC heb ik Crystal Player gevonden welke aan 'Motion Morphing' doet, ook voor HD bestanden, helaas zonder ondersteuning voor ondertitels in mkv bestanden.
roland p
jasjenl
Ah ja, die Cinemateq heb ik wel eens eerder hier langs zien komen. Lijkt me echter inmiddels een wat verouderd apparaat, zowel qua aansluitingen als wat ie aan standaarden ondersteunt. Ze hebben dan wel een soortgelijk ding, maar die doet volgens mij niet echt aan motion interpolation.
bartvv
De adviesprijs in Europa is 799,- euro inclusief BTW
Leverbaar vanaf begin september.
We organiseren een 10% pre-order korting voor HTforumleden die een DVDO Edge bestellen vóór 31 augustus 2008. De prijs voor de Edge word dan 719,- inclusief BTW.
Distributeur van: Adeo projectieschermen, Barco residentieel, DVDO, Fortress bioscoopstoelen, Gefen, KanexPro, Optoma projectoren en schermen, Screen Excellence met geluiddoorlatend doek.
Mooi actie Bart...
Wel jammer dat hij geen 2:35:1 stretch heeft, dat zou hem ECHT interessant gemaakt hebben. Misschien in een toekomstige firmware update? Lijkt mij namelijk heel makkelijk om toe te voegen wat betreft functionaliteit.
bartvv
#18
Quote from: garmtz on August 13, 2008, 10:05:58
Mooi actie Bart...
Dee vraag was in het AVS forum ook gesteld, antwoord van Josh van ABT:
A 33% vertical stretch can be accomplished by using the Vertical Zoom control on the input.
Ik heb dit opgenomen in de wensenlijst, maar weet niet in hoeverre dit in een latere firmware beschikbaar komt.
bartvv
Mooi actie Bart...
Hierbij de reactie van ABT hierop:
2,35:1 won't be included on EDGE.
Although the 4:3 Letterbox button gives the desired results when the content is anamorphically encoded 2.35:1 content.
This includes anamorphically enhanced DVDs and all HD content/broadcasts.
PeterPan
De beta test periode van dit apparaat is inmiddels voorbij en de beta testers posten inmiddels hun bevindingen op AVSforum:
http://www.avsforum.com/avs-vb/showthread.php?t=1051246&page=38
Als ik me goed heb laten informeren moet de EDGE binnen ongeveer twee weken ook in Nederland leverbaar zijn.
Michel1973
#21
Deze Edge heeft een ABT2010 chipset aan boord, die ook gebruikt wordt in Oppo's Blu-ray Disc speler BDP-83  ;)
PeterPan
#22
De EDGE is inmiddels leverbaar in Nederland, volgens mij als een van de eerste landen ter wereld. Goed werk van Clofis!
Forum sponsor JVB Digital heeft ze op voorraad.
Ik zal binnenkort mij eerst bevindingen posten.
bartvv
Vanwege de gestegen dollarprijs wordt de adviesprijs per 1 december 2008 verhoogd naar 849,- inclusief BTW. Alle Edge video processors die worden besteld tot en met 29 november 2008 worden nog geleverd voor 799,- inclusief BTW.
Dirc
Jammer dat ie niet gaat werken op mijn crt tje.
Btw das waar ook de crystalio 1 staat er al tussen.
