Author Topic: Acoustiblok: "halve cm. isoleert geluid beter dan 30 cm beton"......  (Read 5476 times)
Offline Shorty
  • HT forum donateur
  • Trade Count: (0)
  • Gender: Male
  • Ze plane, ze plane!
Quote
[...]While others attempt various ways to stop or absorb sound, Acoustiblok has resolved the problem in a vastly different way. The soft 1/8" thick Acoustiblok is engineered not to stop or even absorb sound, but through a unique thermodynamic process Acoustiblok transforms the sound energy into trace amounts of heat!
Acoustiblok is made of a proprietary viscoelastic polymer material with a high density mineral content. As sound waves cause the Acoustiblok material to flex, internal friction occurs and the acoustical energy is dissipated into a very small trace amount of heat. The viscoelastic principle is isothermal for low frequencies and adiabatic for higher frequencies. This is truly a vastly superior method to using massive solid materials for stopping sound transmission.
Thus one 1/8" layer of Acoustiblok in a standard wall will result in more sound reduction than 12" of poured concrete! (Certified lab results.)
Recently a concrete block wall using a metal stud and Acoustiblok was tested by a well known NVLAP Certified audio lab. The results were remarkable: "We have never tested a wall assembly that achieved such a high sound transmission loss rating... it even exceeded the testing capabilities of most laboratories!"  Truly a revolutionary material, so revolutionary that it was given the first place award for sound abatement in Britain's House of Commons!
Acoustiblok, is not only an incredible sound isolation product, but can be easily installed without construction changes, special tools, or skilled labor and is U.L. approved for use in 277 fire-rated wall and floor/ceiling configurations (see U.L. Classifications).  Simply cut it with a box knife, staple or screw to studs, and ensure airtightness.
Bron: Acoustiblok.
Als het te mooi klinkt om waar te zijn, dan..... (En let ook op de toupet van 'president and founder of Acoustiblok Inc.'  :P )
Maar ze beroepen zich wel op "STC, IIC, and NRC ratings from independent lab test reports"....
VrGr,
Bart J.
Offline Shorty
  • HT forum donateur
  • Trade Count: (0)
  • Gender: Male
Re: Acoustiblok: "halve cm. isoleert geluid beter dan 30 cm beton"......
« Reply #1 on: December 11, 2007, 10:47:26 »
Het Amerikaanse bedrijf heeft ook een Duitse website. Daarop wordt beweerd dat ze hun produkt niet alleen aan de USAF, GM en twee Trump Towers hebben geleverd, maar ook aan "Parlamentsgebäude Amsterdam".  ???  :P
VrGr,
Bart J.
Offline Joep
  • HT forum legend group
  • Trade Count: (0)
  • Gender: Male
« Reply #2 on: December 11, 2007, 11:17:43 »
Misschien te mooi om waar te zijn, maar als ze maar de helft doen van wat ze beloven is het nog steeds mooi. Ik ben nu aan het verbouwen in mijn nieuwe huis, dus heb er op zich wel oren naar.
Het is niet goedkoop: prijzen zijn vanaf € 61,29 voor een stuk van 200x68cm. De Heavy Duty-versie (2 x zo dik) kost voor ditzelfde stuk € 87,-.
Houd ik in gedachte!  :)
Offline Shorty
  • HT forum donateur
  • Trade Count: (0)
  • Gender: Male
« Reply #3 on: December 11, 2007, 12:42:07 »
Als je hard genoeg afspeelt bespaar je natuurlijk wel een hoop op verwarmingskosten.  O0
VrGr,
Bart J.
Offline Joep
  • Trade Count: (0)
  • Gender: Male
« Reply #4 on: December 11, 2007, 13:11:49 »
VrGr,
Bart J.
Haha, ja het geluid wordt omgezet in warmte idd. Ga ik het boven ook gebruiken op de vloer!  ;D
Offline Franky P.
  • full member
  • Trade Count: (+5)
  • Gender: Male
  • Nix is wat t lijkt!
« Reply #5 on: December 11, 2007, 22:50:00 »
wrsch idd te mooi om waar te zijn
een paar dingen die me opvallen aan de website: er wordt veel met ingewikkelde termen gesmeten, je wordt dood gegooid met bijna onleesbare grafiekjes, sommige zonder aanduiding van eenheid bij de x en y as, er worden niet echt vergelijkbare muren met elkaar vergeleken en er worden vooral veel grote namen als referentie gebruikt en een schreeuwerig design van de website ipv rust.. het zou echt kunnen zijn, maar het zijn allemaal typische kenmerken die ook bij een hoax horen.. blijkbaar is er erg veel overtuigingskracht nodig. Als het echt zo fantastisch spul is spreken de cijfers voor zich en kan je toe met enkle harden feiten en niet zon toestand
daarbij kan het denk ik technisch nie werken zoals ze claimen. tuurlijk is bekend dat een massa/veer/massa systeem een veel grotere isolatie per dikte-eenheid kan bereiken dan pure massa maar die liggen niet zover uit elkaar als hier beweerd wordt
een voorbeeldje: er wordt een houten-balken-met-gipsplaat-muur getoond met tussen de balken en de gipsplaten een laag van dit goedje. in zon constructie kan dit al niet maximaal isoleren: trillingen opgevangen door de gipsplaten zullen door de gebruikte schroeven/nieten om ze aan de balken te bevestigen direct hier aan doorgegeven worden en daar helpt zon laag acoustiblok, waar de schroeven dwars doorheen gaan, niets tegen.
denk ik
maargoed wie ben ik...
Thingman??  :D ???
gr Frank
Offline SpeedyAndré
  • Surrounded by Infinity 7.1 and members of the
  • Trade Count: (+6)
  • Gender: Male
  • Only 1080p CRT's => nu met 3D!
    • Opbrengst zonnepanelen 2350Wp
« Reply #6 on: December 11, 2007, 23:23:02 »
Thingman is niet zo zeer met isolatie bezig maar meer met verbeteren van de akoestiek :)
Een van de toepassingen van acoustiblok is op deze manier:
Waar je normaal alleen glaswol gebruikt zit nu acoustiblok achterop de laag gips.
Het is dus niet een vervangend goedje maar aanvullend in een bestaande situatie :)
Zelf heb ik goede ervaring met het gebruik van Merford dempende regels en strips, hiermee bevestig je een laag gips vrij makkelijk zwevend.
Acoustiblok doet ongeveer het zelfde, nl. het contact tussen het gips en de regels op de muur minder direct maken.
Ik zie er geen wondermiddeltje in dat het beter doet dan bijv. een complete constructie met Merford materiaal.
André  8)
Northstar Extremo Monster Sigma 2K Xtc powercords Sphinx PJ8 Straightwire Virtuoso Aragon Palladium Infinity Renaissance 90 Onkyo Tx-NR1009 Oppo BD83 Sony Bdp-S790 Toshiba HD-XE1 PS3, Soundaware D100 pro Optoma 3D-XL
Infinity Kappa center B 4x Kappa Video II SVS PB12ISD 3x! Sony 1292 Moome box Sony HW30ES Harmony hub TX-P42U10E VU Duo Eminent 7380 3D player 8TB DS410 6tb WD my cloud
All electric house: 2x Toshiba Daiseikai 8 3,5kW Bosch inductie Itho 80l boiler Grohe red duo 8l 5050Wp op dak
Offline Eric Desart
  • Fysisch Akoesticus: ±35 j.
  • full member
  • Trade Count: (0)
« Reply #7 on: December 12, 2007, 14:44:50 »
Zijn hier ergens meetrapporten van te vinden?
Groetjes
Eric
« Last Edit: December 12, 2007, 17:28:00 by Eric Desart »
Vriendelijke groeten
Eric Desart
Vragen inzake geluidsisolatie of akoestiek horen hier thuis in het forum, niet in of via persoonlijk berichtjes.
Zo leren we allen van elkaar.
Offline Niet actief
  • Trade Count: (0)
  • Gender: Male
« Reply #8 on: December 12, 2007, 16:44:55 »
Thingman??  :D ???
gr Frank
André heeft gelijk...
Geluidsisolatie is een volkomen ander vakgebied of specialisme als akoestiek.
Ik heb redelijk wat ervaring met geluid dat binnen mag blijven, maar nauwelijks met geluid dat de neiging heeft naar buiten uit de ruimte te treden...
Offline Franky P.
  • full member
  • Trade Count: (+5)
  • Gender: Male
« Reply #9 on: December 12, 2007, 20:15:54 »
@ thingman: my bad, ik dacht dat je ook isolatie e.d. deed :-)
(Image removed from quote.)
André  8)
Ik ken ook de IVI_regels , die zullen denk ik ongeveer hetzelfde werken als de merford regels die je bedoelt. Alleen daarbij is de constructie heel anders. dan wordt namelijk het gips opgehangen aan de regel en de regel via vilt aan de balken, daarmee is er dus geen direct contact met de balk constructie, en is de wand volledig zwevend t.o.v. de constructie. En zon systeem werkt al niet zo goed als 30 cm beton. Dus het lijkt me erg sterk dat acoustiblok dat wel doet terwijl zon gipsplaat nog steeds met een starre verbinding (schroeven) aan de balk zit en dus ongehinderd alle trillingen kunnen worden doorgegeven..
anywayz kben een beetje sceptisch
gr Frank
Offline SpeedyAndré
  • Trade Count: (+6)
  • Gender: Male
« Reply #10 on: December 12, 2007, 21:03:06 »
Een dikke laag beton an sich is ook geen goede isolator, veel gewicht is geen garantie voor een goede isolatie  ::)
André  8)
Offline Niet actief
  • Trade Count: (0)
  • Gender: Male
« Reply #11 on: December 13, 2007, 01:11:44 »
Vraag het eens aan Patrick vd B, die hier toch vast ook nog wel meeleest...
Patrick?  :)
Offline Eric Desart
  • full member
  • Trade Count: (0)
« Reply #12 on: December 14, 2007, 12:47:27 »
Voor de geïnteresseerden:
Het materiaal waar je naar kijkt is wat Engelsen refereren als MLV (Mass Loaded Vynil)
Dit is meestal een soort van PVC (soms ander basis product) verzwaard met mineralen om de densiteit op te drijven.  In basis hebben dergelijke materialen een soortelijk gewicht (afhankelijk van type) tussen 1.1 en 1.4 kg/dm3.  Deze verzwaring verhoogd de densiteit met ca een factor 1.8.
In feite werkt dit zoals roofing (bitumen).
Het voordeel van een dergelijk materiaal is hoge interne damping.
De effecten zijn echter beperkt.
Dat is ook de reden dat je daar geen enkele sezieuze meting of vergelijkende meting op zie staan.
Het gaat te ver om de physica hiervan in detail uit te leggen.
Hoe dan ook, vanuit physisch wetenschappelijk standpunt is dat een vreselijke site en zéér misleidend.
Commercial hype ten top.
Die vergelijking met 30 cm beton, zonder duidelijke definitie over het hoe, wat, waar is complete onzin.
Op de Green Glue site zijn trouwens dergelijke toepassingen gemeten (met officiele meetrapporten).
http://www.greengluecompany.com/
Dergelijke materialen zijn hier ook standaard gekend (ook door Merford).
Zolang je op kamertemperatuur en daarrond zit, is roofing zonder die steentjes op even goed (alleen opletten met brandeigenschappen).
In feite kan je haast veilig stellen, dat een site waar objectieve meetgegevens en vergelijkingen totaal ontbreken en vervangen worden door verhaaltjes en pseudo-wetenschap tot enorme terughoudendheid moet aanmanen.
Gewoon grapje: als je dergelijke folie op die betonnen muur zou kleven, of op die zware betonvloeren, kan je gemakkelijker het geld hiervoor op die beton kleven (is sneller en vraagt minder energie). Het effect zal ca gelijkwaardig zijn (of die betonwand zou lek geweest zijn als een zeef).
« Last Edit: December 14, 2007, 13:13:37 by Eric Desart »
Eric Desart
Offline SpeedyAndré
  • Trade Count: (+6)
  • Gender: Male
« Reply #13 on: December 14, 2007, 13:03:25 »
Duidelijk, een laag van dit spul achter de gipsplaten van mijn zwevende wandje zou dus weinig doen, behalve m'n bankrekening wat lichter maken  ;D
Overigens heb ik geen ruimte voor een nog dikkere wand, het past allemaal maar net ;)
André  8)
« Last Edit: December 14, 2007, 14:15:59 by SpeedyAndré »
