Playstation 3 Algemeen
Started by aMUSEd, April 2, 2007, 20:40:36
Djang
Nieuwsgroepen, je kan een USA account aanmkaken als je een bestaand adres kan verzinnen in Amerika.
ZO weet ik nog meer handige tricks.
http://www.ps3-media.nl
receiver: denon avr-x2000 , speakers: wharfedale diamond 8 serie, plasma: LG 50pz250, kabels: qed, console: wii u,
angel66
nou net mijn eerste HD serie bekeken.
Bones .......very nice ;D
LittleNinja
#52
Toch hier nog een keer dezelfde vraag...
Welke overeenkomsten vertoond de PS3 met de PixelMagic HD MB200?? Is de MB200 nagenoeg overbodig met de eigenschappen van de PS3??
LN
corival
10 PS3 tricks Sony doesn't tell you
QuoteGot a PlayStation 3? For those of you that have picked up Sony's shiny black plaything, we've put together a Digital Home top ten of tips that you won't find in the user manual.
1) Play games from any country
Harbouring a desire to play Super Gaiden Ninja XI? Now you can. In fact, you can handily play any PS3 game from any country. On holiday in the States and spot the latest release at a bargain dollar-to-pound price? Help yourself. So far, at least, PS3 games aren't being region coded. That said PS2 and PS1 games are so you can't play a US title on a Euro console.
And let's not forget that Blu-ray movies are region-coded so the barriers aren't completely down yet. Advertisement
2) The secret video reset
One of the most annoying aspects of the PS3 are its video settings. Take it up to the bedroom portable or round to a friend's house and there's a good chance that you won't be able to see anything onscreen because your 'new' TV is running at a different resolution or using a different cable connection. And - because you can't see anything - you can't change it. Until now. Shut down your PS3 then restart by pressing and holding the power button. This will reset your PS3 to its most basic 480p graphics mode so you'll be able to see enough to choose RGB SCART, component, HDMI or whatever from here.
3) See how much charge is on your pad
There's no indication of how much charge is left on the pad itself. Instead it appears on screen during games. Press and hold the PS button on any joypad. An indicator will appear, showing your pad's charge as a small battery. A full battery pic means a fully-charged pad. Neat.
4) Download game saves
Chances are someone out there has already beaten that boss for you and saved their game afterwards. Why not take advantage of it? Google 'PS3 game saves'. There are hundreds of finished and half finished game saves scattered all over the internet. Download the save you want - it'll come in a 'PS3' folder that you can lift onto a USB stick and put into your PS3. Go to the Game menu, choose your stick and the game save you downloaded should be right there. Press Triangle to copy it to your hard drive.
5) Make free video phone calls
You will need a USB headset (like the one you use for PS2 Socom) and an EyeToy camera. Plug in both via USB then go to your Friends menu. Choose a friend you've signed up earlier and press Triangle. Choose Start New Chat and type a message. Something like 'Videochat?' should do the trick. Now, providing they're in front of their powered-up PS3 (perhaps you could text them to tell them to be in position?) then they'll see your message and be given the option to accept your videochat.
Now, provided they too have a camera and headset, two windows will open, one showing you (so you can make sure you're looking your best), the other displaying your mate. Best of all you can hit Triangle again and invite more people to join your chat - up to a maximum of six. And the cost? Not a bean above your usual broadband connection charges.
6) Browse multiple Internet windows
Open the browser (go to Network) and surf to a page you want. Now open up the menu with a press of Triangle and choose 'Open In New Window'. Enter another URL and then do the same again. Keep going until you've got six windows open. Now press L3 (done by clicking down the left stick). You're now in multi-page mode. Move the left stick to flick through the web pages as though they were bits of paper, then click L3 again to zoom in.
7) Upgrade your hard drive
We took the drive out of our PS3 and found it to be a Seagate Momentus 5400rpm 60Gb 2.5inch SATA drive. We swapped ours out effortlessly for a Seagate Momentus 120Gb 2.5inch SATA drive and it worked perfectly. Remove the cover flap on the bottom of your PS3 with a fingernail. Undo the blue screw and slide the drive over to the right and out of your PS3. Undo the four screws on the 'caddy' and remove the old drive.
Put your new drive in the caddy (it should be exactly the same size, of course) and re-do the four screws. Slot it back in and slide to the left to make the connections. Re-do the blue screw, pop the cover back on and restart your PS3. Say 'yes' to the message on screen and voila - new super-size hard-drive. (Go to Settings, System Settings, System Information to check).
8.) Share your bought downloads
You can download anything you've bought from the store to five PlayStation 3's. This is useful if you've got more than one PS3 (of course) and also if you've wiped your hard-drive and don't fancy paying for the same download twice...
However, you can also choose to share your download with your mates. The PlayStation Store logs how many times each download has been downloaded by each user. On your mate's PS3 Create New User and log onto the store with your ID. You'll now be able to go to your download and see that you've already downloaded whatever it was that you paid for. You can now download it again, using another of your downloads and giving it to your mate for free. Or a small optional charge...
9) Force a PS3 to show your files
Put your photos in a folder called 'PICTURE' or your videos in a folder called 'VIDEO' or simply *force* your PS3 to look at your files on your stick regardless of what you called them or where you put them. Insert your stick and go to the menu option you want (Photos, Music, whatever). Press Triangle to bring up a menu and choose Display All. This will show every file on the stick. It even works for a plugged-in iPod, though the multi-folder structure you'll reveal is a bit baffling. Still, your songs are in there if you've got the patience to find them.
10) Change your album art
When you import a music CD your PS3 automatically pulls down the album art and stores it with the tracks. Occasionally it gets it wrong, however, or it may simply not be able to find the art of your hipper, less commercial tracks. This is easily fixed however. Download a pic of the art you need as a jpg on your PC and put it onto a stick (in a folder called PICTURE, ideally). Copy it to your Photo menu (press Triangle). Now go to Music and select the album folder with the offending art. Press Triangle and select Information. Go to the Photo menu and select your new picture. Bingo.
Words by: Dan Griffiths
bron: http://www.tech.co.uk/digital-home/general/blogs/2007/04/06/10-ps3-tricks-sony-doesnt-tell-you
Pioneer PDP-LX508D  |  Emotiva UMC-1  |  Emotiva XPA-5  |  Crown K1  |  PS3  |  PS4 | Apple TV4 | Humax iHDR-5200C  |  Olive One |  Audiophysic TEMPO 25 / CELSIUS HHCT II / STEP  |  SVS CS-Ultra  |  Finite Elemente Modul Classic  |  Kabels Emotiva X-Series  |  Harmony Ultimate
angel66
Gaeje
Rob_Dingen
Hoi
Weet iemand al of er een regiovrij oplossing voor blu-ray is?
angel66
nee.
maar vele blu-rays zijn afspeelbaar op andere regio,s.
hier is een site met een lijst.
http://bluray.lindsite.dk/
Mrwhoopie
Ik heb dus al even de ps3 en het is tijd voor een upgrade ;D,ik wil een toetsenbord en liefst een mooi.
Dus vandaag naar de winkel geweest en morgen mag ik deze gaan afhalen
Nu hopen dat dat ook gaat werken.
LittleNinja
Quote from: Mrwhoopie on April 11, 2007, 17:18:26
Die is cool! Draadloos, toch??
aMUSEd
#60
WOW, nice!.. nu nog een muis en dan kan je helemaal lekker FPS-en ;D
Wat kost zo'n keyboard eigenlijk?
Mrwhoopie
Neen de muis zit bij op het klavier ;),en idd draadloos.Ik hoop maar dat het gaat,normaal gezien wel.
en als je hem niet gebruikt moet je hem zo dus opladen
dat gaat weer mooi staan in de living ;D,hopelijk vind de vrouw dat ook.
riwi
Ik probeer de video streaming aan de praat te krijgen met de ps3.
Ik heb het hfs 2.1d progje gestart op de windows PC.
Ik zie niet de drie folders waar angel66 het over heeft (in de andere ps3 thread).
Ik zie alleen de root /. Ik kan folders toevoegen : menu -> add folder from disk
Dus ik maak in het hfs tooltje onder / een folder VIDEO aan en voeg daaronder mijn D en E drive van de XP PC toe.
Als ik op de ps3 in de browser nu de http://192.168.1.2 kies dan zie ik inderdaad alle files op de drives staan.
Bij zowel .avi als .ts bestanden krijg ik alleen de melding : "insert storage media at the save destination"
Wat doe ik hier fout? Jullie hadden de video streaming toch al werkend? Ik kan wel wat tips gebruiken :)
NeonKnight
Hoi,
Ik heb sinds kort ook een PS3.
Prettig apparaat, in de meeste gevallen erg gebruiksvriendelijk.
Heb ondertussen ook yellowdog linux geinstalleerd, alleen nu blijkt wifi op dit moment niet te worden ondersteund... Dat vind ik wel jammer.
Anyways: ik heb me aangemeld aan het playstation network én daarnaast nog een keer via een pc.
Toch krijg ik nog een bericht dat áls ik me aanmeld, ik de blu ray disc van casino royale ontvang...
Heb ik me nou wél of niet aangemeld?
Bvd,
Koen.
Meridian 565 z3 | Classé CAV-75 | Eichmann six interlinks | Monitor audio in-wall en in-ceiling speakers
Uitje
Ik heb me alleen aangemeld via m'n ps3 en kreeg na een aantal dagen een bevestigings email dat ik recht had op Casino Royale. Ik zou het dus even een paar dagen afwachten en kijken of je ook een mailtje krijgt.
Quote from: NeonKnight on April 12, 2007, 12:43:04
Hoi,
Bvd,
Koen.
aMUSEd
Quote from: Uitje on April 12, 2007, 13:44:51
Ik kan het mis hebben maar geldt deze aanbieding niet alleen voor de eerste 500.000 eigenaren in Europa?
In een bericht van een paar dagen geleden stond dat ze de 500.000 al gepasseerd zijn.
Zou toch wel jammer voor je zijn.. :-\
Mrwhoopie
Het toetsenbord werkt dus mega goed,allen vraag ik mij af of je ergens de layout van het beeld kan aanpassen want nu komen de internetpaginas maar raar op het beeld hoor.
aMUSEd
Quote from: Mrwhoopie on April 12, 2007, 20:12:27
Dat heb ik dus ook.. heb je toevallig een gewone beeldbuis? Ik heb ergens gelezen dat de weergave van het beeld bij internet wordt aangepast afhankelijk van de resolutie waarop de PS3 is ingesteld.
Bij sdtv wordt het beeld opgehakt en uitvergroot zodat de tekst beter leesbaar is.
LittleNinja
Quote from: aMUSEd on April 12, 2007, 15:25:58
er waren er toch maar 50.000 ?!?!  ::)  ::)
Mrwhoopie
Quote from: aMUSEd on April 12, 2007, 21:44:18
Idd gewone beeldbuis.AL die platte dingen zijn nog ni wa ik er van wil hebben ;D
aMUSEd
Quote from: LittleNinja on April 12, 2007, 21:48:03
Europa: 910,000 PS3's!
Zoals al eerder in een berichtje stond had Sony 2 dagen na hun Europese launch al meer dan 600,000 PlayStation 3's verkocht, nu is er na iets meer dan een week na de launch het aantal gestegen naar 870,000 verkochte consoles. Hiermee is de Playstation 3 de snelst verkochte console in de geschiedenis van gaming consoles.
En nu is er op dit moment via VGChartz duidelijk geworden dat het aantal is opgelopen tot 910,000 verkochte units in Europa, op naar de miljoen Sony! Dit is toch wel tegen veel verwachtingen in, ondanks de hoge prijs heeft de Japanse gigant dus helemaal geen problemen hun console aan de mensen kwijt te raken. Het totaal staat nu op 3,15 miljoen, in de volgorde: 1,37 miljoen in Amerika, 870,000 in Japan en 910,000 in Europa.
Bron: DGS-online
aMUSEd
Quote from: Mrwhoopie on April 12, 2007, 21:50:32
Dat heb ik nou ook elke keer als ik de schermen zie spelen ;D
Joris1971
Quote from: Djang on April  9, 2007, 12:25:55
..... als je een bestaand adres kan verzinnen in Amerika.
Knap hoor, hoe verzin je iets bestaands?  ;D ;)
LittleNinja
Gaeje
Quote from: aMUSEd on April 12, 2007, 21:51:19
Bron: DGS-online
shit... serieuze inhaalbeweging precies in europa, op een paar weken tijd!!
