Started by Peerless Monster, April 8, 2006, 12:34:24
Marco66
#17000
Een mooie Denon PMA-2000ae als basis voor mijn stereo setup.
Erg benieuwd naar deze bak, ziet er ieg indrukwekkend uit!
Morgen ophalen.
Marco
sultankat
Quote from: Marco66 on June  7, 2017, 10:15:33
Morgeen ophalen.
Marco
Gefeliciteerd, heeft ook mijn aandacht als vervanger in de tweede set.
Quad Artera Play Plus + Quad Elite QMP mono's | NAD PP2e Phono preamp | Thorens TD147 + Ortofon OMB 20 | Audizio tuner | Innuos ZEN mini MK3 streamer +  Innuos voeding | Meze Audio 99 Classics | Tannoy D700 speakers | Wireworld Mini Eclipse 8 speakerkabels |  | Van den Hul Digicoupler | Ansuz digital cables | Shunyata power cables | Vibex powerblock
patsijb
Sopper
Vrijdag mijn Lejonklou Tundra Tarandus upgrade ophalen  :)
Nu ook een Lejonklou Kikkin 2.2 als pre erbij gekocht, als step-up naar de Sagatun voorversterker.
Kikkin is a remote controlled volume control in stereo.
The purpose of Kikkin is to offer maximal sound quality at a minimal price for those who primarily use one source in their HiFi system. 98% of the costs of a Kikkin is sound related and 2% make sure it's functional and easy to use.
Kikkin has four functions, all controlled by remote: Raise volume, decrease volume, temporarily lower the volume and full mute. A coloured light on the front indicates which is the current volume setting. As the colour can be seen from a distance, it's far easier to read than a conventional display.
Why does Kikkin sound so good?
* Minimalism: Kikkin consists of two inputs, one high quality volume control, two powerful output stages that can drive almost anything and a separate optimised circuit for logic and control.
* Optimisation: Each and every unit is measured, listened to and fine tuned to perform optimally. This not only raises its performance, but also make different specimen sound almost identically.
* Power supply: The power supply of Kikkin has been developed during a long time. The aim has been to make sure it doesn't interfere with the musical signal.
* Circuit board: A careful layout has a large impact on sound quality. Kikkin has eight different ground planes to minimise all possible negative effects on the musical signal.
* Enclosure: The functional small enclosure is optimally damped and all fasteners are tightened with a torque tool. Even the feet are chosen for best sound performance and are adjusted so that the case sits perfectly stable on a flat surface.
* Upgradeable: If we find a way to improve the circuits of Kikkin, older units will be possible to upgrade to the latest specification. We are very proud of this unique policy.
# Lejonklou Källa - Streamer # Lejonklou Sagatun Mono 1.7 - Voorversterker x2
# Lejonklou Tundra Mono 3.0 - Eindversterker x2
# Graham LS8/1F - Luidsprekers
# Bekabeling - Trivium Audio Cables
Marco66
Morgen ophalen.
Marco
Gelijk maar bijpassende streamer er bij gekocht, kon hem niet laten staan voor het geld.
De DNP-730ae.
Marco66
Morgen ophalen.
Marco
Net aangesloten, pff wat een beest!
Dacht dat mijn Lexicon pre het aardig deed in stereo maar is toch geen partij met deze versterker!
Morgen de streamer binnen en verder testen.
Marco
hpapen
Liep toevallig tegen een pathos cinemax aan- kon hem niet laten staan vanwege de looks.
Sopper
Quote from: Sopper on June  7, 2017, 14:56:40
Zo... die Fredrik Lejonklou weet wel wat ie ontwerpt en bouwt zeg..
Heb de Majik DSM/2 nu met line out naar de Lejonklou Kikkin pre
Sommige ruimtelijke opnames lijken wel surround, alsof ik nog luidsprekers achter me heb staan
Ongelooflijke soundstage...
Nadeel is dat ik nu toch echt de Sagatun preamplifier moet kopen  >:(
Als zo'n klein doosje dit met de muziek doet, dan wordt het met de Sagatun echt smullen.
Rudi64
Quote from: Sopper on June 14, 2017, 20:15:39
Vroeger ook lang eens getwijfeld om een kikkin aan te schaffen, bijna bij alle reviews
was de tendens dat deze op Akurate kontrol niveau presteerde..dus heel wat voor zo een klein doosje.
Nadeel was voor mij het gebruiksgemak en het gelimiteerde aantal aansluitingen.
Geniet ze.. :music:
Linn MDSM/2 ◼ Linn Majik Exaktbox I Katalyst.◼ Linn M109 speakers-◼ Linn K400 speakerkabels ◼BlueJeans 6a ethernet cables/ Iso Acoustics mini pucks.
Sopper
Quote from: Rudi64 on June 14, 2017, 20:59:18
Geniet ze.. :music:
Heb met een dsm maar 1 ingang in de pre nodig  ;)
Hans47
Mitch--
Harbeth Compact 7ES-3 40th Anniversary-Lejonklou Källa-Lejonklou Superkikkin-Lejonklou Tundra 2.5-Linn K400 'Lejonklou spec'
Marco66
#17012
Mooie demoset speakers, Highland Audio Dilis 4405.
Nog niet eerder gehoord, lekker luistersessie gehad en verrassend goede speaker voor het geld.
Strak laag en mooi afgestemd, ook afwerking is gewoon top.
Morgenochtend aansluiten op de Denon en kijken of het hier ook zo goed klinkt.
Marco
Marco66
Set staat inmiddels aangesloten en klinkt gewoon erg goed.
Nu op gemakje nog wachten op een mooie bijpassende Denon sacd speler voor leuke prijs.
Marco
modde239
Quote from: Marco66 on June 16, 2017, 11:54:52
Marco
Wat zie ik.....sluikreclame op je scherm...... :D
Marco66
Quote from: modde239 on June 16, 2017, 13:16:34
Ja haha, startte net op 😀
Nosferatu
Marco
Als bezitter van z'n nieuwere broertje (PMA & DCD 2020AE set) zou ik in jouw geval eens kijken naar een DCD-1520AE. Een 2000 serie SACD speler doet het niet beter, is alleen intern mooier opgebouwd (dubbele voedingen enzo) maar gehoormatig praktisch identiek. Knap als je verschil hoort.
Marco66
Quote from: Nosferatu on June 16, 2017, 17:09:30
Dank voor de tip!
frits marantz
Mooie set Marco66. Genieten maar. :pompom:
Marco66
Quote from: frits marantz on June 17, 2017, 08:01:32
Thanks, gaat lukken.
Nu de ht set compleet en stereo bijna haha.
Marco
Siddartha
Een setje Sonus Faber Venere 2.5
Naast de geweldige looks ook een geweldige sound.
Voor de SF en eigenlijk FS puristen niet conform de originele huisstijl qua klank, maar aangezien ik daar onvoldoende bekend mee ben, is dat geen probleem [emoji4]
Sirius666
Dat staat heel wat beter dan boekenplankspeakers hoor  ;)
Erg fraai deze SF. Hoe zou je de sound omschrijven?
Marco66
Quote from: Siddartha on June 17, 2017, 21:21:58
Prachtige speakers!
Siddartha
Quote from: Sirius666 on June 17, 2017, 21:40:48
Ja hahaha, het is dat we wat ver uit elkaar wonen, anders was ik echt komen luisteren!
Tja, ik vind dat altijd lastig, maar goed laat ik eens proberen [emoji4]
Wat mij opvalt is dat ik een betere plaatsing van de instrumenten hoor, meer los van elkaar dan een 'brei'.
Verder hebben ze een lichte boost in het midlaag (zonder te meten gok ik rond de 300 hz). Dat maakt het wat warmer. Uit ervaring met mixen weet ik dat een eq boost rond die frequentie naast warmte ook de lage frequenties er meer uitspringen en dat klinkt wel lekker.
Het hoog is zeker niet te pittig, maar voldoende aanwezig.
Het midden vind ik mooi gedetailleerd, vooral vocalen klinken erg mooi al heeft de boost in het midlaag wal het effect dat het iets wolliger klinkt bij sommige opnamen.
Maar over het algemeen klinkt het gewoon lekker, en vooral muziek á la Diana Krall erg goed.
fasteddie
muziek á la Diana Krall klinkt overal erg goed.......
