Zidoo player
Started by skank1, September 16, 2015, 14:15:53
skank1
Deze best in het oog houden..
Niet zomaar de zoveelste android mediaplayer....
Shell Material: Plastic
CPU Model: Rockchip R3368 Octa Core up to 1.6GHz (Cortex-A53 64bit)
Operating System: Android 5.1, Built in Google Play Store,Support OTA Function
GPU: SGX6110; support 4K*2K H.265/H.264
Memory: 2GB DDR3
Internal Storage: 16GB eMMC
Wifi Connectivity: IEEE 802.11a/b/g/n/mimo, 4.900 GHz ~ 5.845 GHz (5.0 GHz ISM Band) AP6335 dual-band WIFI,802.11ac
Ethernet:1 * RJ-45 Ethernet Jack (10/100/1000Mbps)
Bluetooth: BT 4.0
HDMI Port: Standard HDMI female, v2.0 Support 4K@60fps
Other Interface:
1 * TF card reader SD card interface . Support 1GB/2GB/4GB/8GB/16GB/32GB
2 * USB 2.0 port(one could be a OTG port)
1 * IR receiver
1 *Composite video and audio port
1*S/SPDIF (2CH, 5.1CH)
Power: DC 5V/2A
What's in the box:
1 x TV box
1 x Romote control
1 x HDMI cable
1 x Power adapter
1 x User manual
As you can see, each model is pretty rich in sense of design with distinct characteristics that designed by ZIDOO.Deeply optimized system, hardware-decoding capabilities and continuous update services. Right now,we also inject these characteristics into the new model. It's based on Rockchip 3368, not only high-performance, but also unique.
64-bit
ZIDOO X6 Powered by Cortex-A53 Rockchip 3368 Octa-core CPU,
into 64-bit era,Because of 64-bit CPU,address space can be up to 64GB
processing speed and width are double too.64-bit can dramatically affect the OS application and the whole industrial structure.
2G+16G
2G DDR3 make big games run more smoothly
The utilization of eMMC memory offers an array of benefits in terms of performance security and reliability, a richer end-user experience
WIFI
ZIDOO X6 use Broadcom AP6335 dual-band WIFI,It supports IEEE 802.11a/b/g/n/mimo, 802.11ac,2.4GHz/5GHz. It can achieve up to a speed of 433.3Mbps withe single stream in 802.11ac draft to connect to the wireless LAN
1000M network interface
carry 1000M network interface
4K image, carefreely shows in front of audience with 10 times speed through
current mainstream 100M ,without any pressure limit
BT 4.0
ZIDOO X6 is embedded with Bt 4.0 module
It can reduce 3 miliseconds delay
the transfer-distance can be more than 10 meter,and support AES-128 coding.
It is compatible with 2.0,2.1 and 3.0 all BT standards
HDMI 2.0 4K*60p
ZIDOO X6 supports hdmi output with the resolution 4K*2K@60fps
ZIDOO choose the high-end HDMI cable as standard accessories to match X6
You can enjoy large-scale games which require UHD frame rate@60fps
can enjoy 18Gbps data transfer and 12-Bit real-color without any data losing on ZIDOO X6
PMU
Built-in ZIDOO unique PMU power management chip, ZIDOO X6 can achieve completely switch IR Contral and dormancy function
It is the first Android TV BOX support auto power off and standby
Android 5.1
Pre-installed Android 5.1 Lollipop,after ZIDOO depth optimization, ZIDOO X6 can offer smoother multi-tasking for users to switch among applications easily and offer more security
Unified storage
ZIDOO X6 original firmware uses unified storage,
more available space than other device,you can install more applications
Support 4k*2k H.265
Hardware Decoding
ZIDOO X6 offers 4K*2K UHD video playback, support 4K@60fps
support HD Audio(7.1CH)、24P frame rate switch freely
Pre-installed ZIDOO customized KODI 15.0 Isengard support Hardware decoding
BD-ISO and 3D BD-ISO
BD rips in BDMV format and ISO are supported for playback.3D BD-ISO rips are supported.
Subtitles in BD rips are supported.All BD supports are via customed BD-Lite menus,not the original disc menu.
ZIUI
By ZIUI, you can use the most simple operation to manage applications, files, set the parental lock, speed system, everything goes with the flow
Certainly, it is pretty nice
ZIDOO MEDIA CENTER
X1 has been built-in the programpaket of ZIDOO MEDIA CENTER,
which costs ZIDOO a whole year to develop
It’s been never so simple to operate album, manage files, play music, access to LAN.
During using a number of features, you would know how powerful it is
Airplay,airmirror,DLNA,miracast,zidoo rc,google remote all in one!!
ZIDOO RC
Through ZIDOO RC, you can use your favorite operating way to control X6 with your cell phone
IR Shortcut and learning
The new smart IR remote with progrmmable keys offers a great easy way
to control not only the X6 Octa-core but also the TV at your home
It also supports three programmable color-keys that customizes to open apps quickly
Support HDMI CEC Control
Cloudfront CDN------Ota
We use the global Cloudfront CDN services, you can easily and stably to get OTA upgrade
in any corner of the world. You will see, our active and iterative firmware. All of these are free
As always support software update, in response to users community, regularly update firmware
skank1
Raymond187
Quote from: skank1 on September 16, 2015, 14:17:01
HD-audio, android tv, 3d iso support alles binnen kodi en zonder externe speler !!
Dat is de eerste mensen !
Features:
Wilde net vragen?
DTS-MA?
skank1
Quote from: Raymond187 on September 16, 2015, 14:20:35
Wilde net vragen?
DTS-MA?
Ja !!!! Binnen kodi !!
Verschil deze speler tov himedia
Het grootste verschil is dat himedia een wrapper gebruikt om hd audio en 3d te ondersteunen (waardoor je onafhankelijk bent vd firma (zolang het werk) om kodi updates te doen)
Negatief dan is dat himedia bepaalde kodi apps niet zullen werken en je de kodi gui mist tijdens het afspelen
Zidoo heeft tov himedia:
- hdmi 2.0
- betere 4k ondersteuning
- native kodi (maw 3d iso en hd audio in kodi !!!!!) Dus je verliest geen kodi functionaliteiten
- betere netflix ondersteuning
- geen wrapper of externe speler
Wel afhankelijk v zidoo die dus telkens een update moet uitsturen als kodi dit doet. Echter zidoo staat wel enorm gekend voor goeie support (is ook hun uithangbord, heb er wel vertrouwen in, in deze toch)
- lollipop android
- snellere proc
Raymond187
Had net wat specs gevonden. HD 7.1  :thumbs-up:
Specs zien er veel belovend uit. Jammer dat de case plastiek is en niet van aluminium.
skank1
Quote from: Raymond187 on September 16, 2015, 14:29:58
Goh jah.. Voor 90 euro !!!
Er is altijd wel iets te vinden, als het dat maar is :p
Er is bovendien serieuze partnership aan de gang tss zidoo - kodi ;)
Martijn76
#6
Heb nu nog 2 dunes en een ander merk speler voor 3D, vroeger (jaja, op de originele XBOX nog) XBMC gebruikt, de nieuwe KODI implementaties zien er ook erg goed uit..
Wellicht tijd voor een overstap! Voornml. Netflix en series/films van NAS
Waar ik huiverig voor ben is alleen de ondersteuning in de vorm van firmware-updates e.d.
skank1
Die dune is bij mij al lang weg ;)
Die q5 van himedia is ook een optie he, niet zomaar laten vallen, daar ben je minder afhankelijk maar verlies je wel een stuk kodi integratie (enkel during play)
Met deze heb je dat niet, maar zou je in de toekomst van een kodi upgrade wel afhankelijk zijn.
Maar ik zou zo huiverig niet zijn hoor...
1. Telkens kodi upgrade, zijn die nieuwe functies echt niet zo noemenswaardig vind ik persoonljik
2. Die updates gaan volgens mij wel komen vermits zidoo erg goeie support heeft (hun uithangbord)
3. Het toestel kost eigenljik maar 90 euro Dus indien het binnen x jaar idd niet meer zou updaten, tegen dan.. is dat zo erg?
Martijn76
#8
Heb je ook gelijk in, maar bij mij zouden het er direct 2 zijn zodat de interface en mogelijkheden in slaap- en woonkamer gelijk zijn.
Ik zag dat je ook iets had gezegd over Netflix, waar kan ik daar iets over terugvinden? Heb nml. beneden nu gewoon op de SMART TV (maar geen ARC of audio naar versterker, dus audio via TV) en in slaapkamer over de PS4 (waar vrouwlief niet mee om kan/wil gaan). Dus dat zou een mooie selling point voor thuis zijn ;)
Wat gebruik jij op dit moment dan? Zie 't al ;)
Gebruik nu trouwens Yadis op de Dunes en alle media en library staat op de NAS, waarschijnlijk zal ik met Kodi en shared library nog wel wat kunstgrepen moeten uitvoeren op de NAS (unRaid, binnenkort updaten naar 6.0)
skank1
Als je er 2 neemt, is het ideaal als je bv emby gebruikt als backend... dan kun je ook pauzeren en resumen over de 2 toestellen ;)
(en nog andere voordelen)
Martijn76
Quote from: skank1 on September 16, 2015, 15:21:54
Was al aan het lezen (zag dat jij 'm ook gebruikt), denk alleen dat mijn 'server' daar niet echt krachtig genoeg voor is; ik gebruik nu een HP Microserver N40L
skank1
Quote from: Martijn76 on September 16, 2015, 15:25:38
zolang je hem niet aan transcending laat doen , waarom niet?
Proberen !
Martijn76
#12
Quote from: skank1 on September 16, 2015, 15:28:20
Proberen !
Ik ga eerst even de upgrade inplannen :) (misschien dit weekend) en de benodigde dockers installeren (sabnzbd, evt. couchpotatoe, sickbeard en dropbox), ga ondertussen even op zoek naar unraid/emby-integratie (PhAzE Repository zie ik) correctie: HurricaneHernandez' Repository
skank1
Unraid/emby is super makkelijk !
Zorg enkel dat je unraid 6 hebt, en installeer daar de docker !
installatie is  vlekkeloos , zie ook emby topic hier, en unraid topic
Martijn76
Quote from: skank1 on September 16, 2015, 15:33:23
Klinkt goed, ben er even te lang uit geweest... maar volgens mij moet het lukken hoor! :)
TopGun2010
Raymond187
Quote from: skank1 on September 16, 2015, 14:31:09
90euro? Oohh ik zag hem voor 159euro staan. btw wel grappig dat die webshops gewoon geld vragen om Addons te installeren.....
Kan je deze ook gewoon bedienen met een App op je smart phone?
Specs trekken me zeker meer aan dan die Q5.
skank1
Quote from: Raymond187 on September 16, 2015, 15:42:23
91,04 om exact te zijn
http://www.geekbuying.com/item/ZIDOO-X6-Android-5-1-Lollipop-TV-Box-RK3368-Octa-Core-Cortex-A53-2G-16B-1000M-LAN-Dual-Band-WIF-HDMI-2-0-4K-2K-H-265-KODI-3D---Silver-353626.html
Deze kun je idd bedienen met app op je smartphone of met de bijgeleverde ab, die je ook nog es kan programmeren
Raymond187
#18
Muchos gracias  :thumbs-up:  Ik had de hoop opgegeven voor een goeie MP met DTS MA en kodi. En zou een HTPC gaan bouwen.
Zou spmc niet beter werken dan Kodi aangezien deze speciaal aangepast is voor deze chipset...hhhmm
Heb ze een vraag gesteld.
Of je emulators kan installeren en spelen op deze MP. ALs dat kan ga ik hem wel kopen ipv een HTPC bouwen.
skank1
Quote from: Raymond187 on September 16, 2015, 16:14:55
Spmc? nee, das een spinoff v xbmc
gast2018
Mooie specs, echt gaaf!
Raymond187
#21
Quote from: skank1 on September 16, 2015, 15:44:41
Prijs is al 9$ omhoog gegaan.
Omgerekend is het 87.5 euro. Ga hem maar bestellen. Is het niks kan ik hem altijd nog verkopen voor deze prijs, aangezien die in NL 159 euro kost.
Staaled
Douanerechten en BTW ? ;)
gast2018
Ik kom op internet 2 versies tegen. Een met android 4.4 en een met 5.1.
Marco66
Drai zelf kodi op een Raspberry PI 2b en speelt probleemloos alles af, geweldige interface en gebruiksgemak!
Marco
