NEEO - The Thinking Remote
Started by Valkyrie, February 11, 2015, 20:04:05
Valkyrie
#25
Er is weer een nieuwe update en de website is online! :pompom: :pompom: :pompom:
https://neeo.com/
Jammer genoeg is er nog geen nieuwe levertijd vermeld.
De belangrijkste updates:
Blog
A number of backers asked us to post more frequent status updates. That's why we added a blog to our new website. Our goal is to post roughly one article per week. We will continue to send monthly updates to our kickstarter backers, summarizing past events and announcing kickstarter specific news. We are confident that writing weekly posts will not distract us too much from the project. We will try to balance it well. Have fun!
Go to the NEEO blog: https://neeo.com/blog
Works with NEEO
One very important addition to our online presence is a page where you can enter the brand and model name of a device you are planning to connect with NEEO and it will give you an instant feedback. It essentially searches our entire device library for your model name. This includes all device classes, infrared, z-wave and so on. If you can't find it there, simply press the button underneath to request its inclusion. Andy and the driver team will look into it and contact you as soon as it has been tested and added to the library.
Go to WORKS WITH NEEO: http://neeo.com/works-with-neeo
Forum and FAQs
We want to hear your comments and thoughts. The new forum and FAQs allow you to research known questions and share your knowledge and experiences. This is already active from today on and will of course become much more important once you actually use your NEEO. We also started building a properly searchable FAQ (not like the one on kickstarter..).
Go to forum and FAQ: https://support.neeo.com/hc/en-us
papaleo
Leuk zo'n update...?!
Ik zit met mn Pronto voorlopig niet op een schopstoel....,maar nog ff en het is weer Mei,maar dan Mei 2016.... ???
Tja,en dan maar zien of dat de Neeo dan wel af is... :crazy:
Witalik
Looking good, ben benieuwd naar de eerste user reviews !
"Showcase"
road rebel
#28
Er komt een open API voor integratie met bijvoorbeeld itach... Als ze alles doen wat ze beloven is dit mogelijks wel het hebbedingetje die elke av enthousiast op zijn salontafel wilt! Morgen middag gaan de prijzen verder omhoog ;-)
papaleo
Gaat het dan toch nog lukken dit jaar...?
Ze gaan binnenkort de eerste batch verschepen  :clapping:
The Guardian
Ik hoop het!
"This does not mean that NEEO will ship tomorrow but it means that there is some light at the end of the tunnel!"
W.Otter
heel benieuwd naar dit systeem!!
Martinus
mooi project, totdat ik prijs zag. Eerst ff reviews bekijken voor ik 329 dollar overmaak.
en de ETA verschuift ook maar, maar das klassiek kickstarter zover ik heb meegemaakt.
Bama
Vorige week controleerden ze mijn afleveradres dus ik begin toch lichte hoop te krijgen dat hij dit jaar nog komt.
rovinggecko
Ze hebben zelfs mijn meridian 861 toegevoegd! Er is hoop, mee eens.
Roving Gecko's Woonkamer
Ziet er interessant uit. Kan je de remote ook zonder de brain gebruiken, bijvoorbeeld als je alleen IR apparaten wil aansturen? Ik kan het niet vinden op de site.
road rebel
Op de website staat dat je een brain nodig hebt op de remote te kunnen gebruiken. Geen idee hoe het zit met enkel IR!
W.Otter
rovinggecko
Hier ondertussen een bergje fibaro spul aan het installeren. Straks helemaal klaar voor de NEEO
papaleo
Quote from: rovinggecko on December 21, 2015, 14:37:04
Haast je niet...,doe maar rustig aan  :devil:
rovinggecko
:) Wees niet bang, mijn verwachting zijn behoorlijk laag. Maar ondertussen heb ik de 'kerst scene' werkend. Voor de NEEO zal het op zijn vroegst een paas scene zijn gok ik.
Mausman
Ziet er gelikt uit. Is dit een goede vervanger voor de Harmony One die ik momenteel gebruik? Werkt die NEEO hetzelfde als de Harmony; dus 1 druk op de knop en bijv. je tv, receiver en mediaplayer gaan aan en kun je vervolgens selecteren wat je wilt kijken?
rovinggecko
Da's het idee inderdaad. Zien is geloven natuurlijk, maar voorlopig ziet het er goed uit. Check ook rustig of jouw apparaten er tussen zitten, zo nee, aanmelden, de mijne hebben ze al toegevoegd :).
The Guardian
Ik heb Audionet (DNP) aangemeld. Krijg 'n email als't zo  ver is.
W.Otter
heeft iemand al een idee wanneer ze gaan leveren? ik las iets over maart...
The Guardian
Ben benieuwd.
Wacht eerst af wat ze op de CES 2016 presenteren.
gilles0181
Ik gok een partnering met een groot merk om eerlijk te zijn
AVR: Denon X7200WA | AMP: Rotel RB-1582 mkII | Fronts: B&W CM10 S2 | Center: B&W CMC S2 | Sub: Rel T9 | Surround + Back: 4x KEF T101 | Atmos: 4x Q-acoustics QI65CW
Extra: Nvidia Shield TV 2k17 - Sonos Connect - Chromecast 1
The Guardian
Quote from: The Guardian on December 23, 2015, 17:41:01
Gisteren email gekregen dat de codes zijn verwerkt.
W.Otter
de blog is ook weer geüpdatet  :pompom: het schijnt dat ze zéér binnenkort in productie genomen gaat worden :pompom:
rovinggecko
De mail update (die wel heel erg lang was) gaf aan dat er in feb nog 1 test is.
