Anthem MRX Receivers - 710, 510, 310
Started by CinemaDream, September 27, 2013, 10:44:16
CinemaDream
Anthem MRX 710, 510 & 310 aangekondigd
MRX510 and 710 this fall, MRX310 January 2014. come early ...
# More HDMI Connections! 7 HDMI inputs 2 HDMI outputs. MRX 710 and 510 offer an additional HDMI input on the front panel.
# 4K Upscaling and Pass Through.
# HDMI Audio Return Channel.
# Faster HDMI Switching.
# Software updateable via USB drive.
# IP and Serial control for full compatibility with automation systems.
# Home Automation Drivers for all major control systems make integration for home automation a snap for installers.
# iOS (Apple) Compatibility – control the MRX with an iPhone,iPod Touch or iPad.
# Android Compatibility – control the MRX with an Android,Smart Phone or tablet.
# Improved Larger, Easier-to-Read On-Screen Menus.
# Improved 2-Line On-Screen Display.
# Dual setting profiles for both music and movies.
# Speaker crossover now adjustable by 10-Hz steps.
# Optical and Coaxial now available to send to Zone 2.
# Sleeker Aesthetics! Clean, minimalist front-panel styling.
WHAT'S NEW IN ANTHEM ROOM CORRECTION?
- Three more reasons why ARC continues to be the best room correction system on the market!
# A Higher Level of Digital Signal Processing
allows for even greater precision in ARC's correction curves.
# Print A Report
showing in-room response before and after ARC performs its room correcting magic!
# ARC now connects via Ethernet.
No serial connection or adaptor
Moondust
Ik geniet nog steeds van mijn MRX700, mooi apparaat!
Pioneer KRP-600M • Anthem MRX-700 • 2 x Revel F32 + 2 x Revel M22 + Revel C32 • Velodyne DD12 • Samsung DCB-H380R
frank2
Ben je niet de enige. De nieuwe recievers geven niet veel nieuws, behalve apps en een iets betere ARC en dat voor 1000 euro extra. Tsja, ik houd mijn 700 wel, die bevalt goed.
Heb net nieuwe keramische zekeringen erin zitten, geeft een mooiere bas en mids naast het hoog.
evilniek
Ja, wellicht heeft Anthem ook last van de crisis, if it aint broken, dont fix it, gaat hier misschien ook wel een beetje op. Maar toch zijn er hier en daar wel kleine verbeteringen te vinden. Een 2de hdmi output is geen overbodige luxe tegenwoordig, meer flexibiliteit kwa x-over vind ik ook wel interessant (alhoewel het in mijn situatie niet direct nodig zal zijn), bediening via smartphone etc kan mits goed geimplementeerd ook goed uitpakken.
Quote from: CinemaDream on September 27, 2013, 10:44:16
# Print A Report
Iemand enig idee wat a higher level of digital signal processing in de praktijk inhoud ?
Top dat het apparaat ook een printer in zich heeft...ws ga ik hem nu ook kopen.  :D
Gr Hans
riwi
#5
Wel een heel stuk(je) mooier dan de oude serie :
twani
De oude heeft een industriële styling, non conformistisch en best wel cool eigenlijk. Niet mooi, dat niet...
evilniek
Ik vind mijn MRX300 ook niet lelijk hoor, heeft wel wat.
twani
Quote from: evilniek on September 27, 2013, 21:58:37
En ach wat heb ik nou helemaal te vertellen als eigenaar van Harbeth speakers :D
riwi
Ik postte het, maar ik geef eigenlijk ook geen klap om styling  :)
Ik vind ze lekker functioneel en retro eruit zien die x00 serie.
CinemaDream
Quote from: riwi on September 27, 2013, 22:35:43
Jullie kunnen het hopelijk binnenkort in het echt zien ;-)
Bama
Quote from: morca on September 28, 2013, 17:27:59
Ik vind die nieuwe wel mooi   :)
Mee eens, "oude" vind ik zelfs netjes gezegd niet mooi, veel te druk, maar klinkt wel leuk.
Moondust
Quote from: frank2 on September 27, 2013, 18:45:21
Welke zekeringen en was het vervangen eenvoudig?
frank2
Quote from: Moondust on October  9, 2013, 15:39:03
Alle glaszekeringen in de Anthem, dat zijn er 3, twee daarvan zie je zitten en kun je makkelijk bij de laatste zit bij de poweringang, daar moet je 3 schroeven losdraaien, en een beetje "pielen" maar dat is dan de moeilijkste, maar op zich niet erg moeilijk.
Het zijn gewone keramische zekeringen die er in zitten, niets bijzonders. Moet zeggen dat ik het heb laten doen bij Concept&design, heb er wel bijgestaan. De waardes bovenin zijn geloof ik 6,3A maar de laatste bij de poweringang weet ik zo niet.
Maro
Vind de nieuwe serie ook een stuk mooier. Lijkt wel wat op Rotel.
Proceed
evilniek
Nieuwe site Anthem, en wat meer info over de nieuwe MRX lijn.
http://www.anthemav.com/index.php
VerZeLe
Iemand een idee wanneer deze beschikbaar zouden zijn in België/Nederland ?
When The Lights Go Down
CinemaDream
Wij verwachten ze elk moment in huis te hebben. De versterkers zijn al in Nederland en worden vastgehouden door de douane.
VerZeLe
Iemand al weet van de eventuele prijzen? in €
Raymond187
Ongeveer gelijk aan hoe de vorige modellen kosten.
WickedGame
Quote from: Raymond187 on December  6, 2013, 12:12:52
En dat is? Want heb nog steeds geen definitieve prijzen/retail prijzen gehoord.
Zie in iedergeval dat BB&G ze geleverd heeft gekregen.
